~$ inxi -Fxz
Kernel: 5.4.0-66-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Cinnamon 4.8.6 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Type: Desktop Mobo: Biostar model: P35D2-A7 serial: <filter> BIOS: Phoenix
v: 6.00 PG date: 07/18/2008
Topology: Dual Core model: Intel Core2 Duo E8200 bits: 64 type: MCP
arch: Penryn rev: 6 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 10644
Speed: 1996 MHz min/max: 1998/2664 MHz Core speeds (MHz): 1: 1996 2: 1996
Device-1: AMD RV670 [Radeon HD 3690/3850] vendor: ASUSTeK driver: radeon
v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: ati,radeon
OpenGL: renderer: AMD RV670 (DRM 2.50.0 / 5.4.0-66-generic LLVM 11.0.0)
v: 3.3 Mesa 20.2.6 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: Biostar Microtech Intl Corp
Device-2: AMD RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-66-generic
Device-1: Ralink RT3060 Wireless 802.11n 1T/1R driver: rt2800pci v: 2.3.0
port: db00 bus ID: 04:01.0
IF: wlp4s1 state: up mac: <filter>
Device-2: Realtek RTL-8110SC/8169SC Gigabit Ethernet
vendor: Biostar Microtech Intl Corp driver: r8169 v: kernel port: ce00
bus ID: 04:04.0
IF: enp4s4 state: down mac: <filter>
Local Storage: total: 456.46 GiB used: 22.77 GiB (5.0%)
ID-1: /dev/sda vendor: Crucial model: CT240BX500SSD1 size: 223.57 GiB
temp: 41 C
ID-2: /dev/sdb vendor: Samsung model: HD251HJ size: 232.89 GiB temp: 29 C
ID-1: / size: 27.38 GiB used: 9.06 GiB (33.1%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 56.63 GiB used: 13.63 GiB (24.1%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 3.72 GiB used: 82.5 MiB (2.2%) fs: swap dev: /dev/sda5
System Temperatures: cpu: 44.0 C mobo: N/A gpu: radeon temp: 63 C
Processes: 215 Uptime: 3h 46m Memory: 3.84 GiB used: 2.00 GiB (51.9%)
inxi: 3.0.38
bus ID: 04:04.0
temp: 41 C
inxi: 3.0.38
