Нет иконки audacious
Установил audacious, но иконка в системном лотке не появилась (в настройках включена). Linux mint 20
- Решено: 40
Странно , попробовал установить. В меню появился сразу. У меня минт мате 19,3. Что такое в твоём представление системный лоток? И выведи
Kernel: 5.4.0-56-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
base: Ubuntu 20.04 focal
Type: Portable System: Dell product: Inspiron 3521 v: A12 serial: <filter>
Mobo: Dell model: 06RYX8 v: A02 serial: <filter> UEFI: Dell v: A12
date: 10/25/2013
ID-1: BAT1 charge: 11.4 Wh condition: 11.4/41.4 Wh (28%)
model: Simplo DELL FW1MN31P status: Full
Topology: Dual Core model: Intel Core i3-3217U bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 14366
Speed: 798 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.20.8 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.0.8 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
Sound Server: ALSA v: k5.4.0-56-generic
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: 2000 bus ID: 01:00.0
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: AzureWave AW-NB037H 802.11bgn driver: ath9k v: kernel port: 2000
bus ID: 02:00.0
Device-3: Qualcomm Atheros AR3011 Bluetooth type: USB driver: btusb
bus ID: 1-1.1:4
Local Storage: total: 111.79 GiB used: 13.17 GiB (11.8%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-1: / size: 18.21 GiB used: 10.06 GiB (55.2%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 91.16 GiB used: 3.11 GiB (3.4%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 220 Uptime: 2m Memory: 3.73 GiB used: 1014.2 MiB (26.6%)
inxi: 3.0.38
Нашел где собака зарыта. В настройках апплета "ЗВУК" надо отключить "Скрывать иконки в системном трее для совместимых проигрывателей"
