Cinnamon падает после установки драйверов на GeForce GT 9400
Imbik
15 фев 2021, 10:40
Здравствуйте. Никак не хотят устанавливаться драйвера на GT9400. Устанавливаю через менеджер драйверов. Версия 340.108. После их установки Сinnamon падает в безопасный режим. Ставлю опять nouveau и снова работает. Как победить?
  Kernel: 5.4.0-65-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
  base: Ubuntu 20.04 focal
  Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
  UEFI [Legacy]: American Megatrends v: P4.20 date: 06/18/2020
  Topology: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
  rev: 2 L2 cache: 4096 KiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 102194
  Speed: 1270 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 1281 2: 2762
  3: 1313 4: 1276 5: 2628 6: 3958 7: 3919 8: 3944 9: 1299 10: 1301 11: 2641
  12: 3956 13: 2706 14: 3944 15: 1272 16: 2793
  Device-1: NVIDIA G96C [GeForce 9400 GT] vendor: Micro-Star MSI
  driver: nvidia v: 340.108 bus ID: 09:00.0
  Display: x11 server: X.Org 1.20.9 driver: nvidia
  unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
  OpenGL: renderer: N/A v: N/A direct render: N/A
  Device-1: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
  v: kernel bus ID: 0b:00.3
  Sound Server: ALSA v: k5.4.0-65-generic
  vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 08:00.0
  IF: enp8s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.89 TiB used: 609.63 GiB (31.5%)
  ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-00RKKA0
  ID-2: /dev/sdb vendor: Samsung model: HD103SI size: 931.51 GiB
  ID-3: /dev/sdc vendor: Seagate model: ST380215AS size: 74.53 GiB
  ID-1: / size: 37.25 GiB used: 17.27 GiB (46.4%) fs: ext4 dev: /dev/sda3
  ID-2: /home size: 462.45 GiB used: 286.16 GiB (61.9%) fs: ext4
  dev: /dev/sda5
  ID-3: swap-1 size: 953.0 MiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda6
  System Temperatures: cpu: 43.5 C mobo: 28.0 C gpu: nvidia temp: 39 C
  Fan Speeds (RPM): fan-1: 0 fan-2: 2166 fan-3: 0 fan-4: 718 fan-5: 0
  Voltages: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.22
  Processes: 351 Uptime: 1m Memory: 31.29 GiB used: 1.52 GiB (4.9%)
  inxi: 3.0.38
15 фев 2021, 10:53
Imbik, для каких целей ставишь драйвер невидии? С твоей видяхой и свободного nouveau с голой хватит.
Imbik писал(а):
15 фев 2021, 10:40
Как победить?
Поставить ядро ниже 5.4
Real
15 фев 2021, 13:19
Возможно, дело в версии ядра. Вот что пишут в интернетах
NVidia официально прекратила поддержку драйвера ветки 340.*, который предназначался для семейства видеокарт Tesla G8x, G9x, и GT2xx. Установить эти драйверы можно только на систему с ядром до Linux v5.4 и Xorg 1.20 включительно. На сборку с ядром Linux 5.6 проприетарный драйвер nvidia-340 не установится.
...хотя, по inxi - ядро 5.4.х
Imbik
15 фев 2021, 20:45
Странно однако. Сам минт эти дрова предлогает но они не пашу. Ядро 5.8.0 пишет что устарело, а 5.4.0 актуальное это как?
Драйвера нужны потому что с ними меньше нагрузка на процессор.
15 фев 2021, 20:50
Imbik писал(а):
15 фев 2021, 20:45
https://forum.ubuntu.ru/index.php?topic=313927.0
Решено: 36
15 фев 2021, 20:59
Imbik, nouveau это не на процессоре... Это драйвер бэкинжинирингом созданный и на данный момент он 340 официальный уделывает на старых картах... Так что если не утыкаешься в какой-то софт, который требует специфических фишек н-видиа, рекомендую свободный драйвер использовать
Whowka
Благодарил (а): 777 раз
15 фев 2021, 21:10
15 фев 2021, 20:59
https://www.youtube.com/watch?v=6mVS2xyAe1k
:-D
15 фев 2021, 21:17
Whowka, за пруфами туда же :-D
15 фев 2021, 21:30
Imbik писал(а):
15 фев 2021, 20:45
Потому что ядро 5.8 EOL. Это повезло что в этот раз Canonical, выпуская LTS дистр, взяла ядро LTS. А то обычно они берут проходное ядро, а потом как некроманты поддерживают это ядро.
Решено: 36
15 фев 2021, 21:31
Whowka, ну я полноценных тестов не проводил, но на свободном драйвере у меня температура на буке на 10 градусов ниже, а производительность та же в танках была :) а потом я бросил эти танки...
сейчас у меня драйвер nvidia стоит только на работе для 9800GT и только потому, что в KiCAD не желал рендерить 3D модель платы на свободном драйвере в какой-то версии, да и разница там была порядка 5 градусов опять же в пользу свободного, так что особо не страдаю :)
Imbik
16 фев 2021, 11:17
15 фев 2021, 20:59
Я так и думал до того как установил Mint 20. Зачем он мне постоянно выводит сообщение о том что теперь моя система будет работать медленней и вся графика будет обрабатываться процессором?
16 фев 2021, 11:19
Imbik писал(а):
16 фев 2021, 11:17
а это значит что драйвер не загрузился и рендеринг будет происходить на процессоре, а не на видяхе
Решено: 36
16 фев 2021, 11:21
Imbik писал(а):
16 фев 2021, 11:17
видимо что-то пошлло не так... у тебя и на nvidia хрень полнейшая... что на на nv ты нам не показал, так что можем только гадать :)
Imbik писал(а):
15 фев 2021, 10:40
sheridan
Решено: 14
Благодарил (а): 900 раз
16 фев 2021, 12:03
У Вас хорошее железо, но GeForce 9400 GT явно не в коня корм, поставьте хотя бы GeForce GTX 1650 и все Ваши беды с пропиетарными драйверами закончатся,
забудете nouveau.
Imbik
16 фев 2021, 15:33
sheridan писал(а):
16 фев 2021, 12:03
забудете nouveau.
Понятное дело. Но нужна именно такая затычка, чтоб желания поиграть не возникало)))
Imbik
16 фев 2021, 15:35
16 фев 2021, 11:21
Imbik писал(а):
16 фев 2021, 11:17
Imbik писал(а):
15 фев 2021, 10:40
Как показать? Не понял что именно увидеть хочешь?
Imbik
16 фев 2021, 15:37
driver: nouveau v: kernel bus ID: 09:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
OpenGL: renderer: llvmpipe (LLVM 10.0.1 256 bits) v: 3.3 Mesa 20.1.5
Вот на nouveau. Разве что то не в порядке?
Решено: 36
16 фев 2021, 15:47
Imbik писал(а):
16 фев 2021, 15:37
driver: modesetting
а должен быть nouveau...
Imbik писал(а):
16 фев 2021, 15:37
тоже софтверный выставлен...
что-то не то...
ни какие опции загрузки не лепил в инициализации ядра???
покажи выхлоп cat /etc/default/grub
16 фев 2021, 16:06
Imbik писал(а):
16 фев 2021, 15:33
Тогда купить затычку, только современную
Imbik
16 фев 2021, 16:07
С ядром пониже версией это все запустилось. Но опять сообщение о том что система работает без видеоускорения. И вот теперь по настоящему все тормозит :dash2:
  Kernel: 5.4.0-26-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
  bogomips: 102195
  Speed: 1481 MHz min/max: 1550/3200 MHz Core speeds (MHz): 1: 1330 2: 2411
  3: 2763 4: 1330 5: 3623 6: 1459 7: 1586 8: 1330 9: 2413 10: 1330 11: 2784
  12: 1713 13: 1351 14: 1326 15: 1326 16: 2481
