Давайте какой есть)
Mint 18.1 и 2 карты radeon
SemenSinchenko, вот полностью рабочий:
[ 15.705] (--) Log file renamed from "/var/log/Xorg.pid-1250.log" to "/var/log/Xorg.0.log"
[ 15.716]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 15.716] X Protocol Version 11, Revision 0
[ 15.716] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[ 15.716] Current Operating System: Linux io-serena 4.4.0-53-generic #74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016 x86_64
[ 15.716] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-53-generic root=UUID=31afcf19-4a79-4b0e-a194-58d1bedbe8ba ro quiet splash vt.handoff=7
[ 15.716] Build Date: 02 November 2016 10:06:10PM
[ 15.716] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
[ 15.716] Current version of pixman: 0.33.6
[ 15.716] Before reporting problems, check http://wiki.x.org
[ 15.716] Markers: (--) probed, (**) from config file, (==) default setting,
[ 15.716] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb 22 15:17:44 2017
[ 15.718] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 15.738] (==) No Layout section. Using the first Screen section.
[ 15.738] (==) No screen section available. Using defaults.
[ 15.738] (**) |-->Screen "Default Screen Section" (0)
[ 15.738] (**) | |-->Monitor "<default monitor>"
[ 15.748] (==) No monitor specified for screen "Default Screen Section".
[ 15.748] (==) Automatically adding devices
[ 15.748] (==) Automatically enabling devices
[ 15.748] (==) Automatically adding GPU devices
[ 15.748] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 15.818] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 15.818] Entry deleted from font path.
[ 15.818] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 15.818] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 15.820] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 15.820] Entry deleted from font path.
[ 15.820] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 15.820] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 15.820] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 15.820] (II) The server relies on udev to provide the list of input devices.
[ 15.820] (II) Loader magic: 0x55dd54fc5dc0
[ 15.820] (II) Module ABI versions:
[ 15.820] X.Org ANSI C Emulation: 0.4
[ 15.820] X.Org Video Driver: 20.0
[ 15.820] X.Org XInput driver : 22.1
[ 15.821] X.Org Server Extension : 9.0
[ 15.822] (++) using VT number 7
[ 15.822] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 15.822] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 15.822] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 15.825] (--) PCI:*(0:3:0:0) 1002:68da:174b:1621 rev 0, Mem @ 0xc0000000/268435456, 0xfbbc0000/131072, I/O @ 0x0000b000/256, BIOS @ 0x????????/131072
[ 15.825] (--) PCI: (0:4:0:0) 1002:9540:1458:21ae rev 0, Mem @ 0xd0000000/268435456, 0xfbce0000/65536, I/O @ 0x0000c000/256, BIOS @ 0x????????/131072
[ 15.825] (II) LoadModule: "glx"
[ 15.849] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 16.188] (II) Module glx: vendor="X.Org Foundation"
[ 16.188] compiled for 1.18.4, module version = 1.0.0
[ 16.188] ABI class: X.Org Server Extension, version 9.0
[ 16.188] (==) AIGLX enabled
[ 16.188] (==) Matched ati as autoconfigured driver 0
[ 16.188] (==) Matched ati as autoconfigured driver 1
[ 16.188] (==) Matched ati as autoconfigured driver 2
[ 16.188] (==) Matched modesetting as autoconfigured driver 3
[ 16.188] (==) Matched fbdev as autoconfigured driver 4
[ 16.188] (==) Matched vesa as autoconfigured driver 5
[ 16.188] (==) Assigned the driver to the xf86ConfigLayout
[ 16.188] (II) LoadModule: "ati"
[ 16.209] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 16.215] (II) Module ati: vendor="X.Org Foundation"
[ 16.215] compiled for 1.18.3, module version = 7.7.0
[ 16.215] Module class: X.Org Video Driver
[ 16.215] ABI class: X.Org Video Driver, version 20.0
[ 16.215] (II) LoadModule: "radeon"
[ 16.215] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 16.255] (II) Module radeon: vendor="X.Org Foundation"
[ 16.255] compiled for 1.18.3, module version = 7.7.0
[ 16.255] Module class: X.Org Video Driver
[ 16.255] ABI class: X.Org Video Driver, version 20.0
[ 16.255] (II) LoadModule: "modesetting"
[ 16.255] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 16.267] (II) Module modesetting: vendor="X.Org Foundation"
[ 16.267] compiled for 1.18.4, module version = 1.18.4
[ 16.267] Module class: X.Org Video Driver
[ 16.267] ABI class: X.Org Video Driver, version 20.0
[ 16.267] (II) LoadModule: "fbdev"
[ 16.267] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 16.269] (II) Module fbdev: vendor="X.Org Foundation"
[ 16.269] compiled for 1.18.1, module version = 0.4.4
[ 16.269] Module class: X.Org Video Driver
[ 16.269] ABI class: X.Org Video Driver, version 20.0
[ 16.269] (II) LoadModule: "vesa"
[ 16.269] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 16.270] (II) Module vesa: vendor="X.Org Foundation"
[ 16.270] compiled for 1.18.1, module version = 2.3.4
[ 16.270] Module class: X.Org Video Driver
[ 16.270] ABI class: X.Org Video Driver, version 20.0
[ 16.270] (II) RADEON: Driver for ATI Radeon chipsets:
ATI Radeon Mobility X600 (M24) 3150 (PCIE), ATI FireMV 2400 (PCI),
ATI Radeon Mobility X300 (M24) 3152 (PCIE),
ATI FireGL M24 GL 3154 (PCIE), ATI FireMV 2400 3155 (PCI),
ATI Radeon X600 (RV380) 3E50 (PCIE),
ATI FireGL V3200 (RV380) 3E54 (PCIE), ATI Radeon IGP320 (A3) 4136,
ATI Radeon IGP330/340/350 (A4) 4137, ATI Radeon 9500 AD (AGP),
ATI Radeon 9500 AE (AGP), ATI Radeon 9600TX AF (AGP),
ATI FireGL Z1 AG (AGP), ATI Radeon 9800SE AH (AGP),
ATI Radeon 9800 AI (AGP), ATI Radeon 9800 AJ (AGP),
ATI FireGL X2 AK (AGP), ATI Radeon 9600 AP (AGP),
ATI Radeon 9600SE AQ (AGP), ATI Radeon 9600XT AR (AGP),
ATI Radeon 9600 AS (AGP), ATI FireGL T2 AT (AGP), ATI Radeon 9650,
ATI FireGL RV360 AV (AGP), ATI Radeon 7000 IGP (A4+) 4237,
ATI Radeon 8500 AIW BB (AGP), ATI Radeon IGP320M (U1) 4336,
ATI Radeon IGP330M/340M/350M (U2) 4337,
ATI Radeon Mobility 7000 IGP 4437, ATI Radeon 9000/PRO If (AGP/PCI),
ATI Radeon 9000 Ig (AGP/PCI), ATI Radeon X800 (R420) JH (AGP),
ATI Radeon X800PRO (R420) JI (AGP),
ATI Radeon X800SE (R420) JJ (AGP), ATI Radeon X800 (R420) JK (AGP),
ATI Radeon X800 (R420) JL (AGP), ATI FireGL X3 (R420) JM (AGP),
ATI Radeon Mobility 9800 (M18) JN (AGP),
ATI Radeon X800 SE (R420) (AGP), ATI Radeon X800XT (R420) JP (AGP),
ATI Radeon X800 VE (R420) JT (AGP), ATI Radeon X850 (R480) (AGP),
ATI Radeon X850 XT (R480) (AGP), ATI Radeon X850 SE (R480) (AGP),
ATI Radeon X850 PRO (R480) (AGP), ATI Radeon X850 XT PE (R480) (AGP),
ATI Radeon Mobility M7 LW (AGP),
ATI Mobility FireGL 7800 M7 LX (AGP),
ATI Radeon Mobility M6 LY (AGP), ATI Radeon Mobility M6 LZ (AGP),
ATI FireGL Mobility 9000 (M9) Ld (AGP),
ATI Radeon Mobility 9000 (M9) Lf (AGP),
ATI Radeon Mobility 9000 (M9) Lg (AGP), ATI FireMV 2400 PCI,
ATI Radeon 9700 Pro ND (AGP), ATI Radeon 9700/9500Pro NE (AGP),
ATI Radeon 9600TX NF (AGP), ATI FireGL X1 NG (AGP),
ATI Radeon 9800PRO NH (AGP), ATI Radeon 9800 NI (AGP),
ATI FireGL X2 NK (AGP), ATI Radeon 9800XT NJ (AGP),
ATI Radeon Mobility 9600/9700 (M10/M11) NP (AGP),
ATI Radeon Mobility 9600 (M10) NQ (AGP),
ATI Radeon Mobility 9600 (M11) NR (AGP),
ATI Radeon Mobility 9600 (M10) NS (AGP),
ATI FireGL Mobility T2 (M10) NT (AGP),
ATI FireGL Mobility T2e (M11) NV (AGP), ATI Radeon QD (AGP),
ATI Radeon QE (AGP), ATI Radeon QF (AGP), ATI Radeon QG (AGP),
ATI FireGL 8700/8800 QH (AGP), ATI Radeon 8500 QL (AGP),
ATI Radeon 9100 QM (AGP), ATI Radeon 7500 QW (AGP/PCI),
ATI Radeon 7500 QX (AGP/PCI), ATI Radeon VE/7000 QY (AGP/PCI),
ATI Radeon VE/7000 QZ (AGP/PCI), ATI ES1000 515E (PCI),
ATI Radeon Mobility X300 (M22) 5460 (PCIE),
ATI Radeon Mobility X600 SE (M24C) 5462 (PCIE),
ATI FireGL M22 GL 5464 (PCIE), ATI Radeon X800 (R423) UH (PCIE),
ATI Radeon X800PRO (R423) UI (PCIE),
ATI Radeon X800LE (R423) UJ (PCIE),
ATI Radeon X800SE (R423) UK (PCIE),
ATI Radeon X800 XTP (R430) (PCIE), ATI Radeon X800 XL (R430) (PCIE),
ATI Radeon X800 SE (R430) (PCIE), ATI Radeon X800 (R430) (PCIE),
ATI FireGL V7100 (R423) (PCIE), ATI FireGL V5100 (R423) UQ (PCIE),
ATI FireGL unknown (R423) UR (PCIE),
ATI FireGL unknown (R423) UT (PCIE),
ATI Mobility FireGL V5000 (M26) (PCIE),
ATI Mobility Radeon X700 XL (M26) (PCIE),
ATI Mobility Radeon X700 (M26) (PCIE),
ATI Radeon X550XTX 5657 (PCIE), ATI Radeon 9100 IGP (A5) 5834,
ATI Radeon Mobility 9100 IGP (U3) 5835,
ATI Radeon XPRESS 200 5954 (PCIE),
ATI Radeon XPRESS 200M 5955 (PCIE), ATI Radeon 9250 5960 (AGP),
ATI Radeon 9200 5961 (AGP), ATI Radeon 9200 5962 (AGP),
ATI Radeon 9200SE 5964 (AGP), ATI FireMV 2200 (PCI),
ATI ES1000 5969 (PCI), ATI Radeon XPRESS 200 5974 (PCIE),
ATI Radeon XPRESS 200M 5975 (PCIE),
ATI Radeon XPRESS 200 5A41 (PCIE),
ATI Radeon XPRESS 200M 5A42 (PCIE),
ATI Radeon XPRESS 200 5A61 (PCIE),
ATI Radeon XPRESS 200M 5A62 (PCIE),
ATI Radeon X300 (RV370) 5B60 (PCIE),
ATI Radeon X600 (RV370) 5B62 (PCIE),
ATI Radeon X550 (RV370) 5B63 (PCIE),
ATI FireGL V3100 (RV370) 5B64 (PCIE),
ATI FireMV 2200 PCIE (RV370) 5B65 (PCIE),
ATI Radeon Mobility 9200 (M9+) 5C61 (AGP),
ATI Radeon Mobility 9200 (M9+) 5C63 (AGP),
ATI Mobility Radeon X800 XT (M28) (PCIE),
ATI Mobility FireGL V5100 (M28) (PCIE),
ATI Mobility Radeon X800 (M28) (PCIE), ATI Radeon X850 5D4C (PCIE),
ATI Radeon X850 XT PE (R480) (PCIE),
ATI Radeon X850 SE (R480) (PCIE), ATI Radeon X850 PRO (R480) (PCIE),
ATI unknown Radeon / FireGL (R480) 5D50 (PCIE),
ATI Radeon X850 XT (R480) (PCIE),
ATI Radeon X800XT (R423) 5D57 (PCIE),
ATI FireGL V5000 (RV410) (PCIE), ATI Radeon X700 XT (RV410) (PCIE),
ATI Radeon X700 PRO (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X700 (RV410) (PCIE),
ATI Radeon X700 SE (RV410) (PCIE), ATI Radeon X1800,
ATI Mobility Radeon X1800 XT, ATI Mobility Radeon X1800,
ATI Mobility FireGL V7200, ATI FireGL V7200, ATI FireGL V5300,
ATI Mobility FireGL V7100, ATI Radeon X1800, ATI Radeon X1800,
ATI Radeon X1800, ATI Radeon X1800, ATI Radeon X1800,
ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
ATI Mobility Radeon X1400, ATI Radeon X1300/X1550,
ATI Radeon X1550 64-bit, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Mobility Radeon X1300,
ATI Mobility Radeon X1300, ATI Radeon X1300, ATI Radeon X1300,
ATI RV505, ATI RV505, ATI FireGL V3300, ATI FireGL V3350,
ATI Radeon X1300, ATI Radeon X1550 64-bit, ATI Radeon X1300/X1550,
ATI Radeon X1600, ATI Radeon X1300/X1550, ATI Mobility Radeon X1450,
ATI Radeon X1300/X1550, ATI Mobility Radeon X2300,
ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
ATI Mobility Radeon X1350, ATI Mobility Radeon X1450,
ATI Radeon X1300, ATI Radeon X1550, ATI Mobility Radeon X1350,
ATI FireMV 2250, ATI Radeon X1550 64-bit, ATI Radeon X1600,
ATI Radeon X1650, ATI Radeon X1600, ATI Radeon X1600,
ATI Mobility FireGL V5200, ATI Mobility Radeon X1600,
ATI Radeon X1650, ATI Radeon X1650, ATI Radeon X1600,
ATI Radeon X1300 XT/X1600 Pro, ATI FireGL V3400,
ATI Mobility FireGL V5250, ATI Mobility Radeon X1700,
ATI Mobility Radeon X1700 XT, ATI FireGL V5200,
ATI Mobility Radeon X1700, ATI Radeon X2300HD,
ATI Mobility Radeon HD 2300, ATI Mobility Radeon HD 2300,
ATI Radeon X1950, ATI Radeon X1900, ATI Radeon X1950,
ATI Radeon X1900, ATI Radeon X1900, ATI Radeon X1900,
ATI AMD Stream Processor, ATI Radeon X1900, ATI Radeon X1950,
ATI RV560, ATI RV560, ATI Mobility Radeon X1900, ATI RV560,
ATI Radeon X1950 GT, ATI RV570, ATI RV570, ATI FireGL V7400,
ATI RV560, ATI Radeon X1650, ATI Radeon X1650, ATI RV560,
ATI Radeon 9100 PRO IGP 7834, ATI Radeon Mobility 9200 IGP 7835,
ATI Radeon X1200, ATI Radeon X1200, ATI Radeon X1200,
ATI Radeon X1200, ATI Radeon X1200, ATI RS740, ATI RS740M, ATI RS740,
ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 XT,
ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro, ATI Radeon HD 2900 GT,
ATI FireGL V8650, ATI FireGL V8600, ATI FireGL V7600,
ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
ATI Radeon 4800 Series, ATI Radeon HD 4850 x2,
ATI FirePro V8750 (FireGL), ATI FirePro V7760 (FireGL),
ATI Mobility RADEON HD 4850, ATI Mobility RADEON HD 4850 X2,
ATI Radeon 4800 Series, ATI FirePro RV770, AMD FireStream 9270,
AMD FireStream 9250, ATI FirePro V8700 (FireGL),
ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
ATI Mobility RADEON HD 4870, ATI Radeon 4800 Series,
ATI Radeon 4800 Series, ATI FirePro M7750, ATI M98, ATI M98, ATI M98,
ATI Mobility Radeon HD 4650, ATI Radeon RV730 (AGP),
ATI Mobility Radeon HD 4670, ATI FirePro M5750,
ATI Mobility Radeon HD 4670, ATI Radeon RV730 (AGP),
ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI Radeon HD 4770,
ATI FirePro M5750, ATI RV610, ATI Radeon HD 2400 XT,
ATI Radeon HD 2400 Pro, ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000,
ATI RV610, ATI Radeon HD 2350, ATI Mobility Radeon HD 2400 XT,
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610,
ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
ATI Mobility Radeon HD 3850 X2, ATI RV670,
ATI Mobility Radeon HD 3870, ATI Mobility Radeon HD 3870 X2,
ATI Radeon HD3870 X2, ATI FireGL V7700, ATI Radeon HD3850,
ATI Radeon HD3690, AMD Firestream 9170, ATI Radeon HD 4550,
ATI Radeon RV710, ATI Radeon RV710, ATI Radeon RV710,
ATI Radeon HD 4350, ATI Mobility Radeon 4300 Series,
ATI Mobility Radeon 4500 Series, ATI Mobility Radeon 4500 Series,
ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
ATI FireGL V3600, ATI Radeon HD 2600 LE,
ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
ATI Radeon HD 3450, ATI Radeon HD 3450, ATI Radeon HD 3430,
ATI Radeon HD 3450, ATI FirePro V3700, ATI FireMV 2450,
ATI FireMV 2260, ATI FireMV 2260, ATI Radeon HD 3600 Series,
ATI Radeon HD 3650 AGP, ATI Radeon HD 3600 PRO,
ATI Radeon HD 3600 XT, ATI Radeon HD 3600 PRO,
ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
ATI Radeon HD 3300 Graphics, ATI Radeon HD 3200 Graphics,
ATI Radeon 3000 Graphics, SUMO, SUMO, SUMO2, SUMO2, SUMO2, SUMO2,
SUMO, SUMO, SUMO2, SUMO, SUMO, SUMO, SUMO, SUMO, ATI Radeon HD 4200,
ATI Radeon 4100, ATI Mobility Radeon HD 4200,
ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
AMD Radeon HD 6310 Graphics, AMD Radeon HD 6310 Graphics,
AMD Radeon HD 6250 Graphics, AMD Radeon HD 6250 Graphics,
AMD Radeon HD 6300 Series Graphics,
AMD Radeon HD 6200 Series Graphics, PALM, PALM, PALM, CYPRESS,
ATI FirePro (FireGL) Graphics Adapter,
ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
AMD Firestream 9350, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5800 Series,
ATI Radeon HD 5800 Series, ATI Radeon HD 5900 Series,
ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
ATI Mobility Radeon HD 5800 Series, ATI Radeon HD 5700 Series,
ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
ATI Mobility Radeon HD 5000 Series,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
ATI FirePro (FireGL) Graphics Adapter, ATI Radeon HD 5670,
ATI Radeon HD 5570, ATI Radeon HD 5500 Series, REDWOOD,
ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon Graphics,
ATI Mobility Radeon Graphics, CEDAR,
ATI FirePro (FireGL) Graphics Adapter, ATI FirePro 2270, CEDAR,
ATI Radeon HD 5450, CEDAR, CEDAR, CAYMAN, CAYMAN, CAYMAN, CAYMAN,
CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN, CAYMAN,
AMD Radeon HD 6900 Series, AMD Radeon HD 6900 Series, CAYMAN, CAYMAN,
CAYMAN, AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series,
BARTS, BARTS, Mobility Radeon HD 6000 Series,
Mobility Radeon HD 6000 Series, BARTS, BARTS, BARTS, BARTS,
AMD Radeon HD 6800 Series, AMD Radeon HD 6800 Series,
AMD Radeon HD 6700 Series, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS, TURKS,
CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS,
CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, CAICOS, ARUBA, ARUBA,
ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, ARUBA,
ARUBA, ARUBA, ARUBA, ARUBA, ARUBA, TAHITI, TAHITI, TAHITI, TAHITI,
TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI, TAHITI,
TAHITI, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN,
PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN, PITCAIRN,
VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE, VERDE,
VERDE, VERDE, VERDE, VERDE, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND,
OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND, OLAND,
OLAND, HAINAN, HAINAN, HAINAN, HAINAN, HAINAN, HAINAN, BONAIRE,
BONAIRE, BONAIRE, BONAIRE, BONAIRE, BONAIRE, BONAIRE, BONAIRE,
BONAIRE, BONAIRE, BONAIRE, KABINI, KABINI, KABINI, KABINI, KABINI,
KABINI, KABINI, KABINI, KABINI, KABINI, KABINI, KABINI, KABINI,
KABINI, KABINI, KABINI, MULLINS, MULLINS, MULLINS, MULLINS, MULLINS,
MULLINS, MULLINS, MULLINS, MULLINS, MULLINS, MULLINS, MULLINS,
MULLINS, MULLINS, MULLINS, MULLINS, KAVERI, KAVERI, KAVERI, KAVERI,
KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI, KAVERI,
KAVERI, KAVERI, HAWAII, HAWAII, HAWAII, HAWAII, HAWAII, HAWAII,
[ 16.274] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 16.274] (II) FBDEV: driver for framebuffer: fbdev
[ 16.274] (II) VESA: driver for VESA chipsets: vesa
[ 16.285] (II) [KMS] Kernel modesetting enabled.
[ 16.285] (WW) Falling back to old probe method for modesetting
[ 16.285] (WW) Falling back to old probe method for fbdev
[ 16.285] (II) Loading sub module "fbdevhw"
[ 16.285] (II) LoadModule: "fbdevhw"
[ 16.285] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 16.302] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 16.302] compiled for 1.18.4, module version = 0.0.2
[ 16.302] ABI class: X.Org Video Driver, version 20.0
[ 16.302] (WW) Falling back to old probe method for vesa
[ 16.302] (II) RADEON(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 16.302] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[ 16.302] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 16.302] (==) RADEON(0): Default visual is TrueColor
[ 16.302] (==) RADEON(0): RGB weight 888
[ 16.302] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[ 16.302] (--) RADEON(0): Chipset: "ATI Radeon HD 5500 Series" (ChipID = 0x68da)
[ 16.302] (II) Loading sub module "fb"
[ 16.302] (II) LoadModule: "fb"
[ 16.302] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 16.336] (II) Module fb: vendor="X.Org Foundation"
[ 16.336] compiled for 1.18.4, module version = 1.0.0
[ 16.336] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.336] (II) Loading sub module "dri2"
[ 16.336] (II) LoadModule: "dri2"
[ 16.336] (II) Module "dri2" already built-in
[ 16.336] (II) Loading sub module "exa"
[ 16.336] (II) LoadModule: "exa"
[ 16.336] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 16.344] (II) Module exa: vendor="X.Org Foundation"
[ 16.344] compiled for 1.18.4, module version = 2.6.0
[ 16.344] ABI class: X.Org Video Driver, version 20.0
[ 16.344] (II) RADEON(0): KMS Color Tiling: enabled
[ 16.344] (II) RADEON(0): KMS Color Tiling 2D: enabled
[ 16.344] (II) RADEON(0): KMS Pageflipping: enabled
[ 16.344] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[ 16.408] (II) RADEON(0): Output HDMI-0 has no monitor section
[ 16.439] (II) RADEON(0): Output DVI-0 has no monitor section
[ 16.470] (II) RADEON(0): Output VGA-0 has no monitor section
[ 16.532] (II) RADEON(0): EDID for output HDMI-0
[ 16.563] (II) RADEON(0): EDID for output DVI-0
[ 16.563] (II) RADEON(0): Manufacturer: BNQ Model: 783f Serial#: 21573
[ 16.563] (II) RADEON(0): Year: 2010 Week: 3
[ 16.563] (II) RADEON(0): EDID Version: 1.3
[ 16.563] (II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 16.563] (II) RADEON(0): Sync: Separate Composite SyncOnGreen
[ 16.563] (II) RADEON(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 16.563] (II) RADEON(0): Gamma: 2.20
[ 16.563] (II) RADEON(0): DPMS capabilities: Off; RGB/Color Display
[ 16.563] (II) RADEON(0): Default color space is primary color space
[ 16.563] (II) RADEON(0): First detailed timing is preferred mode
[ 16.563] (II) RADEON(0): redX: 0.649 redY: 0.338 greenX: 0.289 greenY: 0.609
[ 16.563] (II) RADEON(0): blueX: 0.146 blueY: 0.070 whiteX: 0.312 whiteY: 0.329
[ 16.563] (II) RADEON(0): Supported established timings:
[ 16.563] (II) RADEON(0): 720x400@70Hz
[ 16.563] (II) RADEON(0): 640x480@60Hz
[ 16.563] (II) RADEON(0): 640x480@75Hz
[ 16.563] (II) RADEON(0): 800x600@60Hz
[ 16.563] (II) RADEON(0): 800x600@75Hz
[ 16.563] (II) RADEON(0): 832x624@75Hz
[ 16.563] (II) RADEON(0): 1024x768@60Hz
[ 16.563] (II) RADEON(0): 1024x768@75Hz
[ 16.563] (II) RADEON(0): 1280x1024@75Hz
[ 16.563] (II) RADEON(0): 1152x864@75Hz
[ 16.563] (II) RADEON(0): Manufacturer's mask: 0
[ 16.563] (II) RADEON(0): Supported standard timings:
[ 16.563] (II) RADEON(0): #0: hsize: 1152 vsize 720 refresh: 60 vid: 113
[ 16.563] (II) RADEON(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 16.563] (II) RADEON(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 16.563] (II) RADEON(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.563] (II) RADEON(0): #4: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 16.563] (II) RADEON(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 16.563] (II) RADEON(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 16.563] (II) RADEON(0): Supported detailed timing:
[ 16.563] (II) RADEON(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 16.563] (II) RADEON(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 16.563] (II) RADEON(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 16.563] (II) RADEON(0): Serial No: Y1A06749SL0
[ 16.563] (II) RADEON(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 83 kHz, PixClock max 175 MHz
[ 16.563] (II) RADEON(0): Monitor name: BenQ G2420HD
[ 16.563] (II) RADEON(0): EDID (in hex):
[ 16.563] (II) RADEON(0): 00ffffffffffff0009d13f7845540000
[ 16.563] (II) RADEON(0): 031401030e351e782e6081a6564a9c25
[ 16.563] (II) RADEON(0): 125054a56b80710081c081408180a9c0
[ 16.563] (II) RADEON(0): b300d1c00101023a801871382d40582c
[ 16.563] (II) RADEON(0): 4500132b2100001a000000ff00593141
[ 16.563] (II) RADEON(0): 3036373439534c300a20000000fd0032
[ 16.563] (II) RADEON(0): 4c185311000a202020202020000000fc
[ 16.563] (II) RADEON(0): 0042656e5120473234323048440a0088
[ 16.563] (II) RADEON(0): Printing probed modes for output DVI-0
[ 16.563] (II) RADEON(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
[ 16.563] (II) RADEON(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1152x720"x60.0 67.28 1152 1208 1328 1504 720 721 724 746 -hsync +vsync (44.7 kHz)
[ 16.563] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 16.563] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.563] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.563] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.563] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.563] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.563] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.563] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 15.716]
built-ins
продолжение:
сорян - поправил)
[ 16.595] (II) RADEON(0): EDID for output VGA-0
[ 16.595] (II) RADEON(0): Manufacturer: HWP Model: 26eb Serial#: 16843009
[ 16.595] (II) RADEON(0): Year: 2009 Week: 26
[ 16.595] (II) RADEON(0): EDID Version: 1.3
[ 16.595] (II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 16.595] (II) RADEON(0): Sync: Separate
[ 16.595] (II) RADEON(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 16.595] (II) RADEON(0): Gamma: 2.40
[ 16.595] (II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 16.595] (II) RADEON(0): Default color space is primary color space
[ 16.595] (II) RADEON(0): First detailed timing is preferred mode
[ 16.595] (II) RADEON(0): redX: 0.639 redY: 0.342 greenX: 0.297 greenY: 0.614
[ 16.595] (II) RADEON(0): blueX: 0.146 blueY: 0.067 whiteX: 0.312 whiteY: 0.328
[ 16.595] (II) RADEON(0): Supported established timings:
[ 16.595] (II) RADEON(0): 720x400@70Hz
[ 16.595] (II) RADEON(0): 640x480@60Hz
[ 16.595] (II) RADEON(0): 640x480@72Hz
[ 16.595] (II) RADEON(0): 640x480@75Hz
[ 16.595] (II) RADEON(0): 800x600@60Hz
[ 16.595] (II) RADEON(0): 800x600@72Hz
[ 16.595] (II) RADEON(0): 800x600@75Hz
[ 16.595] (II) RADEON(0): 832x624@75Hz
[ 16.595] (II) RADEON(0): 1024x768@60Hz
[ 16.595] (II) RADEON(0): 1024x768@70Hz
[ 16.595] (II) RADEON(0): 1024x768@75Hz
[ 16.595] (II) RADEON(0): 1280x1024@75Hz
[ 16.595] (II) RADEON(0): 1152x864@75Hz
[ 16.595] (II) RADEON(0): Manufacturer's mask: 0
[ 16.595] (II) RADEON(0): Supported standard timings:
[ 16.595] (II) RADEON(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.595] (II) RADEON(0): Supported detailed timing:
[ 16.595] (II) RADEON(0): clock: 108.0 MHz Image Size: 340 x 270 mm
[ 16.595] (II) RADEON(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 16.595] (II) RADEON(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 16.595] (II) RADEON(0): Ranges: V min: 50 V max: 77 Hz, H min: 24 H max: 83 kHz, PixClock max 145 MHz
[ 16.595] (II) RADEON(0): Monitor name: HP L1710
[ 16.595] (II) RADEON(0): Serial No: CNC926PGYG
[ 16.595] (II) RADEON(0): EDID (in hex):
[ 16.595] (II) RADEON(0): 00ffffffffffff0022f0eb2601010101
[ 16.595] (II) RADEON(0): 1a13010368221b8ceea150a3574c9d25
[ 16.595] (II) RADEON(0): 115054adef8081800101010101010101
[ 16.595] (II) RADEON(0): 010101010101302a009851002a403070
[ 16.595] (II) RADEON(0): 1300540e1100001e000000fd00324d18
[ 16.595] (II) RADEON(0): 530e000a202020202020000000fc0048
[ 16.595] (II) RADEON(0): 50204c313731300a20202020000000ff
[ 16.595] (II) RADEON(0): 00434e43393236504759470a202000be
[ 16.595] (II) RADEON(0): Printing probed modes for output VGA-0
[ 16.595] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 16.595] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.595] (II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.595] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 16.595] (II) RADEON(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 16.595] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.595] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.595] (II) RADEON(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 16.595] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.595] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.595] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.595] (II) RADEON(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 16.595] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.595] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.595] (II) RADEON(0): Output HDMI-0 disconnected
[ 16.595] (II) RADEON(0): Output DVI-0 connected
[ 16.595] (II) RADEON(0): Output VGA-0 connected
[ 16.595] (II) RADEON(0): Using spanning desktop for initial modes
[ 16.595] (II) RADEON(0): Output DVI-0 using initial mode 1920x1080 +0+0
[ 16.595] (II) RADEON(0): Output VGA-0 using initial mode 1280x1024 +1920+0
[ 16.595] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 16.595] (II) RADEON(0): mem size init: gart size :3fdde000 vram size: s:80000000 visible:7f3b8000
[ 16.595] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[ 16.595] (==) RADEON(0): DPI set to (96, 96)
[ 16.595] (II) Loading sub module "ramdac"
[ 16.595] (II) LoadModule: "ramdac"
[ 16.595] (II) Module "ramdac" already built-in
[ 16.595] (==) RADEON(G0): Depth 24, (--) framebuffer bpp 32
[ 16.595] (II) RADEON(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 16.595] (==) RADEON(G0): Default visual is TrueColor
[ 16.595] (==) RADEON(G0): RGB weight 888
[ 16.595] (II) RADEON(G0): Using 8 bits per RGB (8 bit DAC)
[ 16.595] (--) RADEON(G0): Chipset: "ATI Radeon HD 4550" (ChipID = 0x9540)
[ 16.595] (II) Loading sub module "fb"
[ 16.595] (II) LoadModule: "fb"
[ 16.595] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 16.595] (II) Module fb: vendor="X.Org Foundation"
[ 16.595] compiled for 1.18.4, module version = 1.0.0
[ 16.595] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.595] (II) Loading sub module "dri2"
[ 16.595] (II) LoadModule: "dri2"
[ 16.595] (II) Module "dri2" already built-in
[ 16.595] (II) Loading sub module "exa"
[ 16.595] (II) LoadModule: "exa"
[ 16.595] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 16.595] (II) Module exa: vendor="X.Org Foundation"
[ 16.595] compiled for 1.18.4, module version = 2.6.0
[ 16.595] ABI class: X.Org Video Driver, version 20.0
[ 16.595] (II) RADEON(G0): KMS Color Tiling: enabled
[ 16.595] (II) RADEON(G0): KMS Color Tiling 2D: enabled
[ 16.595] (II) RADEON(G0): KMS Pageflipping: enabled
[ 16.595] (II) RADEON(G0): SwapBuffers wait for vsync: enabled
[ 16.629] (II) RADEON(G0): Output VGA-1-1 has no monitor section
[ 16.630] (II) RADEON(G0): Output HDMI-1-1 has no monitor section
[ 16.640] (II) RADEON(G0): Output DVI-1-1 has no monitor section
[ 16.676] (II) RADEON(G0): EDID for output VGA-1-1
[ 16.676] (II) RADEON(G0): Manufacturer: HWP Model: 26eb Serial#: 16843009
[ 16.676] (II) RADEON(G0): Year: 2009 Week: 32
[ 16.676] (II) RADEON(G0): EDID Version: 1.3
[ 16.676] (II) RADEON(G0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 16.676] (II) RADEON(G0): Sync: Separate
[ 16.676] (II) RADEON(G0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 16.676] (II) RADEON(G0): Gamma: 2.40
[ 16.676] (II) RADEON(G0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 16.676] (II) RADEON(G0): Default color space is primary color space
[ 16.676] (II) RADEON(G0): First detailed timing is preferred mode
[ 16.676] (II) RADEON(G0): redX: 0.639 redY: 0.342 greenX: 0.297 greenY: 0.614
[ 16.676] (II) RADEON(G0): blueX: 0.146 blueY: 0.067 whiteX: 0.312 whiteY: 0.328
[ 16.676] (II) RADEON(G0): Supported established timings:
[ 16.676] (II) RADEON(G0): 720x400@70Hz
[ 16.676] (II) RADEON(G0): 640x480@60Hz
[ 16.676] (II) RADEON(G0): 640x480@72Hz
[ 16.676] (II) RADEON(G0): 640x480@75Hz
[ 16.676] (II) RADEON(G0): 800x600@60Hz
[ 16.676] (II) RADEON(G0): 800x600@72Hz
[ 16.676] (II) RADEON(G0): 800x600@75Hz
[ 16.676] (II) RADEON(G0): 832x624@75Hz
[ 16.676] (II) RADEON(G0): 1024x768@60Hz
[ 16.676] (II) RADEON(G0): 1024x768@70Hz
[ 16.676] (II) RADEON(G0): 1024x768@75Hz
[ 16.676] (II) RADEON(G0): 1280x1024@75Hz
[ 16.676] (II) RADEON(G0): 1152x864@75Hz
[ 16.676] (II) RADEON(G0): Manufacturer's mask: 0
[ 16.676] (II) RADEON(G0): Supported standard timings:
[ 16.676] (II) RADEON(G0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.676] (II) RADEON(G0): Supported detailed timing:
[ 16.676] (II) RADEON(G0): clock: 108.0 MHz Image Size: 340 x 270 mm
[ 16.676] (II) RADEON(G0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 16.676] (II) RADEON(G0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 16.676] (II) RADEON(G0): Ranges: V min: 50 V max: 77 Hz, H min: 24 H max: 83 kHz, PixClock max 145 MHz
[ 16.676] (II) RADEON(G0): Monitor name: HP L1710
[ 16.676] (II) RADEON(G0): Serial No: CNC932QXW9
[ 16.676] (II) RADEON(G0): EDID (in hex):
[ 16.676] (II) RADEON(G0): 00ffffffffffff0022f0eb2601010101
[ 16.676] (II) RADEON(G0): 2013010368221b8ceea150a3574c9d25
[ 16.676] (II) RADEON(G0): 115054adef8081800101010101010101
[ 16.676] (II) RADEON(G0): 010101010101302a009851002a403070
[ 16.676] (II) RADEON(G0): 1300540e1100001e000000fd00324d18
[ 16.676] (II) RADEON(G0): 530e000a202020202020000000fc0048
[ 16.676] (II) RADEON(G0): 50204c313731300a20202020000000ff
[ 16.676] (II) RADEON(G0): 00434e43393332515857390a202000b9
[ 16.676] (II) RADEON(G0): Printing probed modes for output VGA-1-1
[ 16.676] (II) RADEON(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 16.676] (II) RADEON(G0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.676] (II) RADEON(G0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.677] (II) RADEON(G0): EDID for output HDMI-1-1
[ 16.688] (II) RADEON(G0): EDID for output DVI-1-1
[ 16.688] (II) RADEON(G0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 16.688] (II) RADEON(G0): mem size init: gart size :3fdde000 vram size: s:20000000 visible:1f6a1000
[ 16.688] (II) RADEON(G0): EXA: Driver will allow EXA pixmaps in VRAM
[ 16.688] (==) RADEON(G0): DPI set to (96, 96)
[ 16.688] (II) Loading sub module "ramdac"
[ 16.688] (II) LoadModule: "ramdac"
[ 16.688] (II) Module "ramdac" already built-in
[ 16.688] (II) UnloadModule: "modesetting"
[ 16.688] (II) Unloading modesetting
[ 16.688] (II) UnloadModule: "fbdev"
[ 16.688] (II) Unloading fbdev
[ 16.688] (II) UnloadSubModule: "fbdevhw"
[ 16.688] (II) Unloading fbdevhw
[ 16.688] (II) UnloadModule: "vesa"
[ 16.688] (II) Unloading vesa
[ 16.688] (--) Depth 24 pixmap format is 32 bpp
[ 16.693] (II) RADEON(G0): [DRI2] Setup complete
[ 16.693] (II) RADEON(G0): [DRI2] DRI driver: r600
[ 16.694] (II) RADEON(G0): [DRI2] VDPAU driver: r600
[ 16.694] (II) RADEON(G0): Front buffer size: 3072K
[ 16.694] (II) RADEON(G0): VRAM usage limit set to 460429K
[ 16.716] (==) RADEON(G0): DRI3 disabled
[ 16.716] (==) RADEON(G0): Backing store enabled
[ 16.716] (II) RADEON(G0): Direct rendering enabled
[ 16.716] (II) EXA(256): Driver allocated offscreen pixmaps
[ 16.716] (II) EXA(256): Driver registered support for the following operations:
[ 16.716] (II) Solid
[ 16.716] (II) Copy
[ 16.716] (II) Composite (RENDER acceleration)
[ 16.716] (II) UploadToScreen
[ 16.716] (II) DownloadFromScreen
[ 16.716] (II) RADEON(G0): Acceleration enabled
[ 16.716] (==) RADEON(G0): DPMS enabled
[ 16.717] (==) RADEON(G0): Silken mouse enabled
[ 16.723] (II) RADEON(G0): Set up textured video
[ 16.723] (II) RADEON(G0): [XvMC] Associated with Radeon Textured Video.
[ 16.723] (EE) RADEON(G0): [XvMC] Failed to initialize extension.
[ 16.723] (II) RADEON(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 16.733] (II) RADEON(0): [DRI2] Setup complete
[ 16.733] (II) RADEON(0): [DRI2] DRI driver: r600
[ 16.733] (II) RADEON(0): [DRI2] VDPAU driver: r600
[ 16.733] (II) RADEON(0): Front buffer size: 13600K
[ 16.733] (II) RADEON(0): VRAM usage limit set to 1863792K
[ 16.733] (==) RADEON(0): DRI3 disabled
[ 16.733] (==) RADEON(0): Backing store enabled
[ 16.733] (II) RADEON(0): Direct rendering enabled
[ 16.733] (II) EXA(0): Driver allocated offscreen pixmaps
[ 16.733] (II) EXA(0): Driver registered support for the following operations:
[ 16.733] (II) Solid
[ 16.733] (II) Copy
[ 16.733] (II) Composite (RENDER acceleration)
[ 16.733] (II) UploadToScreen
[ 16.733] (II) DownloadFromScreen
[ 16.741] (II) RADEON(0): Acceleration enabled
[ 16.741] (==) RADEON(0): DPMS enabled
[ 16.741] (==) RADEON(0): Silken mouse enabled
[ 16.741] (II) RADEON(0): Set up textured video
[ 16.741] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[ 16.741] (II) RADEON(0): [XvMC] Extension initialized.
[ 16.741] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 16.741] (--) RandR disabled
[ 16.758] (II) SELinux: Disabled on system
[ 18.761] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 18.761] (II) AIGLX: enabled GLX_ARB_create_context
[ 18.761] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 18.761] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 18.761] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 18.761] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 18.761] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 18.761] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 18.761] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 18.761] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 18.761] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 18.763] (II) AIGLX: Loaded and initialized r600
[ 18.763] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 18.764] (II) RADEON(0): Setting screen physical size to 846 x 285
[ 19.020] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 19.020] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 19.020] (II) LoadModule: "evdev"
[ 19.021] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.050] (II) Module evdev: vendor="X.Org Foundation"
[ 19.050] compiled for 1.18.1, module version = 2.10.1
[ 19.050] Module class: X.Org XInput Driver
[ 19.050] ABI class: X.Org XInput driver, version 22.1
[ 19.050] (II) Using input driver 'evdev' for 'Power Button'
[ 19.050] (**) Power Button: always reports core events
[ 19.050] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 19.050] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 19.050] (--) evdev: Power Button: Found keys
[ 19.050] (II) evdev: Power Button: Configuring as keyboard
[ 19.050] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 19.050] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 19.050] (**) Option "xkb_rules" "evdev"
[ 19.050] (**) Option "xkb_model" "pc105"
[ 19.050] (**) Option "xkb_layout" "us,ru"
[ 19.050] (**) Option "xkb_variant" ","
[ 19.050] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 19.076] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 19.076] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 19.076] (II) Using input driver 'evdev' for 'Power Button'
[ 19.076] (**) Power Button: always reports core events
[ 19.076] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 19.076] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 19.076] (--) evdev: Power Button: Found keys
[ 19.076] (II) evdev: Power Button: Configuring as keyboard
[ 19.076] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 19.076] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 19.076] (**) Option "xkb_rules" "evdev"
[ 19.076] (**) Option "xkb_model" "pc105"
[ 19.076] (**) Option "xkb_layout" "us,ru"
[ 19.076] (**) Option "xkb_variant" ","
[ 19.076] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 19.077] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event5)
[ 19.077] (II) No input driver specified, ignoring this device.
[ 19.077] (II) This device may have been added with another device file.
[ 19.078] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event4)
[ 19.078] (II) No input driver specified, ignoring this device.
[ 19.078] (II) This device may have been added with another device file.
[ 19.079] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event2)
[ 19.079] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[ 19.079] (II) Using input driver 'evdev' for 'MOSART Semi. 2.4G Keyboard Mouse'
[ 19.079] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[ 19.079] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: Device: "/dev/input/event2"
[ 19.079] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Vendor 0x62a Product 0x4101
[ 19.079] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found keys
[ 19.079] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as keyboard
[ 19.079] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:062A:4101.0001/input/input5/event2"
[ 19.079] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 8)
[ 19.079] (**) Option "xkb_rules" "evdev"
[ 19.079] (**) Option "xkb_model" "pc105"
[ 19.079] (**) Option "xkb_layout" "us,ru"
[ 19.079] (**) Option "xkb_variant" ","
[ 19.079] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 19.080] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event3)
[ 19.080] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[ 19.080] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[ 19.080] (II) Using input driver 'evdev' for 'MOSART Semi. 2.4G Keyboard Mouse'
[ 19.080] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[ 19.080] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: Device: "/dev/input/event3"
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Vendor 0x62a Product 0x4101
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found 9 mouse buttons
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found scroll wheel(s)
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found relative axes
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found x and y relative axes
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found absolute axes
[ 19.080] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Forcing absolute x/y axes to exist.
[ 19.080] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found keys
[ 19.080] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as mouse
[ 19.080] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as keyboard
[ 19.080] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Adding scrollwheel support
[ 19.080] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: YAxisMapping: buttons 4 and 5
[ 19.080] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 19.080] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:062A:4101.0002/input/input6/event3"
[ 19.080] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 9)
[ 19.080] (**) Option "xkb_rules" "evdev"
[ 19.080] (**) Option "xkb_model" "pc105"
[ 19.080] (**) Option "xkb_layout" "us,ru"
[ 19.080] (**) Option "xkb_variant" ","
[ 19.080] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 19.081] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: initialized for relative axes.
[ 19.081] (WW) evdev: MOSART Semi. 2.4G Keyboard Mouse: ignoring absolute axes.
[ 19.081] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) keeping acceleration scheme 1
[ 19.081] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration profile 0
[ 19.081] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration factor: 2.000
[ 19.081] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration threshold: 4
[ 19.082] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/mouse0)
[ 19.082] (II) No input driver specified, ignoring this device.
[ 19.082] (II) This device may have been added with another device file.
[ 19.082] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event7)
[ 19.082] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event8)
[ 19.083] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event9)
[ 19.083] (II) No input driver specified, ignoring this device.
[ 19.083] (II) This device may have been added with another device file.
[ 19.083] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event10)
[ 19.084] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event11)
[ 19.084] (II) No input driver specified, ignoring this device.
[ 19.084] (II) This device may have been added with another device file.
[ 19.084] (II) config/udev: Adding input device HDA Intel Line Out Side (/dev/input/event12)
[ 19.084] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event13)
[ 19.084] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event6)
[ 31.663] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 31.663] (II) RADEON(0): Using EDID range info for horizontal sync
[ 31.663] (II) RADEON(0): Using EDID range info for vertical refresh
[ 31.663] (II) RADEON(0): Printing DDC gathered Modelines:
[ 31.663] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 31.663] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 31.663] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 31.663] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 31.663] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 31.663] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 31.663] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 31.663] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 31.663] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 31.663] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 31.663] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 31.663] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 31.663] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 31.663] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 31.786] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 31.786] (II) RADEON(0): Using hsync ranges from config file
[ 31.786] (II) RADEON(0): Using vrefresh ranges from config file
[ 31.786] (II) RADEON(0): Printing DDC gathered Modelines:
[ 31.786] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 31.786] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 31.786] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 31.786] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 31.786] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 31.786] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 31.786] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 31.786] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 31.786] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 31.786] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 31.786] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 31.786] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 31.786] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 31.786] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 36.737] (II) RADEON(0): Allocate new frame buffer 4488x1080 stride 4544
[ 36.739] (II) RADEON(0): VRAM usage limit set to 1858651K
[ 36.795] (II) RADEON(G0): Allocate new frame buffer 1280x1024 stride 1280
[ 36.798] (II) RADEON(G0): VRAM usage limit set to 458586K
[ 37.266] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 37.266] (II) RADEON(0): Using hsync ranges from config file
[ 37.266] (II) RADEON(0): Using vrefresh ranges from config file
[ 37.266] (II) RADEON(0): Printing DDC gathered Modelines:
[ 37.266] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 37.266] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 37.266] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 37.266] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 37.266] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 37.266] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 37.267] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 37.267] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 37.267] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 37.267] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 37.267] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 37.267] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 37.267] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 37.267] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 37.390] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 37.390] (II) RADEON(0): Using hsync ranges from config file
[ 37.390] (II) RADEON(0): Using vrefresh ranges from config file
[ 37.390] (II) RADEON(0): Printing DDC gathered Modelines:
[ 37.390] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 37.390] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 37.390] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 37.390] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 37.390] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 37.390] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 37.390] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 37.390] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 37.390] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 37.390] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 37.390] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 37.390] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 37.390] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 37.390] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.716] (II) Copy
[ 16.733] (II) Copy
а, вот с запущенным демоном самбы, моник не работает:
[ 15.765] (--) Log file renamed from "/var/log/Xorg.pid-1207.log" to "/var/log/Xorg.0.log"
[ 15.785]
[ 15.785] X Protocol Version 11, Revision 0
[ 15.785] Build Operating System: Linux 4.4.0-45-generic x86_64 Ubuntu
[ 15.785] Current Operating System: Linux io-serena 4.4.0-53-generic #74-Ubuntu SMP Fri Dec 2 15:59:10 UTC 2016 x86_64
[ 15.785] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-53-generic root=UUID=31afcf19-4a79-4b0e-a194-58d1bedbe8ba ro quiet splash vt.handoff=7
[ 15.785] Build Date: 02 November 2016 10:06:10PM
[ 15.785] xorg-server 2:1.18.4-0ubuntu0.2 (For technical support please see http://www.ubuntu.com/support)
[ 15.785] Current version of pixman: 0.33.6
[ 15.785] Before reporting problems, check http://wiki.x.org
[ 15.785] Markers: (--) probed, (**) from config file, (==) default setting,
[ 15.785] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb 22 15:28:06 2017
[ 15.812] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 15.856] (==) No Layout section. Using the first Screen section.
[ 15.856] (==) No screen section available. Using defaults.
[ 15.856] (**) |-->Screen "Default Screen Section" (0)
[ 15.856] (**) | |-->Monitor "<default monitor>"
[ 15.857] (==) No monitor specified for screen "Default Screen Section".
[ 15.857] (==) Automatically adding devices
[ 15.857] (==) Automatically enabling devices
[ 15.857] (==) Automatically adding GPU devices
[ 15.857] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 15.944] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 15.944] Entry deleted from font path.
[ 15.944] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 15.944] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 15.959] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 15.959] Entry deleted from font path.
[ 15.959] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 15.959] (==) FontPath set to:
built-ins
[ 15.959] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 15.959] (II) The server relies on udev to provide the list of input devices.
[ 15.967] (II) Loader magic: 0x55845ec3adc0
[ 15.967] (II) Module ABI versions:
[ 15.967] X.Org ANSI C Emulation: 0.4
[ 15.967] X.Org Video Driver: 20.0
[ 15.967] X.Org XInput driver : 22.1
[ 15.967] X.Org Server Extension : 9.0
[ 15.967] (++) using VT number 7
[ 15.967] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 15.968] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 15.968] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 15.968] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
[ 15.968] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[ 15.970] (--) PCI:*(0:3:0:0) 1002:68da:174b:1621 rev 0, Mem @ 0xc0000000/268435456, 0xfbbc0000/131072, I/O @ 0x0000b000/256, BIOS @ 0x????????/131072
[ 15.970] (--) PCI: (0:4:0:0) 1002:9540:1458:21ae rev 0, Mem @ 0xd0000000/268435456, 0xfbce0000/65536, I/O @ 0x0000c000/256, BIOS @ 0x????????/131072
[ 15.970] (II) LoadModule: "glx"
[ 15.991] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 16.177] (II) Module glx: vendor="X.Org Foundation"
[ 16.177] compiled for 1.18.4, module version = 1.0.0
[ 16.177] ABI class: X.Org Server Extension, version 9.0
[ 16.177] (==) AIGLX enabled
[ 16.177] (==) Matched ati as autoconfigured driver 0
[ 16.177] (==) Matched ati as autoconfigured driver 1
[ 16.177] (==) Matched modesetting as autoconfigured driver 2
[ 16.177] (==) Matched fbdev as autoconfigured driver 3
[ 16.177] (==) Matched vesa as autoconfigured driver 4
[ 16.177] (==) Assigned the driver to the xf86ConfigLayout
[ 16.177] (II) LoadModule: "ati"
[ 16.198] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[ 16.214] (II) Module ati: vendor="X.Org Foundation"
[ 16.214] compiled for 1.18.3, module version = 7.7.0
[ 16.214] Module class: X.Org Video Driver
[ 16.214] ABI class: X.Org Video Driver, version 20.0
[ 16.214] (II) LoadModule: "radeon"
[ 16.214] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[ 16.250] (II) Module radeon: vendor="X.Org Foundation"
[ 16.250] compiled for 1.18.3, module version = 7.7.0
[ 16.250] Module class: X.Org Video Driver
[ 16.250] ABI class: X.Org Video Driver, version 20.0
[ 16.250] (II) LoadModule: "modesetting"
[ 16.250] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 16.252] (II) Module modesetting: vendor="X.Org Foundation"
[ 16.252] compiled for 1.18.4, module version = 1.18.4
[ 16.252] Module class: X.Org Video Driver
[ 16.252] ABI class: X.Org Video Driver, version 20.0
[ 16.252] (II) LoadModule: "fbdev"
[ 16.252] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 16.270] (II) Module fbdev: vendor="X.Org Foundation"
[ 16.270] compiled for 1.18.1, module version = 0.4.4
[ 16.270] (II) LoadModule: "vesa"
[ 16.270] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 16.271] (II) Module vesa: vendor="X.Org Foundation"
[ 16.271] compiled for 1.18.1, module version = 2.3.4
[ 16.271] Module class: X.Org Video Driver
[ 16.271] ABI class: X.Org Video Driver, version 20.0
[ 16.271] (II) RADEON: Driver for ATI Radeon chipsets:
[ 16.300] (II) [KMS] Kernel modesetting enabled.
[ 16.300] (WW) Falling back to old probe method for modesetting
[ 16.300] (WW) Falling back to old probe method for fbdev
[ 16.300] (II) Loading sub module "fbdevhw"
[ 16.300] (II) LoadModule: "fbdevhw"
[ 16.300] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 16.311] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 16.311] compiled for 1.18.4, module version = 0.0.2
[ 16.311] ABI class: X.Org Video Driver, version 20.0
[ 16.311] (WW) Falling back to old probe method for vesa
[ 16.312] (II) RADEON(0): Creating default Display subsection in Screen section
[ 16.312] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[ 16.312] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 16.312] (==) RADEON(0): Default visual is TrueColor
[ 16.312] (==) RADEON(0): RGB weight 888
[ 16.312] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[ 16.312] (--) RADEON(0): Chipset: "ATI Radeon HD 5500 Series" (ChipID = 0x68da)
[ 16.312] (II) Loading sub module "fb"
[ 16.312] (II) LoadModule: "fb"
[ 16.312] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 16.352] (II) Module fb: vendor="X.Org Foundation"
[ 16.352] compiled for 1.18.4, module version = 1.0.0
[ 16.352] ABI class: X.Org ANSI C Emulation, version 0.4
[ 16.352] (II) Loading sub module "dri2"
[ 16.352] (II) LoadModule: "dri2"
[ 16.352] (II) Module "dri2" already built-in
[ 16.352] (II) Loading sub module "exa"
[ 16.352] (II) LoadModule: "exa"
[ 16.352] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 16.385] (II) Module exa: vendor="X.Org Foundation"
[ 16.385] compiled for 1.18.4, module version = 2.6.0
[ 16.385] ABI class: X.Org Video Driver, version 20.0
[ 16.385] (II) RADEON(0): KMS Color Tiling: enabled
[ 16.385] (II) RADEON(0): KMS Color Tiling 2D: enabled
[ 16.385] (II) RADEON(0): KMS Pageflipping: enabled
[ 16.385] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[ 16.448] (II) RADEON(0): Output HDMI-0 has no monitor section
[ 16.479] (II) RADEON(0): Output DVI-0 has no monitor section
[ 16.512] (II) RADEON(0): Output VGA-0 has no monitor section
[ 16.576] (II) RADEON(0): EDID for output HDMI-0
[ 15.785]
X.Org X Server 1.18.4
Release Date: 2016-07-19
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
Mint 18.1 и 2 карты radeon
и, продолжение:
[ 16.607] (II) RADEON(0): EDID for output DVI-0
[ 16.607] (II) RADEON(0): Manufacturer: BNQ Model: 783f Serial#: 21573
[ 16.607] (II) RADEON(0): Year: 2010 Week: 3
[ 16.608] (II) RADEON(0): EDID Version: 1.3
[ 16.608] (II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
[ 16.608] (II) RADEON(0): Sync: Separate Composite SyncOnGreen
[ 16.608] (II) RADEON(0): Max Image Size [cm]: horiz.: 53 vert.: 30
[ 16.608] (II) RADEON(0): Gamma: 2.20
[ 16.608] (II) RADEON(0): DPMS capabilities: Off; RGB/Color Display
[ 16.608] (II) RADEON(0): Default color space is primary color space
[ 16.608] (II) RADEON(0): First detailed timing is preferred mode
[ 16.608] (II) RADEON(0): redX: 0.649 redY: 0.338 greenX: 0.289 greenY: 0.609
[ 16.608] (II) RADEON(0): blueX: 0.146 blueY: 0.070 whiteX: 0.312 whiteY: 0.329
[ 16.608] (II) RADEON(0): Supported established timings:
[ 16.608] (II) RADEON(0): 720x400@70Hz
[ 16.608] (II) RADEON(0): 640x480@60Hz
[ 16.608] (II) RADEON(0): 640x480@75Hz
[ 16.608] (II) RADEON(0): 800x600@60Hz
[ 16.608] (II) RADEON(0): 800x600@75Hz
[ 16.608] (II) RADEON(0): 832x624@75Hz
[ 16.608] (II) RADEON(0): 1024x768@60Hz
[ 16.608] (II) RADEON(0): 1024x768@75Hz
[ 16.608] (II) RADEON(0): 1280x1024@75Hz
[ 16.608] (II) RADEON(0): 1152x864@75Hz
[ 16.608] (II) RADEON(0): Manufacturer's mask: 0
[ 16.608] (II) RADEON(0): Supported standard timings:
[ 16.608] (II) RADEON(0): #0: hsize: 1152 vsize 720 refresh: 60 vid: 113
[ 16.608] (II) RADEON(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 16.608] (II) RADEON(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 16.608] (II) RADEON(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.608] (II) RADEON(0): #4: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 16.608] (II) RADEON(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 16.608] (II) RADEON(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 16.608] (II) RADEON(0): Supported detailed timing:
[ 16.608] (II) RADEON(0): clock: 148.5 MHz Image Size: 531 x 299 mm
[ 16.608] (II) RADEON(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 16.608] (II) RADEON(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 16.608] (II) RADEON(0): Serial No: Y1A06749SL0
[ 16.608] (II) RADEON(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 83 kHz, PixClock max 175 MHz
[ 16.608] (II) RADEON(0): Monitor name: BenQ G2420HD
[ 16.608] (II) RADEON(0): EDID (in hex):
[ 16.608] (II) RADEON(0): 00ffffffffffff0009d13f7845540000
[ 16.608] (II) RADEON(0): 031401030e351e782e6081a6564a9c25
[ 16.608] (II) RADEON(0): 125054a56b80710081c081408180a9c0
[ 16.608] (II) RADEON(0): b300d1c00101023a801871382d40582c
[ 16.608] (II) RADEON(0): 4500132b2100001a000000ff00593141
[ 16.608] (II) RADEON(0): 3036373439534c300a20000000fd0032
[ 16.608] (II) RADEON(0): 4c185311000a202020202020000000fc
[ 16.608] (II) RADEON(0): 0042656e5120473234323048440a0088
[ 16.608] (II) RADEON(0): Printing probed modes for output DVI-0
[ 16.608] (II) RADEON(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync -vsync (67.5 kHz eP)
[ 16.608] (II) RADEON(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1152x720"x60.0 67.28 1152 1208 1328 1504 720 721 724 746 -hsync +vsync (44.7 kHz)
[ 16.608] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 16.608] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.608] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.608] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.608] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.608] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.608] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.608] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.640] (II) RADEON(0): EDID for output VGA-0
[ 16.640] (II) RADEON(0): Manufacturer: HWP Model: 26eb Serial#: 16843009
[ 16.640] (II) RADEON(0): Year: 2009 Week: 26
[ 16.640] (II) RADEON(0): EDID Version: 1.3
[ 16.640] (II) RADEON(0): Analog Display Input, Input Voltage Level: 0.700/0.700 V
[ 16.640] (II) RADEON(0): Sync: Separate
[ 16.640] (II) RADEON(0): Max Image Size [cm]: horiz.: 34 vert.: 27
[ 16.640] (II) RADEON(0): Gamma: 2.40
[ 16.640] (II) RADEON(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
[ 16.640] (II) RADEON(0): Default color space is primary color space
[ 16.640] (II) RADEON(0): First detailed timing is preferred mode
[ 16.640] (II) RADEON(0): redX: 0.639 redY: 0.342 greenX: 0.297 greenY: 0.614
[ 16.640] (II) RADEON(0): blueX: 0.146 blueY: 0.067 whiteX: 0.312 whiteY: 0.328
[ 16.640] (II) RADEON(0): Supported established timings:
[ 16.640] (II) RADEON(0): 720x400@70Hz
[ 16.640] (II) RADEON(0): 640x480@60Hz
[ 16.640] (II) RADEON(0): 640x480@72Hz
[ 16.640] (II) RADEON(0): 640x480@75Hz
[ 16.640] (II) RADEON(0): 800x600@60Hz
[ 16.640] (II) RADEON(0): 800x600@72Hz
[ 16.640] (II) RADEON(0): 800x600@75Hz
[ 16.640] (II) RADEON(0): 832x624@75Hz
[ 16.640] (II) RADEON(0): 1024x768@60Hz
[ 16.640] (II) RADEON(0): 1024x768@70Hz
[ 16.640] (II) RADEON(0): 1024x768@75Hz
[ 16.640] (II) RADEON(0): 1280x1024@75Hz
[ 16.640] (II) RADEON(0): 1152x864@75Hz
[ 16.640] (II) RADEON(0): Manufacturer's mask: 0
[ 16.640] (II) RADEON(0): Supported standard timings:
[ 16.640] (II) RADEON(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 16.640] (II) RADEON(0): Supported detailed timing:
[ 16.640] (II) RADEON(0): clock: 108.0 MHz Image Size: 340 x 270 mm
[ 16.640] (II) RADEON(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
[ 16.640] (II) RADEON(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
[ 16.640] (II) RADEON(0): Ranges: V min: 50 V max: 77 Hz, H min: 24 H max: 83 kHz, PixClock max 145 MHz
[ 16.640] (II) RADEON(0): Monitor name: HP L1710
[ 16.640] (II) RADEON(0): Serial No: CNC926PGYG
[ 16.640] (II) RADEON(0): EDID (in hex):
[ 16.640] (II) RADEON(0): 00ffffffffffff0022f0eb2601010101
[ 16.640] (II) RADEON(0): 1a13010368221b8ceea150a3574c9d25
[ 16.640] (II) RADEON(0): 115054adef8081800101010101010101
[ 16.640] (II) RADEON(0): 010101010101302a009851002a403070
[ 16.640] (II) RADEON(0): 1300540e1100001e000000fd00324d18
[ 16.640] (II) RADEON(0): 530e000a202020202020000000fc0048
[ 16.640] (II) RADEON(0): 50204c313731300a20202020000000ff
[ 16.640] (II) RADEON(0): 00434e43393236504759470a202000be
[ 16.640] (II) RADEON(0): Printing probed modes for output VGA-0
[ 16.640] (II) RADEON(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 16.640] (II) RADEON(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 16.640] (II) RADEON(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.640] (II) RADEON(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 16.641] (II) RADEON(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 16.641] (II) RADEON(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 16.641] (II) RADEON(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 16.641] (II) RADEON(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 16.641] (II) RADEON(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 16.641] (II) RADEON(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 16.641] (II) RADEON(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 16.641] (II) RADEON(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 16.641] (II) RADEON(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 16.641] (II) RADEON(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 16.641] (II) RADEON(0): Output HDMI-0 disconnected
[ 16.641] (II) RADEON(0): Output DVI-0 connected
[ 16.641] (II) RADEON(0): Output VGA-0 connected
[ 16.641] (II) RADEON(0): Using spanning desktop for initial modes
[ 16.641] (II) RADEON(0): Output DVI-0 using initial mode 1920x1080 +0+0
[ 16.641] (II) RADEON(0): Output VGA-0 using initial mode 1280x1024 +1920+0
[ 16.641] (II) RADEON(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 16.641] (II) RADEON(0): mem size init: gart size :3fdde000 vram size: s:80000000 visible:7f3b8000
[ 16.641] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[ 16.641] (==) RADEON(0): DPI set to (96, 96)
[ 16.641] (II) Loading sub module "ramdac"
[ 16.641] (II) LoadModule: "ramdac"
[ 16.641] (II) Module "ramdac" already built-in
[ 16.641] (II) UnloadModule: "modesetting"
[ 16.641] (II) Unloading modesetting
[ 16.641] (II) UnloadModule: "fbdev"
[ 16.641] (II) Unloading fbdev
[ 16.641] (II) UnloadSubModule: "fbdevhw"
[ 16.641] (II) Unloading fbdevhw
[ 16.641] (II) UnloadModule: "vesa"
[ 16.641] (II) Unloading vesa
[ 16.641] (--) Depth 24 pixmap format is 32 bpp
[ 16.642] (II) RADEON(0): [DRI2] Setup complete
[ 16.642] (II) RADEON(0): [DRI2] DRI driver: r600
[ 16.642] (II) RADEON(0): [DRI2] VDPAU driver: r600
[ 16.643] (II) RADEON(0): Front buffer size: 13600K
[ 16.643] (II) RADEON(0): VRAM usage limit set to 1863792K
[ 16.665] (==) RADEON(0): DRI3 disabled
[ 16.665] (==) RADEON(0): Backing store enabled
[ 16.665] (II) RADEON(0): Direct rendering enabled
[ 16.665] (II) EXA(0): Driver allocated offscreen pixmaps
[ 16.665] (II) EXA(0): Driver registered support for the following operations:
[ 16.665] (II) Solid
[ 16.665] (II) Copy
[ 16.665] (II) Composite (RENDER acceleration)
[ 16.665] (II) UploadToScreen
[ 16.665] (II) DownloadFromScreen
[ 16.698] (II) RADEON(0): Acceleration enabled
[ 16.698] (==) RADEON(0): DPMS enabled
[ 16.698] (==) RADEON(0): Silken mouse enabled
[ 16.709] (II) RADEON(0): Set up textured video
[ 16.709] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[ 16.709] (II) RADEON(0): [XvMC] Extension initialized.
[ 16.709] (II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 16.723] (--) RandR disabled
[ 16.736] (II) SELinux: Disabled on system
[ 18.606] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 18.606] (II) AIGLX: enabled GLX_ARB_create_context
[ 18.606] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 18.606] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 18.606] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 18.606] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 18.606] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 18.606] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 18.606] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 18.606] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 18.606] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 18.607] (II) AIGLX: Loaded and initialized r600
[ 18.607] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 18.608] (II) RADEON(0): Setting screen physical size to 846 x 285
[ 18.852] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 18.852] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 18.852] (II) LoadModule: "evdev"
[ 18.852] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 18.882] (II) Module evdev: vendor="X.Org Foundation"
[ 18.882] compiled for 1.18.1, module version = 2.10.1
[ 18.882] Module class: X.Org XInput Driver
[ 18.882] ABI class: X.Org XInput driver, version 22.1
[ 18.882] (II) Using input driver 'evdev' for 'Power Button'
[ 18.882] (**) Power Button: always reports core events
[ 18.882] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 18.882] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 18.882] (--) evdev: Power Button: Found keys
[ 18.882] (II) evdev: Power Button: Configuring as keyboard
[ 18.882] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 18.882] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 18.882] (**) Option "xkb_rules" "evdev"
[ 18.882] (**) Option "xkb_model" "pc105"
[ 18.882] (**) Option "xkb_layout" "us,ru"
[ 18.882] (**) Option "xkb_variant" ","
[ 18.882] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 18.911] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 18.911] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 18.911] (II) Using input driver 'evdev' for 'Power Button'
[ 18.911] (**) Power Button: always reports core events
[ 18.911] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 18.911] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 18.911] (--) evdev: Power Button: Found keys
[ 18.911] (II) evdev: Power Button: Configuring as keyboard
[ 18.911] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 18.911] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 18.911] (**) Option "xkb_rules" "evdev"
[ 18.911] (**) Option "xkb_model" "pc105"
[ 18.911] (**) Option "xkb_layout" "us,ru"
[ 18.911] (**) Option "xkb_variant" ","
[ 18.911] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 18.913] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event5)
[ 18.913] (II) No input driver specified, ignoring this device.
[ 18.913] (II) This device may have been added with another device file.
[ 18.913] (II) config/udev: Adding drm device (/dev/dri/card1)
[ 18.913] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 18.913] (EE) /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
[ 18.913] (II) config/udev: Ignoring already known drm device (/dev/dri/card1)
[ 18.913] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event4)
[ 18.914] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event2)
[ 18.914] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[ 18.914] (II) Using input driver 'evdev' for 'MOSART Semi. 2.4G Keyboard Mouse'
[ 18.914] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[ 18.914] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: Device: "/dev/input/event2"
[ 18.914] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Vendor 0x62a Product 0x4101
[ 18.914] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found keys
[ 18.914] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as keyboard
[ 18.914] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:062A:4101.0001/input/input5/event2"
[ 18.914] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 8)
[ 18.914] (**) Option "xkb_rules" "evdev"
[ 18.914] (**) Option "xkb_model" "pc105"
[ 18.914] (**) Option "xkb_layout" "us,ru"
[ 18.914] (**) Option "xkb_variant" ","
[ 18.914] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 18.915] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/event3)
[ 18.915] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[ 18.915] (**) MOSART Semi. 2.4G Keyboard Mouse: Applying InputClass "evdev keyboard catchall"
[ 18.915] (II) Using input driver 'evdev' for 'MOSART Semi. 2.4G Keyboard Mouse'
[ 18.915] (**) MOSART Semi. 2.4G Keyboard Mouse: always reports core events
[ 18.915] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: Device: "/dev/input/event3"
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Vendor 0x62a Product 0x4101
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found 9 mouse buttons
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found scroll wheel(s)
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found relative axes
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found x and y relative axes
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found absolute axes
[ 18.915] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Forcing absolute x/y axes to exist.
[ 18.915] (--) evdev: MOSART Semi. 2.4G Keyboard Mouse: Found keys
[ 18.915] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as mouse
[ 18.915] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Configuring as keyboard
[ 18.915] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: Adding scrollwheel support
[ 18.915] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: YAxisMapping: buttons 4 and 5
[ 18.915] (**) evdev: MOSART Semi. 2.4G Keyboard Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 18.915] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:062A:4101.0002/input/input6/event3"
[ 18.915] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Keyboard Mouse" (type: KEYBOARD, id 9)
[ 18.915] (**) Option "xkb_rules" "evdev"
[ 18.916] (**) Option "xkb_model" "pc105"
[ 18.916] (**) Option "xkb_layout" "us,ru"
[ 18.916] (**) Option "xkb_variant" ","
[ 18.916] (**) Option "xkb_options" "grp:alt_shift_toggle,grp_led:scroll"
[ 18.916] (II) evdev: MOSART Semi. 2.4G Keyboard Mouse: initialized for relative axes.
[ 18.916] (WW) evdev: MOSART Semi. 2.4G Keyboard Mouse: ignoring absolute axes.
[ 18.916] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) keeping acceleration scheme 1
[ 18.916] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration profile 0
[ 18.916] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration factor: 2.000
[ 18.916] (**) MOSART Semi. 2.4G Keyboard Mouse: (accel) acceleration threshold: 4
[ 18.917] (II) config/udev: Adding input device MOSART Semi. 2.4G Keyboard Mouse (/dev/input/mouse0)
[ 18.917] (II) No input driver specified, ignoring this device.
[ 18.917] (II) This device may have been added with another device file.
[ 18.917] (II) config/udev: Adding input device HDA Intel Rear Mic (/dev/input/event7)
[ 18.917] (II) config/udev: Adding input device HDA Intel Line (/dev/input/event8)
[ 18.918] (II) config/udev: Adding input device HDA Intel Line Out Front (/dev/input/event9)
[ 18.918] (II) No input driver specified, ignoring this device.
[ 18.918] (II) This device may have been added with another device file.
[ 18.918] (II) config/udev: Adding input device HDA Intel Line Out Surround (/dev/input/event10)
[ 18.919] (II) config/udev: Adding input device HDA Intel Line Out CLFE (/dev/input/event11)
[ 18.919] (II) No input driver specified, ignoring this device.
[ 18.919] (II) This device may have been added with another device file.
[ 18.919] (II) config/udev: Adding input device HDA Intel Line Out Side (/dev/input/event12)
[ 18.919] (II) config/udev: Adding input device HDA Intel Front Headphone (/dev/input/event13)
[ 18.920] (II) config/udev: Adding input device HDA Intel Front Mic (/dev/input/event6)
[ 18.920] (II) No input driver specified, ignoring this device.
[ 18.920] (II) This device may have been added with another device file.
[ 29.414] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 29.414] (II) RADEON(0): Using EDID range info for horizontal sync
[ 29.414] (II) RADEON(0): Using EDID range info for vertical refresh
[ 29.414] (II) RADEON(0): Printing DDC gathered Modelines:
[ 29.414] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 29.414] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 29.414] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 29.414] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 29.414] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 29.414] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 29.414] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 29.414] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 29.414] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 29.414] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 29.414] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 29.414] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 29.414] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 29.414] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 36.754] (II) RADEON(0): EDID vendor "HWP", prod id 9963
[ 36.754] (II) RADEON(0): Using hsync ranges from config file
[ 36.754] (II) RADEON(0): Using vrefresh ranges from config file
[ 36.754] (II) RADEON(0): Printing DDC gathered Modelines:
[ 36.754] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[ 36.754] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 36.754] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 36.754] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 36.754] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 36.754] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 36.754] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 36.754] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 36.754] (II) RADEON(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 36.754] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 36.754] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 36.754] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 36.754] (II) RADEON(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 36.754] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 16.665] (II) Copy
karrik, во втором /dev/dri/card1: failed to set DRM interface version 1.4: Permission denied
А в первом вроде бы нет... Это если мне не показалось.
Но потом config/udev: Ignoring already known drm device (/dev/dri/card1)
Я правильно понял, что card0 это та, на которой как раз висят два монитора, а card1 это та на которой висит не рабочий монитор?
Не могу сказать, что это за зверь - гугл выдает, что это проблема обычно бамблби и двух гпу на ноутбуках.
Покажите еще dmesg все, что связано с VGA, или все, что связано с ошибками во время "плохого" варианта загрузки.
И есть еще одна мысль... Попробуйте загрузится без самбы и тимфьювера, перейти в консоль, остановить kdm, выполнить Xorg -configure, а потом sudo mv xorg.conf /etc/X11/xorg.conf и перезапустить уже с самбой и фьювером
SemenSinchenko, верно - card0=2 монитора, card1=1 монитор.
Дело в том, что у меня ни бамблби, ни вгасвитчероо нет; в ядро вгасвитчероо встроен, но файл настроек не появляется, бамблби вообще не нашел...
кстати, а тут есть возможность приложить текстовый файл?
dmesg
dmesg
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-64-generic (buildd@lgw01-56) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 (Ubuntu 4.4.0-64.85-generic 4.4.44)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-64-generic root=UUID=1675ecfa-ad11-4c18-8d91-693fb9ccccfe ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] x86/fpu: Using 'lazy' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4c00-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bf77ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf780000-0x00000000bf797fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bf798000-0x00000000bf7dbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf7dc000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000005bfffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/P6X58D-E, BIOS 0303 05/25/2010
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x5c0000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E3FFF write-protect
[ 0.000000] E4000-EBFFF write-through
[ 0.000000] EC000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 5C0000000 mask FC0000000 uncachable
[ 0.000000] 1 base 000000000 mask C00000000 write-back
[ 0.000000] 2 base 400000000 mask E00000000 write-back
[ 0.000000] 3 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 4 base 0BF800000 mask FFF800000 uncachable
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 23GB, range: 1GB, type UC
[ 0.000000] reg 1, base: 0GB, range: 16GB, type WB
[ 0.000000] reg 2, base: 16GB, range: 8GB, type WB
[ 0.000000] reg 3, base: 3GB, range: 1GB, type UC
[ 0.000000] reg 4, base: 3064MB, range: 8MB, type UC
[ 0.000000] total RAM covered: 22520M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 2G num_reg: 7 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 4GB, type WB
[ 0.000000] reg 1, base: 3064MB, range: 8MB, type UC
[ 0.000000] reg 2, base: 3GB, range: 1GB, type UC
[ 0.000000] reg 3, base: 4GB, range: 4GB, type WB
[ 0.000000] reg 4, base: 8GB, range: 8GB, type WB
[ 0.000000] reg 5, base: 16GB, range: 8GB, type WB
[ 0.000000] reg 6, base: 23GB, range: 1GB, type UC
[ 0.000000] e820: update [mem 0xbf800000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xbf780 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[ 0.000000] BRK [0x0220c000, 0x0220cfff] PGTABLE
[ 0.000000] BRK [0x0220d000, 0x0220dfff] PGTABLE
[ 0.000000] BRK [0x0220e000, 0x0220efff] PGTABLE
[ 0.000000] BRK [0x0220f000, 0x0220ffff] PGTABLE
[ 0.000000] BRK [0x02210000, 0x02210fff] PGTABLE
[ 0.000000] BRK [0x02211000, 0x02211fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x33310000-0x3597ffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FBA30 000014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 0x00000000BF780000 000044 (v01 052510 RSDT1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x00000000BF780200 000084 (v01 052510 FACP1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x00000000BF7804B0 00B384 (v01 A1631 A1631001 00000001 INTL 20060113)
[ 0.000000] ACPI: FACS 0x00000000BF798000 000040
[ 0.000000] ACPI: APIC 0x00000000BF780390 0000D8 (v01 052510 APIC1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x00000000BF780470 00003C (v01 052510 OEMMCFG 20100525 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x00000000BF798040 000072 (v01 052510 OEMB1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000BF78F4B0 000038 (v01 052510 OEMHPET 20100525 MSFT 00000097)
[ 0.000000] ACPI: ASPT 0x00000000BF798360 000034 (v06 052510 PerfTune 20100525 MSFT 00000097)
[ 0.000000] ACPI: OSFR 0x00000000BF78F4F0 0000B0 (v01 052510 OEMOSFR 20100525 MSFT 00000097)
[ 0.000000] ACPI: SSDT 0x00000000BF79A1C0 000363 (v01 DpgPmm CpuPm 00000012 INTL 20060113)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x00000005bfffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x5bffe8000-0x5bffecfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000005bfffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000bf77ffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000005bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000005bfffffff]
[ 0.000000] On node 0 totalpages: 5764894
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 12190 pages used for memmap
[ 0.000000] DMA32 zone: 780160 pages, LIFO batch:31
[ 0.000000] Normal zone: 77824 pages used for memmap
[ 0.000000] Normal zone: 4980736 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 9, version 32, address 0xfec8a000, GSI 24-47
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] smpboot: Allowing 16 CPUs, 8 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e4fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e5000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf780000-0xbf797fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf798000-0xbf7dbfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf7dc000-0xbfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc0000000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffdfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffe00000-0xffffffff]
[ 0.000000] e820: [mem 0xc0000000-0xfedfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:16 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 33 pages/cpu @ffff8805a9200000 s98264 r8192 d28712 u262144
[ 0.000000] pcpu-alloc: s98264 r8192 d28712 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 5674795
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-64-generic root=UUID=1675ecfa-ad11-4c18-8d91-693fb9ccccfe ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 22572668K/23059576K available (8452K kernel code, 1293K rwdata, 3980K rodata, 1488K init, 1316K bss, 486908K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=16.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=16
[ 0.000000] NR_IRQS:33024 nr_irqs:960 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2806.553 MHz processor
[ 0.000033] Calibrating delay loop (skipped), value calculated using timer frequency.. 5613.10 BogoMIPS (lpj=11226212)
[ 0.000036] pid_max: default: 32768 minimum: 301
[ 0.000043] ACPI: Core revision 20150930
[ 0.007848] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.007873] Security Framework initialized
[ 0.007875] Yama: becoming mindful.
[ 0.007897] AppArmor: AppArmor initialized
[ 0.009992] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.016862] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.019823] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.019860] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.020253] Initializing cgroup subsys io
[ 0.020257] Initializing cgroup subsys memory
[ 0.020266] Initializing cgroup subsys devices
[ 0.020269] Initializing cgroup subsys freezer
[ 0.020272] Initializing cgroup subsys net_cls
[ 0.020274] Initializing cgroup subsys perf_event
[ 0.020277] Initializing cgroup subsys net_prio
[ 0.020282] Initializing cgroup subsys hugetlb
[ 0.020284] Initializing cgroup subsys pids
[ 0.020305] CPU: Physical Processor ID: 0
[ 0.020306] CPU: Processor Core ID: 0
[ 0.020311] mce: CPU supports 9 MCE banks
[ 0.020325] CPU0: Thermal monitoring enabled (TM1)
[ 0.020333] process: using mwait in idle threads
[ 0.020337] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[ 0.020338] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.020640] Freeing SMP alternatives memory: 32K (ffffffff820b9000 - ffffffff820c1000)
[ 0.071529] ftrace: allocating 32123 entries in 126 pages
[ 0.086093] smpboot: APIC(0) Converting physical 0 to logical package 0
[ 0.086095] smpboot: Max logical packages: 4
[ 0.086099] DMAR-IR: This system BIOS has enabled interrupt remapping
on a chipset that contains an erratum making that
feature unstable. To maintain system stability
interrupt remapping is being disabled. Please
contact your BIOS vendor for an update
[ 0.086104] Switched APIC routing to physical flat.
[ 0.086654] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.234069] smpboot: CPU0: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (family: 0x6, model: 0x1a, stepping: 0x5)
[ 0.234087] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver.
[ 0.234103] core: CPU erratum AAJ80 worked around
[ 0.234104] core: CPUID marked event: 'bus cycles' unavailable
[ 0.234107] ... version: 3
[ 0.234108] ... bit width: 48
[ 0.234109] ... generic registers: 4
[ 0.234110] ... value mask: 0000ffffffffffff
[ 0.234111] ... max period: 000000007fffffff
[ 0.234112] ... fixed-purpose events: 3
[ 0.234113] ... event mask: 000000070000000f
[ 0.235019] x86: Booting SMP configuration:
[ 0.235021] .... node #0, CPUs: #1
[ 0.237800] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.237901] #2 #3 #4 #5 #6 #7
[ 0.252529] x86: Booted up 1 node, 8 CPUs
[ 0.252533] smpboot: Total of 8 processors activated (44904.84 BogoMIPS)
[ 0.258918] devtmpfs: initialized
[ 0.263952] evm: security.selinux
[ 0.263953] evm: security.SMACK64
[ 0.263954] evm: security.SMACK64EXEC
[ 0.263955] evm: security.SMACK64TRANSMUTE
[ 0.263956] evm: security.SMACK64MMAP
[ 0.263956] evm: security.ima
[ 0.263957] evm: security.capability
[ 0.264018] PM: Registering ACPI NVS region [mem 0xbf798000-0xbf7dbfff] (278528 bytes)
[ 0.264102] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.264183] pinctrl core: initialized pinctrl subsystem
[ 0.264288] RTC time: 14:56:06, date: 02/22/17
[ 0.264392] NET: Registered protocol family 16
[ 0.274072] cpuidle: using governor ladder
[ 0.286067] cpuidle: using governor menu
[ 0.286072] PCCT header not found.
[ 0.286160] ACPI: bus type PCI registered
[ 0.286162] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.286225] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.286227] PCI: not using MMCONFIG
[ 0.286229] PCI: Using configuration type 1 for base access
[ 0.298448] ACPI: Added _OSI(Module Device)
[ 0.298450] ACPI: Added _OSI(Processor Device)
[ 0.298451] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.298452] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.299971] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.330362] ACPI: Dynamic OEM Table Load:
[ 0.330374] ACPI: SSDT 0xFFFF8805A8D1E000 001E1C (v01 DpgPmm P001Ist 00000011 INTL 20060113)
[ 0.330949] ACPI: Interpreter enabled
[ 0.330968] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.330969] ACPI: Using IOAPIC for interrupt routing
[ 0.330998] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.331808] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.331812] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[ 0.332268] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.337307] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.337312] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.337316] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.337548] PCI host bridge to bus 0000:00
[ 0.337551] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.337552] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.337554] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.337556] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.337557] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
[ 0.337559] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed8ffff window]
[ 0.337560] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.337571] pci 0000:00:00.0: [8086:3405] type 00 class 0x060000
[ 0.337627] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 0.337706] pci 0000:00:01.0: [8086:3408] type 01 class 0x060400
[ 0.337760] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.337807] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.337843] pci 0000:00:02.0: [8086:3409] type 01 class 0x060400
[ 0.337894] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.337939] pci 0000:00:02.0: System wakeup disabled by ACPI
[ 0.337973] pci 0000:00:03.0: [8086:340a] type 01 class 0x060400
[ 0.338026] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.338078] pci 0000:00:03.0: System wakeup disabled by ACPI
[ 0.338114] pci 0000:00:07.0: [8086:340e] type 01 class 0x060400
[ 0.338168] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.338214] pci 0000:00:07.0: System wakeup disabled by ACPI
[ 0.338253] pci 0000:00:14.0: [8086:342e] type 00 class 0x080000
[ 0.338358] pci 0000:00:14.1: [8086:3422] type 00 class 0x080000
[ 0.338461] pci 0000:00:14.2: [8086:3423] type 00 class 0x080000
[ 0.338561] pci 0000:00:14.3: [8086:3438] type 00 class 0x080000
[ 0.338657] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
[ 0.338701] pci 0000:00:1a.0: reg 0x20: [io 0x9800-0x981f]
[ 0.338778] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.338815] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
[ 0.338858] pci 0000:00:1a.1: reg 0x20: [io 0x9880-0x989f]
[ 0.338935] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.338969] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300
[ 0.339012] pci 0000:00:1a.2: reg 0x20: [io 0x9c00-0x9c1f]
[ 0.339089] pci 0000:00:1a.2: System wakeup disabled by ACPI
[ 0.339129] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
[ 0.339156] pci 0000:00:1a.7: reg 0x10: [mem 0xfb8ff000-0xfb8ff3ff]
[ 0.339224] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.339266] pci 0000:00:1a.7: System wakeup disabled by ACPI
[ 0.339302] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300
[ 0.339327] pci 0000:00:1b.0: reg 0x10: [mem 0xfb8f8000-0xfb8fbfff 64bit]
[ 0.339384] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.339456] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400
[ 0.339521] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.339565] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.339600] pci 0000:00:1c.2: [8086:3a44] type 01 class 0x060400
[ 0.339665] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.339709] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.339746] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
[ 0.339789] pci 0000:00:1d.0: reg 0x20: [io 0x9080-0x909f]
[ 0.339866] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.339900] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
[ 0.339944] pci 0000:00:1d.1: reg 0x20: [io 0x9400-0x941f]
[ 0.340020] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.340055] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
[ 0.340098] pci 0000:00:1d.2: reg 0x20: [io 0x9480-0x949f]
[ 0.340173] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.340214] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
[ 0.340241] pci 0000:00:1d.7: reg 0x10: [mem 0xfb8fe000-0xfb8fe3ff]
[ 0.340309] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.340351] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.340384] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.340463] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.340498] pci 0000:00:1f.0: [8086:3a16] type 00 class 0x060100
[ 0.340578] pci 0000:00:1f.0: can't claim BAR 13 [io 0x0800-0x087f]: address conflict with ACPI CPU throttle [io 0x0810-0x0815]
[ 0.340582] pci 0000:00:1f.0: quirk: [io 0x0500-0x053f] claimed by ICH6 GPIO
[ 0.340585] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.340670] pci 0000:00:1f.2: [8086:3a20] type 00 class 0x01018f
[ 0.340689] pci 0000:00:1f.2: reg 0x10: [io 0x8000-0x8007]
[ 0.340696] pci 0000:00:1f.2: reg 0x14: [io 0x7c00-0x7c03]
[ 0.340703] pci 0000:00:1f.2: reg 0x18: [io 0x7880-0x7887]
[ 0.340709] pci 0000:00:1f.2: reg 0x1c: [io 0x7800-0x7803]
[ 0.340716] pci 0000:00:1f.2: reg 0x20: [io 0x7480-0x748f]
[ 0.340723] pci 0000:00:1f.2: reg 0x24: [io 0x7400-0x740f]
[ 0.340808] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500
[ 0.340824] pci 0000:00:1f.3: reg 0x10: [mem 0xfb8fd000-0xfb8fd0ff 64bit]
[ 0.340842] pci 0000:00:1f.3: reg 0x20: [io 0x1000-0x101f]
[ 0.340920] pci 0000:00:1f.5: [8086:3a26] type 00 class 0x010185
[ 0.340939] pci 0000:00:1f.5: reg 0x10: [io 0x9000-0x9007]
[ 0.340946] pci 0000:00:1f.5: reg 0x14: [io 0x8c00-0x8c03]
[ 0.340953] pci 0000:00:1f.5: reg 0x18: [io 0x8880-0x8887]
[ 0.340960] pci 0000:00:1f.5: reg 0x1c: [io 0x8800-0x8803]
[ 0.340966] pci 0000:00:1f.5: reg 0x20: [io 0x8480-0x848f]
[ 0.340973] pci 0000:00:1f.5: reg 0x24: [io 0x8400-0x840f]
[ 0.341098] pci 0000:01:00.0: [1b4b:91a3] type 00 class 0x01018f
[ 0.341117] pci 0000:01:00.0: reg 0x10: [io 0xac00-0xac07]
[ 0.341124] pci 0000:01:00.0: reg 0x14: [io 0xa880-0xa883]
[ 0.341131] pci 0000:01:00.0: reg 0x18: [io 0xa800-0xa807]
[ 0.341137] pci 0000:01:00.0: reg 0x1c: [io 0xa480-0xa483]
[ 0.341144] pci 0000:01:00.0: reg 0x20: [io 0xa400-0xa40f]
[ 0.341151] pci 0000:01:00.0: reg 0x24: [mem 0xfb9ff800-0xfb9fffff]
[ 0.341158] pci 0000:01:00.0: reg 0x30: [mem 0xfb9e0000-0xfb9effff pref]
[ 0.341183] pci 0000:01:00.0: PME# supported from D3hot
[ 0.346088] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.346093] pci 0000:00:01.0: bridge window [io 0xa000-0xafff]
[ 0.346097] pci 0000:00:01.0: bridge window [mem 0xfb900000-0xfb9fffff]
[ 0.346167] pci 0000:02:00.0: [1033:0194] type 00 class 0x0c0330
[ 0.346197] pci 0000:02:00.0: reg 0x10: [mem 0xfbafe000-0xfbafffff 64bit]
[ 0.346267] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.354087] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.354094] pci 0000:00:02.0: bridge window [mem 0xfba00000-0xfbafffff]
[ 0.354159] pci 0000:03:00.0: [1002:68da] type 00 class 0x030000
[ 0.354182] pci 0000:03:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.354191] pci 0000:03:00.0: reg 0x18: [mem 0xfbbc0000-0xfbbdffff 64bit]
[ 0.354198] pci 0000:03:00.0: reg 0x20: [io 0xb000-0xb0ff]
[ 0.354209] pci 0000:03:00.0: reg 0x30: [mem 0xfbba0000-0xfbbbffff pref]
[ 0.354236] pci 0000:03:00.0: supports D1 D2
[ 0.354280] pci 0000:03:00.1: [1002:aa60] type 00 class 0x040300
[ 0.354302] pci 0000:03:00.1: reg 0x10: [mem 0xfbbfc000-0xfbbfffff 64bit]
[ 0.354352] pci 0000:03:00.1: supports D1 D2
[ 0.362089] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.362094] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff]
[ 0.362098] pci 0000:00:03.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 0.362104] pci 0000:00:03.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.362168] pci 0000:04:00.0: [1002:9540] type 00 class 0x030000
[ 0.362194] pci 0000:04:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.362204] pci 0000:04:00.0: reg 0x18: [mem 0xfbce0000-0xfbceffff 64bit]
[ 0.362210] pci 0000:04:00.0: reg 0x20: [io 0xc000-0xc0ff]
[ 0.362220] pci 0000:04:00.0: reg 0x30: [mem 0xfbcc0000-0xfbcdffff pref]
[ 0.362248] pci 0000:04:00.0: supports D1 D2
[ 0.362292] pci 0000:04:00.1: [1002:aa38] type 00 class 0x040300
[ 0.362319] pci 0000:04:00.1: reg 0x10: [mem 0xfbcfc000-0xfbcfffff 64bit]
[ 0.362377] pci 0000:04:00.1: supports D1 D2
[ 0.370092] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.370097] pci 0000:00:07.0: bridge window [io 0xc000-0xcfff]
[ 0.370102] pci 0000:00:07.0: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 0.370107] pci 0000:00:07.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.370166] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.370174] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.370226] pci 0000:05:00.0: [11ab:4364] type 00 class 0x020000
[ 0.370268] pci 0000:05:00.0: reg 0x10: [mem 0xfbdfc000-0xfbdfffff 64bit]
[ 0.370279] pci 0000:05:00.0: reg 0x18: [io 0xd800-0xd8ff]
[ 0.370319] pci 0000:05:00.0: reg 0x30: [mem 0xfbdc0000-0xfbddffff pref]
[ 0.370365] pci 0000:05:00.0: supports D1 D2
[ 0.370366] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.378098] pci 0000:00:1c.2: PCI bridge to [bus 05]
[ 0.378103] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.378108] pci 0000:00:1c.2: bridge window [mem 0xfbd00000-0xfbdfffff]
[ 0.378169] pci 0000:07:02.0: [1106:3044] type 00 class 0x0c0010
[ 0.378191] pci 0000:07:02.0: reg 0x10: [mem 0xfbeff000-0xfbeff7ff]
[ 0.378200] pci 0000:07:02.0: reg 0x14: [io 0xec00-0xec7f]
[ 0.378260] pci 0000:07:02.0: supports D2
[ 0.378262] pci 0000:07:02.0: PME# supported from D2 D3hot D3cold
[ 0.378328] pci 0000:00:1e.0: PCI bridge to [bus 07] (subtractive decode)
[ 0.378331] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.378334] pci 0000:00:1e.0: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.378339] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.378341] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.378342] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.378344] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.378345] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff window] (subtractive decode)
[ 0.378347] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff window] (subtractive decode)
[ 0.378869] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 11 12 14 *15)
[ 0.378914] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 *11 12 14 15)
[ 0.378957] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.379000] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 6 7 10 11 12 14 15)
[ 0.379043] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 *14 15)
[ 0.379086] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 *7 10 11 12 14 15)
[ 0.379129] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 *4 6 7 10 11 12 14 15)
[ 0.379172] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.379222] ACPI: Enabled 3 GPEs in block 00 to 3F
[ 0.379347] vgaarb: setting as boot device: PCI:0000:03:00.0
[ 0.379349] vgaarb: device added: PCI:0000:03:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.379352] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=none,locks=none
[ 0.379353] vgaarb: loaded
[ 0.379354] vgaarb: bridge control possible 0000:04:00.0
[ 0.379355] vgaarb: bridge control possible 0000:03:00.0
[ 0.379558] SCSI subsystem initialized
[ 0.379604] libata version 3.00 loaded.
[ 0.379625] ACPI: bus type USB registered
[ 0.379638] usbcore: registered new interface driver usbfs
[ 0.379646] usbcore: registered new interface driver hub
[ 0.379667] usbcore: registered new device driver usb
[ 0.379789] PCI: Using ACPI for IRQ routing
[ 0.385418] PCI: Discovered peer bus ff
[ 0.385419] PCI: root bus ff: using default resources
[ 0.385420] PCI: Probing PCI hardware (bus ff)
[ 0.385445] ACPI: \: failed to evaluate _DSM (0x1001)
[ 0.385446] PCI host bridge to bus 0000:ff
[ 0.385448] pci_bus 0000:ff: root bus resource [io 0x0000-0xffff]
[ 0.385449] pci_bus 0000:ff: root bus resource [mem 0x00000000-0xfffffffff]
[ 0.385451] pci_bus 0000:ff: No busn resource found for root bus, will use [bus ff-ff]
[ 0.385453] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.385458] pci 0000:ff:00.0: [8086:2c41] type 00 class 0x060000
[ 0.385498] pci 0000:ff:00.1: [8086:2c01] type 00 class 0x060000
[ 0.385538] pci 0000:ff:02.0: [8086:2c10] type 00 class 0x060000
[ 0.385575] pci 0000:ff:02.1: [8086:2c11] type 00 class 0x060000
[ 0.385612] pci 0000:ff:03.0: [8086:2c18] type 00 class 0x060000
[ 0.385648] pci 0000:ff:03.1: [8086:2c19] type 00 class 0x060000
[ 0.385684] pci 0000:ff:03.4: [8086:2c1c] type 00 class 0x060000
[ 0.385720] pci 0000:ff:04.0: [8086:2c20] type 00 class 0x060000
[ 0.385756] pci 0000:ff:04.1: [8086:2c21] type 00 class 0x060000
[ 0.385793] pci 0000:ff:04.2: [8086:2c22] type 00 class 0x060000
[ 0.385829] pci 0000:ff:04.3: [8086:2c23] type 00 class 0x060000
[ 0.385866] pci 0000:ff:05.0: [8086:2c28] type 00 class 0x060000
[ 0.385902] pci 0000:ff:05.1: [8086:2c29] type 00 class 0x060000
[ 0.385938] pci 0000:ff:05.2: [8086:2c2a] type 00 class 0x060000
[ 0.385974] pci 0000:ff:05.3: [8086:2c2b] type 00 class 0x060000
[ 0.386012] pci 0000:ff:06.0: [8086:2c30] type 00 class 0x060000
[ 0.386048] pci 0000:ff:06.1: [8086:2c31] type 00 class 0x060000
[ 0.386087] pci 0000:ff:06.2: [8086:2c32] type 00 class 0x060000
[ 0.386124] pci 0000:ff:06.3: [8086:2c33] type 00 class 0x060000
[ 0.386170] pci_bus 0000:ff: busn_res: [bus ff] end is updated to ff
[ 0.386172] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.386178] PCI: pci_cache_line_size set to 64 bytes
[ 0.386256] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.386258] e820: reserve RAM buffer [mem 0xbf780000-0xbfffffff]
[ 0.386364] NetLabel: Initializing
[ 0.386365] NetLabel: domain hash size = 128
[ 0.386366] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.386376] NetLabel: unlabeled traffic allowed by default
[ 0.386441] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.386445] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.386448] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.389636] amd_nb: Cannot enumerate AMD northbridges
[ 0.389656] clocksource: Switched to clocksource hpet
[ 0.395270] AppArmor: AppArmor Filesystem Enabled
[ 0.395331] pnp: PnP ACPI init
[ 0.395409] system 00:00: [mem 0xfbf00000-0xfbffffff] has been reserved
[ 0.395411] system 00:00: [mem 0xfc000000-0xfcffffff] has been reserved
[ 0.395413] system 00:00: [mem 0xfd000000-0xfdffffff] has been reserved
[ 0.395415] system 00:00: [mem 0xfe000000-0xfebfffff] has been reserved
[ 0.395417] system 00:00: [mem 0xfec8a000-0xfec8afff] could not be reserved
[ 0.395419] system 00:00: [mem 0xfed10000-0xfed10fff] has been reserved
[ 0.395422] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.395483] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.395646] system 00:02: [io 0x0290-0x029f] has been reserved
[ 0.395650] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.395831] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.395834] system 00:03: [io 0x0800-0x087f] could not be reserved
[ 0.395835] system 00:03: [io 0x0500-0x057f] could not be reserved
[ 0.395837] system 00:03: [io 0x0600-0x0607] has been reserved
[ 0.395839] system 00:03: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.395841] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.395843] system 00:03: [mem 0xfed40000-0xfed8ffff] has been reserved
[ 0.395845] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.395945] system 00:04: [mem 0xffc00000-0xffdfffff] has been reserved
[ 0.395948] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.396042] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.396045] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.396047] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.396133] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.396136] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.396273] system 00:07: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.396275] system 00:07: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.396277] system 00:07: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.396278] system 00:07: [mem 0x00100000-0xbfffffff] could not be reserved
[ 0.396280] system 00:07: [mem 0xfed90000-0xffffffff] could not be reserved
[ 0.396283] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.396382] pnp: PnP ACPI: found 8 devices
[ 0.402474] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.402508] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 06] add_size 1000
[ 0.402511] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 06] add_size 400000 add_align 100000
[ 0.402518] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[ 0.402531] pci 0000:00:1f.0: BAR 13: [io size 0x0080] has bogus alignment
[ 0.402534] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 400000 min_align 100000
[ 0.402535] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x004fffff] res_to_dev_res add_size 400000 min_align 100000
[ 0.402537] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.402539] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.402541] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.402543] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.402547] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0000000-0xf03fffff]
[ 0.402551] pci 0000:00:1c.2: BAR 15: assigned [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.402553] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.402556] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.402558] pci 0000:00:01.0: bridge window [io 0xa000-0xafff]
[ 0.402562] pci 0000:00:01.0: bridge window [mem 0xfb900000-0xfb9fffff]
[ 0.402567] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.402571] pci 0000:00:02.0: bridge window [mem 0xfba00000-0xfbafffff]
[ 0.402577] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.402579] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff]
[ 0.402582] pci 0000:00:03.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 0.402585] pci 0000:00:03.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.402589] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.402591] pci 0000:00:07.0: bridge window [io 0xc000-0xcfff]
[ 0.402595] pci 0000:00:07.0: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 0.402597] pci 0000:00:07.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.402602] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.402604] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.402608] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf03fffff]
[ 0.402611] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.402616] pci 0000:00:1c.2: PCI bridge to [bus 05]
[ 0.402618] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.402622] pci 0000:00:1c.2: bridge window [mem 0xfbd00000-0xfbdfffff]
[ 0.402625] pci 0000:00:1c.2: bridge window [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.402630] pci 0000:00:1e.0: PCI bridge to [bus 07]
[ 0.402632] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.402636] pci 0000:00:1e.0: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.402643] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.402645] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.402646] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.402648] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.402649] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.402651] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff window]
[ 0.402653] pci_bus 0000:01: resource 0 [io 0xa000-0xafff]
[ 0.402654] pci_bus 0000:01: resource 1 [mem 0xfb900000-0xfb9fffff]
[ 0.402656] pci_bus 0000:02: resource 1 [mem 0xfba00000-0xfbafffff]
[ 0.402657] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff]
[ 0.402659] pci_bus 0000:03: resource 1 [mem 0xfbb00000-0xfbbfffff]
[ 0.402660] pci_bus 0000:03: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.402662] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 0.402663] pci_bus 0000:04: resource 1 [mem 0xfbc00000-0xfbcfffff]
[ 0.402665] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.402666] pci_bus 0000:06: resource 0 [io 0x2000-0x2fff]
[ 0.402668] pci_bus 0000:06: resource 1 [mem 0xf0000000-0xf03fffff]
[ 0.402669] pci_bus 0000:06: resource 2 [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.402671] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.402672] pci_bus 0000:05: resource 1 [mem 0xfbd00000-0xfbdfffff]
[ 0.402674] pci_bus 0000:05: resource 2 [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.402675] pci_bus 0000:07: resource 0 [io 0xe000-0xefff]
[ 0.402677] pci_bus 0000:07: resource 1 [mem 0xfbe00000-0xfbefffff]
[ 0.402678] pci_bus 0000:07: resource 4 [io 0x0000-0x0cf7 window]
[ 0.402680] pci_bus 0000:07: resource 5 [io 0x0d00-0xffff window]
[ 0.402681] pci_bus 0000:07: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.402683] pci_bus 0000:07: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.402684] pci_bus 0000:07: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.402686] pci_bus 0000:07: resource 9 [mem 0xf0000000-0xfed8ffff window]
[ 0.402689] pci_bus 0000:ff: resource 4 [io 0x0000-0xffff]
[ 0.402691] pci_bus 0000:ff: resource 5 [mem 0x00000000-0xfffffffff]
[ 0.402723] NET: Registered protocol family 2
[ 0.402945] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.403380] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.403550] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.403594] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.403700] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.403838] NET: Registered protocol family 1
[ 0.405318] pci 0000:03:00.0: Video device with shadowed ROM
[ 0.405349] PCI: CLS 256 bytes, default 64
[ 0.405392] Trying to unpack rootfs image as initramfs...
[ 0.993440] Freeing initrd memory: 39360K (ffff880033310000 - ffff880035980000)
[ 0.993464] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.993467] software IO TLB [mem 0xbb780000-0xbf780000] (64MB) mapped at [ffff8800bb780000-ffff8800bf77ffff]
[ 0.993682] Scanning for low memory corruption every 60 seconds
[ 0.994151] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.994208] audit: initializing netlink subsys (disabled)
[ 0.994226] audit: type=2000 audit(1487775366.840:1): initialized
[ 0.994549] Initialise system trusted keyring
[ 0.994653] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.995993] zbud: loaded
[ 0.996171] VFS: Disk quotas dquot_6.6.0
[ 0.996207] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.996451] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.996662] fuse init (API version 7.23)
[ 0.996783] Key type big_key registered
[ 0.996796] Allocating IMA MOK and blacklist keyrings.
[ 0.997132] Key type asymmetric registered
[ 0.997135] Asymmetric key parser 'x509' registered
[ 0.997171] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.997202] io scheduler noop registered
[ 0.997205] io scheduler deadline registered (default)
[ 0.997234] io scheduler cfq registered
[ 0.997463] pcieport 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.997875] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.997881] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.997909] vesafb: mode is 1400x1050x32, linelength=5632, pages=0
[ 0.997910] vesafb: scrolling: redraw
[ 0.997912] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 0.997931] vesafb: framebuffer at 0xc0000000, mapped to 0xffffc90003800000, using 5824k, total 5824k
[ 0.998024] Console: switching to colour frame buffer device 175x65
[ 0.998058] fb0: VESA VGA frame buffer device
[ 0.998073] intel_idle: MWAIT substates: 0x1120
[ 0.998083] intel_idle: v0.4.1 model 0x1A
Mint 18.1 и 2 карты radeon
[ 0.998084] intel_idle: lapic_timer_reliable_states 0x2
[ 0.998391] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.998395] ACPI: Power Button [PWRB]
[ 0.998427] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.998429] ACPI: Power Button [PWRF]
[ 0.998666] GHES: HEST is not enabled!
[ 0.998747] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 1.000096] Linux agpgart interface v0.103
[ 1.003272] brd: module loaded
[ 1.004677] loop: module loaded
[ 1.004796] ata_piix 0000:00:1f.2: version 2.13
[ 1.004899] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.005881] scsi host0: ata_piix
[ 1.006216] scsi host1: ata_piix
[ 1.006257] ata1: SATA max UDMA/133 cmd 0x8000 ctl 0x7c00 bmdma 0x7480 irq 20
[ 1.006262] ata2: SATA max UDMA/133 cmd 0x7880 ctl 0x7800 bmdma 0x7488 irq 20
[ 1.006373] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.007247] scsi host2: ata_piix
[ 1.007541] scsi host3: ata_piix
[ 1.007605] ata3: SATA max UDMA/133 cmd 0x9000 ctl 0x8c00 bmdma 0x8480 irq 20
[ 1.007609] ata4: SATA max UDMA/133 cmd 0x8880 ctl 0x8800 bmdma 0x8488 irq 20
[ 1.007748] libphy: Fixed MDIO Bus: probed
[ 1.007753] tun: Universal TUN/TAP device driver, 1.6
[ 1.007755] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.007835] PPP generic driver version 2.4.2
[ 1.007945] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.007952] ehci-pci: EHCI PCI platform driver
[ 1.008081] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.008086] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.008097] ehci-pci 0000:00:1a.7: debug port 1
[ 1.012002] ehci-pci 0000:00:1a.7: cache line size of 256 is not supported
[ 1.012013] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfb8ff000
[ 1.021891] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.021950] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.021952] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.021954] usb usb1: Product: EHCI Host Controller
[ 1.021956] usb usb1: Manufacturer: Linux 4.4.0-64-generic ehci_hcd
[ 1.021957] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.022229] hub 1-0:1.0: USB hub found
[ 1.022242] hub 1-0:1.0: 6 ports detected
[ 1.022493] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.022499] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 1.022509] ehci-pci 0000:00:1d.7: debug port 1
[ 1.026406] ehci-pci 0000:00:1d.7: cache line size of 256 is not supported
[ 1.026415] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfb8fe000
[ 1.037884] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.037934] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.037940] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.037941] usb usb2: Product: EHCI Host Controller
[ 1.037943] usb usb2: Manufacturer: Linux 4.4.0-64-generic ehci_hcd
[ 1.037944] usb usb2: SerialNumber: 0000:00:1d.7
[ 1.038204] hub 2-0:1.0: USB hub found
[ 1.038216] hub 2-0:1.0: 6 ports detected
[ 1.038359] ehci-platform: EHCI generic platform driver
[ 1.038368] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.038372] ohci-pci: OHCI PCI platform driver
[ 1.038383] ohci-platform: OHCI generic platform driver
[ 1.038390] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.038499] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.038504] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.038509] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.038531] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00009800
[ 1.038567] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.038569] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.038571] usb usb3: Product: UHCI Host Controller
[ 1.038572] usb usb3: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.038573] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.038836] hub 3-0:1.0: USB hub found
[ 1.038848] hub 3-0:1.0: 2 ports detected
[ 1.039036] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.039041] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.039046] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.039068] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00009880
[ 1.039105] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.039106] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.039108] usb usb4: Product: UHCI Host Controller
[ 1.039109] usb usb4: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.039111] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.039375] hub 4-0:1.0: USB hub found
[ 1.039389] hub 4-0:1.0: 2 ports detected
[ 1.039581] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.039587] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 1.039592] uhci_hcd 0000:00:1a.2: detected 2 ports
[ 1.039614] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00009c00
[ 1.039649] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.039651] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.039653] usb usb5: Product: UHCI Host Controller
[ 1.039654] usb usb5: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.039655] usb usb5: SerialNumber: 0000:00:1a.2
[ 1.039925] hub 5-0:1.0: USB hub found
[ 1.039937] hub 5-0:1.0: 2 ports detected
[ 1.040126] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.040131] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.040137] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.040153] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00009080
[ 1.040190] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.040192] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040193] usb usb6: Product: UHCI Host Controller
[ 1.040194] usb usb6: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.040196] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.040452] hub 6-0:1.0: USB hub found
[ 1.040464] hub 6-0:1.0: 2 ports detected
[ 1.040654] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.040659] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.040666] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.040683] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00009400
[ 1.040718] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.040720] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.040722] usb usb7: Product: UHCI Host Controller
[ 1.040723] usb usb7: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.040724] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.040956] hub 7-0:1.0: USB hub found
[ 1.040968] hub 7-0:1.0: 2 ports detected
[ 1.041159] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.041164] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.041169] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.041188] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00009480
[ 1.041224] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.041225] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041227] usb usb8: Product: UHCI Host Controller
[ 1.041228] usb usb8: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.041230] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.041423] hub 8-0:1.0: USB hub found
[ 1.041434] hub 8-0:1.0: 2 ports detected
[ 1.041588] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.041593] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 9
[ 1.041765] xhci_hcd 0000:02:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x00000004
[ 1.041905] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.041907] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.041908] usb usb9: Product: xHCI Host Controller
[ 1.041910] usb usb9: Manufacturer: Linux 4.4.0-64-generic xhci-hcd
[ 1.041911] usb usb9: SerialNumber: 0000:02:00.0
[ 1.042176] hub 9-0:1.0: USB hub found
[ 1.042190] hub 9-0:1.0: 2 ports detected
[ 1.042284] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.042287] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 10
[ 1.045134] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.045149] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.045150] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.045152] usb usb10: Product: xHCI Host Controller
[ 1.045153] usb usb10: Manufacturer: Linux 4.4.0-64-generic xhci-hcd
[ 1.045155] usb usb10: SerialNumber: 0000:02:00.0
[ 1.045437] hub 10-0:1.0: USB hub found
[ 1.045453] hub 10-0:1.0: 2 ports detected
[ 1.045587] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.048015] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.048019] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.048301] mousedev: PS/2 mouse device common for all mice
[ 1.048658] rtc_cmos 00:01: RTC can wake from S4
[ 1.048920] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.048952] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.048966] i2c /dev entries driver
[ 1.049039] device-mapper: uevent: version 1.0.3
[ 1.049262] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.049302] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.049731] NET: Registered protocol family 10
[ 1.050214] NET: Registered protocol family 17
[ 1.050228] Key type dns_resolver registered
[ 1.050739] microcode: CPU0 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050774] microcode: CPU1 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050810] microcode: CPU2 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050818] microcode: CPU3 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050888] microcode: CPU4 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050956] microcode: CPU5 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050970] microcode: CPU6 sig=0x106a5, pf=0x2, revision=0xf
[ 1.050983] microcode: CPU7 sig=0x106a5, pf=0x2, revision=0xf
[ 1.051122] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.051658] registered taskstats version 1
[ 1.051681] Loading compiled-in X.509 certificates
[ 1.052595] Loaded X.509 cert 'Build time autogenerated kernel key: 11f495fa9f4186f263f5fd144a167c99990e2f12'
[ 1.052617] zswap: loaded using pool lzo/zbud
[ 1.055047] Key type trusted registered
[ 1.059107] Key type encrypted registered
[ 1.059117] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.059122] ima: No TPM chip found, activating TPM-bypass!
[ 1.059156] evm: HMAC attrs: 0x1
[ 1.059749] Magic number: 5:5:941
[ 1.060061] rtc_cmos 00:01: setting system clock to 2017-02-22 14:56:07 UTC (1487775367)
[ 1.062311] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.062312] EDD information not available.
[ 1.062351] PM: Hibernation image not present or could not be loaded.
[ 1.333671] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.336497] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.347301] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.615117] usb 1-1: New USB device found, idVendor=048d, idProduct=1336
[ 1.615121] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.615124] usb 1-1: Product: Mass Storage Device
[ 1.615127] usb 1-1: Manufacturer: Generic
[ 1.615129] usb 1-1: SerialNumber: 00000000000006
[ 1.656418] ata2.00: SATA link down (SStatus 0 SControl 300)
[ 1.656431] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 1.801694] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.801710] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.818172] ata1.00: ATA-9: ST2000DM001-1ER164, CC25, max UDMA/133
[ 1.818177] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.818377] ata1.01: ATA-9: WDC WD20EZRX-00D8PB0, 80.00A80, max UDMA/133
[ 1.818381] ata1.01: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.834146] ata1.00: configured for UDMA/133
[ 1.842082] ata1.01: configured for UDMA/133
[ 1.842559] scsi 0:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
[ 1.843099] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.843103] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.843107] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.843525] sd 0:0:0:0: [sda] Write Protect is off
[ 1.843531] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.843677] scsi 0:0:1:0: Direct-Access ATA WDC WD20EZRX-00D 0A80 PQ: 0 ANSI: 5
[ 1.843723] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.844086] sd 0:0:1:0: Attached scsi generic sg1 type 0
[ 1.844153] sd 0:0:1:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.844158] sd 0:0:1:0: [sdb] 4096-byte physical blocks
[ 1.844250] sd 0:0:1:0: [sdb] Write Protect is off
[ 1.844252] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.844264] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.858217] sda: sda1 sda2 sda3
[ 1.883509] sdb: sdb1
[ 1.883978] sd 0:0:1:0: [sdb] Attached SCSI disk
[ 1.884189] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.886416] Freeing unused kernel memory: 1488K (ffffffff81f45000 - ffffffff820b9000)
[ 1.886417] Write protecting the kernel read-only data: 14336k
[ 1.887412] Freeing unused kernel memory: 1776K (ffff880001844000 - ffff880001a00000)
[ 1.887874] Freeing unused kernel memory: 116K (ffff880001de3000 - ffff880001e00000)
[ 1.902013] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.902071] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.902083] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.902096] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.902645] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.902683] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903080] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903129] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903187] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903233] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.913682] usb 5-1: new full-speed USB device number 2 using uhci_hcd
[ 1.933918] wmi: Mapper loaded
[ 1.934254] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[ 1.943289] ahci 0000:01:00.0: version 3.0
[ 1.943381] ahci 0000:01:00.0: controller can do FBS, turning on CAP_FBS
[ 1.945229] sky2: driver version 1.30
[ 1.945305] sky2 0000:05:00.0: Yukon-2 EC Ultra chip revision 3
[ 1.945629] sky2 0000:05:00.0 eth0: addr 20:cf:30:0b:0e:90
[ 1.949835] [drm] Initialized drm 1.1.0 20060810
[ 1.957621] ahci 0000:01:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl IDE mode
[ 1.957625] ahci 0000:01:00.0: flags: 64bit ncq fbs pio
[ 1.958756] scsi host4: ahci
[ 1.958886] scsi host5: ahci
[ 1.959015] scsi host6: ahci
[ 1.959138] scsi host7: ahci
[ 1.959260] scsi host8: ahci
[ 1.959376] scsi host9: ahci
[ 1.959488] scsi host10: ahci
[ 1.959595] scsi host11: ahci
[ 1.959663] ata5: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ff900 irq 36
[ 1.959666] ata6: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ff980 irq 36
[ 1.959668] ata7: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffa00 irq 36
[ 1.959670] ata8: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffa80 irq 36
[ 1.959672] ata9: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffb00 irq 36
[ 1.959673] ata10: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffb80 irq 36
[ 1.959675] ata11: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffc00 irq 36
[ 1.959677] ata12: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffc80 irq 36
[ 1.986822] [drm] radeon kernel modesetting enabled.
[ 1.987916] sky2 0000:05:00.0 enp5s0: renamed from eth0
[ 1.989142] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.989143] AMD IOMMUv2 functionality not available on this system
[ 1.989581] tsc: Refined TSC clocksource calibration: 2806.361 MHz
[ 1.989584] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2873ba27e9c, max_idle_ns: 440795337963 ns
[ 1.992207] CRAT table not found
[ 1.992209] Finished initializing topology ret=0
[ 1.992257] kfd kfd: Initialized module
[ 1.992435] checking generic (c0000000 5b0000) vs hw (c0000000 10000000)
[ 1.992436] fb: switching to radeondrmfb from VESA VGA
[ 1.992465] Console: switching to colour dummy device 80x25
[ 1.992745] [drm] initializing kernel modesetting (REDWOOD 0x1002:0x68DA 0x174B:0x1621).
[ 1.992756] [drm] register mmio base: 0xFBBC0000
[ 1.992757] [drm] register mmio size: 131072
[ 1.992790] ATOM BIOS: REDWOOD
[ 1.992866] radeon 0000:03:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
[ 1.992868] radeon 0000:03:00.0: GTT: 1024M 0x0000000080000000 - 0x00000000BFFFFFFF
[ 1.992869] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 1.992870] [drm] RAM width 128bits DDR
[ 1.992907] [TTM] Zone kernel: Available graphics memory: 11307720 kiB
[ 1.992908] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 1.992909] [TTM] Initializing pool allocator
[ 1.992914] [TTM] Initializing DMA pool allocator
[ 1.992929] [drm] radeon: 2048M of VRAM memory ready
[ 1.992930] [drm] radeon: 1024M of GTT memory ready.
[ 1.992941] [drm] Loading REDWOOD Microcode
[ 1.992991] [drm] Internal thermal controller with fan control
[ 2.013774] firewire_ohci 0000:07:02.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 2.017945] [drm] radeon: dpm initialized
[ 2.018022] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.018204] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 2.018288] scsi host12: usb-storage 1-1:1.0
[ 2.018345] usbcore: registered new interface driver usb-storage
[ 2.018773] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 2.019745] usbcore: registered new interface driver uas
[ 2.048628] [drm] PCIE GART of 1024M enabled (table at 0x000000000025E000).
[ 2.048764] radeon 0000:03:00.0: WB enabled
[ 2.048767] radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0xffff880035769c00
[ 2.048768] radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0xffff880035769c0c
[ 2.049714] radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x000000000005c418 and cpu addr 0xffffc9000381c418
[ 2.049715] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.049716] [drm] Driver supports precise vblank timestamp query.
[ 2.049717] radeon 0000:03:00.0: radeon: MSI limited to 32-bit
[ 2.049744] radeon 0000:03:00.0: radeon: using MSI.
[ 2.049770] [drm] radeon: irq initialized.
[ 2.066642] [drm] ring test on 0 succeeded in 1 usecs
[ 2.066649] [drm] ring test on 3 succeeded in 2 usecs
[ 2.088632] usb 5-1: New USB device found, idVendor=062a, idProduct=4101
[ 2.088634] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.088636] usb 5-1: Product: 2.4G Keyboard Mouse
[ 2.088637] usb 5-1: Manufacturer: MOSART Semi.
[ 2.094603] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.101872] usbcore: registered new interface driver usbhid
[ 2.101874] usbhid: USB HID core driver
[ 2.103403] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:062A:4101.0001/input/input5
[ 2.157811] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:1a.2-1/input0
[ 2.158082] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:062A:4101.0002/input/input6
[ 2.218099] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:1a.2-1/input1
[ 2.242338] [drm] ring test on 5 succeeded in 1 usecs
[ 2.242344] [drm] UVD initialized successfully.
[ 2.242579] [drm] ib test on ring 0 succeeded in 0 usecs
[ 2.242612] [drm] ib test on ring 3 succeeded in 0 usecs
[ 2.277650] ata12: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.277669] ata11: SATA link down (SStatus 0 SControl 300)
[ 2.277688] ata10: SATA link down (SStatus 0 SControl 300)
[ 2.277712] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.277753] ata12.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66
[ 2.277960] ata12.00: configured for UDMA/66
[ 2.281651] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.285664] ata9: SATA link down (SStatus 0 SControl 300)
[ 2.289657] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.293662] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.306006] scsi 11:0:0:0: Processor Marvell 91xx Config 1.01 PQ: 0 ANSI: 5
[ 2.333637] ata12.00: exception Emask 0x1 SAct 0x0 SErr 0x0 action 0x6
[ 2.333640] ata12.00: irq_stat 0x40000001
[ 2.333647] ata12.00: cmd a0/01:00:00:00:01/00:00:00:00:00/a0 tag 1 dma 16640 in
Inquiry 12 01 00 00 ff 00res 00/00:00:00:00:00/00:00:00:00:00/00 Emask 0x3 (HSM violation)
[ 2.333650] ata12: hard resetting link
[ 2.513781] firewire_core 0000:07:02.0: created device fw0: GUID 001fc6000000eb61, S400
[ 2.661612] ata12: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.662027] ata12.00: configured for UDMA/66
[ 2.662156] ata12: EH complete
[ 2.662417] scsi 11:0:0:0: Attached scsi generic sg2 type 3
[ 2.889700] [drm] ib test on ring 5 succeeded
[ 2.892294] [drm] Radeon Display Connectors
[ 2.892296] [drm] Connector 0:
[ 2.892297] [drm] HDMI-A-1
[ 2.892298] [drm] HPD2
[ 2.892300] [drm] DDC: 0x6470 0x6470 0x6474 0x6474 0x6478 0x6478 0x647c 0x647c
[ 2.892300] [drm] Encoders:
[ 2.892301] [drm] DFP1: INTERNAL_UNIPHY2
[ 2.892302] [drm] Connector 1:
[ 2.892303] [drm] DVI-I-1
[ 2.892303] [drm] HPD1
[ 2.892304] [drm] DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[ 2.892305] [drm] Encoders:
[ 2.892306] [drm] DFP2: INTERNAL_UNIPHY1
[ 2.892307] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 2.892307] [drm] Connector 2:
[ 2.892308] [drm] VGA-1
[ 2.892309] [drm] DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[ 2.892310] [drm] Encoders:
[ 2.892311] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 2.995297] clocksource: Switched to clocksource tsc
[ 3.018507] scsi 12:0:0:0: Direct-Access Generic Storage Device 0.00 PQ: 0 ANSI: 2
[ 3.029565] sd 12:0:0:0: Attached scsi generic sg3 type 0
[ 3.031098] sd 12:0:0:0: [sdc] Attached SCSI removable disk
[ 3.032646] [drm] fb mappable at 0xC045F000
[ 3.032647] [drm] vram apper at 0xC0000000
[ 3.032648] [drm] size 8294400
[ 3.032649] [drm] fb depth is 24
[ 3.032650] [drm] pitch is 7680
[ 3.032817] fbcon: radeondrmfb (fb0) is primary device
[ 3.032932] Console: switching to colour frame buffer device 160x64
[ 3.032965] radeon 0000:03:00.0: fb0: radeondrmfb frame buffer device
[ 3.049774] [drm] Initialized radeon 2.43.0 20080528 for 0000:03:00.0 on minor 0
[ 3.049816] radeon 0000:04:00.0: enabling device (0000 -> 0003)
[ 3.050608] [drm] initializing kernel modesetting (RV710 0x1002:0x9540 0x1458:0x21AE).
[ 3.050622] [drm] register mmio base: 0xFBCE0000
[ 3.050624] [drm] register mmio size: 65536
[ 3.163814] ATOM BIOS: GV
[ 3.163826] [drm] GPU not posted. posting now...
[ 3.165144] radeon 0000:04:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 3.165146] radeon 0000:04:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[ 3.165147] [drm] Detected VRAM RAM=512M, BAR=256M
[ 3.165148] [drm] RAM width 64bits DDR
[ 3.165155] [drm] radeon: 512M of VRAM memory ready
[ 3.165155] [drm] radeon: 1024M of GTT memory ready.
[ 3.165163] [drm] Loading RV710 Microcode
[ 3.165212] [drm] Internal thermal controller with fan control
[ 3.170450] [drm] radeon: dpm initialized
[ 3.170511] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 3.171188] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 3.173141] [drm] PCIE GART of 1024M enabled (table at 0x000000000025E000).
[ 3.173200] radeon 0000:04:00.0: WB enabled
[ 3.173203] radeon 0000:04:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff88059c98fc00
[ 3.173205] radeon 0000:04:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff88059c98fc0c
[ 3.173899] radeon 0000:04:00.0: fence driver on ring 5 use gpu addr 0x000000000005c598 and cpu addr 0xffffc9000501c598
[ 3.173901] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.173901] [drm] Driver supports precise vblank timestamp query.
[ 3.173903] radeon 0000:04:00.0: radeon: MSI limited to 32-bit
[ 3.173926] radeon 0000:04:00.0: radeon: using MSI.
[ 3.173951] [drm] radeon: irq initialized.
[ 3.220544] [drm] ring test on 0 succeeded in 1 usecs
[ 3.220550] [drm] ring test on 3 succeeded in 2 usecs
[ 3.396348] [drm] ring test on 5 succeeded in 1 usecs
[ 3.396351] [drm] UVD initialized successfully.
[ 3.396559] [drm] ib test on ring 0 succeeded in 0 usecs
[ 3.396580] [drm] ib test on ring 3 succeeded in 0 usecs
[ 4.045547] [drm] ib test on ring 5 succeeded
[ 4.047978] [drm] Radeon Display Connectors
[ 4.047980] [drm] Connector 0:
[ 4.047981] [drm] VGA-2
[ 4.047982] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 4.047983] [drm] Encoders:
[ 4.047984] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 4.047985] [drm] Connector 1:
[ 4.047985] [drm] HDMI-A-2
[ 4.047986] [drm] HPD1
[ 4.047987] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 4.047988] [drm] Encoders:
[ 4.047989] [drm] DFP1: INTERNAL_UNIPHY
[ 4.047989] [drm] Connector 2:
[ 4.047990] [drm] DVI-I-2
[ 4.047991] [drm] HPD4
[ 4.047992] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 4.047993] [drm] Encoders:
[ 4.047993] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 4.047994] [drm] DFP2: INTERNAL_UNIPHY2
[ 4.100731] [drm] fb mappable at 0xD045F000
[ 4.100733] [drm] vram apper at 0xD0000000
[ 4.100734] [drm] size 5242880
[ 4.100734] [drm] fb depth is 24
[ 4.100735] [drm] pitch is 5120
[ 4.100777] radeon 0000:04:00.0: fb1: radeondrmfb frame buffer device
[ 4.100912] [drm] Initialized radeon 2.43.0 20080528 for 0000:04:00.0 on minor 1
[ 4.953536] floppy0: no floppy controllers found
[ 4.953549] work still pending
[ 5.477377] raid6: sse2x1 gen() 7105 MB/s
[ 5.545375] raid6: sse2x1 xor() 5502 MB/s
[ 5.613365] raid6: sse2x2 gen() 8425 MB/s
[ 5.681357] raid6: sse2x2 xor() 6523 MB/s
[ 5.749356] raid6: sse2x4 gen() 9539 MB/s
[ 5.817344] raid6: sse2x4 xor() 7146 MB/s
[ 5.817346] raid6: using algorithm sse2x4 gen() 9539 MB/s
[ 5.817347] raid6: .... xor() 7146 MB/s, rmw enabled
[ 5.817348] raid6: using ssse3x2 recovery algorithm
[ 5.818541] xor: measuring software checksum speed
[ 5.857347] prefetch64-sse: 12287.000 MB/sec
[ 5.897341] generic_sse: 10817.000 MB/sec
[ 5.897343] xor: using function: prefetch64-sse (12287.000 MB/sec)
[ 5.911475] Btrfs loaded
[ 5.991334] random: nonblocking pool is initialized
[ 6.112019] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.828632] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.828789] systemd[1]: Detected architecture x86-64.
[ 6.832520] systemd[1]: Set hostname to <io-serena>.
[ 7.830792] systemd[1]: Reached target Encrypted Volumes.
[ 7.830870] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.830924] systemd[1]: Listening on Journal Audit Socket.
[ 7.830945] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.831016] systemd[1]: Created slice User and Session Slice.
[ 7.831025] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.831033] systemd[1]: Reached target User and Group Name Lookups.
[ 7.831062] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.831082] systemd[1]: Listening on udev Kernel Socket.
[ 7.831100] systemd[1]: Listening on Syslog Socket.
[ 7.831127] systemd[1]: Listening on Journal Socket.
[ 7.831166] systemd[1]: Listening on udev Control Socket.
[ 7.831195] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.831251] systemd[1]: Created slice System Slice.
[ 7.841446] systemd[1]: Starting Set console keymap...
[ 7.841862] systemd[1]: Starting Journal Service...
[ 7.842400] systemd[1]: Started Read required files in advance.
[ 7.842828] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 7.843158] systemd[1]: Mounting Debug File System...
[ 7.843539] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.921446] systemd[1]: Starting Load Kernel Modules...
[ 7.921474] systemd[1]: Reached target Slices.
[ 7.921532] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.921918] systemd[1]: Started Braille Device Support.
[ 7.922230] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.076805] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 8.093314] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 8.093690] systemd[1]: Mounting Huge Pages File System...
[ 8.093772] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.094243] systemd[1]: Starting Uncomplicated firewall...
[ 8.094779] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 8.094813] systemd[1]: Reached target Remote File Systems.
[ 8.231871] systemd[1]: Mounted Debug File System.
[ 8.231941] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.231981] systemd[1]: Mounted Huge Pages File System.
[ 8.250162] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 8.269443] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.278109] systemd[1]: Started Uncomplicated firewall.
[ 8.340675] lp: driver loaded but no devices found
[ 8.345467] systemd[1]: Started Journal Service.
[ 8.351233] ppdev: user-space parallel port driver
[ 9.525831] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 9.671919] systemd-journald[396]: Received request to flush runtime journal from PID 1
[ 9.884201] i5500_temp 0000:00:14.3: Sensor seems to be disabled
[ 9.984314] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20150930/utaddress-254)
[ 9.984320] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.984323] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20150930/utaddress-254)
[ 9.984325] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.984327] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20150930/utaddress-254)
[ 9.984329] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.984330] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 9.993625] EDAC MC: Ver: 3.0.0
[ 10.016971] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.037251] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:ff:03.0 (POLLED)
[ 10.037288] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:ff:03.0 (POLLED)
[ 10.037294] EDAC i7core: Driver loaded, 1 memory controller(s) found.
[ 10.432268] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 10.693942] snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
[ 10.694042] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 10.734380] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:07.0/0000:04:00.1/sound/card2/input8
[ 10.734637] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input7
[ 10.755220] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC889: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 10.755223] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.755225] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 10.755227] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 10.755228] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 10.755229] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 10.755232] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 10.755233] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 10.755235] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 10.769872] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 10.769935] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 10.769994] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 10.770052] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 10.770106] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 10.770171] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 10.770289] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 10.770449] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 11.051301] Adding 9764860k swap on /dev/sda1. Priority:-1 extents:1 across:9764860k FS
[ 11.449499] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 12.774597] cgroup: new mount options do not match the existing superblock, will be ignored
[ 12.872922] floppy0: no floppy controllers found
[ 13.571476] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 13.574577] vboxdrv: Found 8 processor cores
[ 13.593073] vboxdrv: TSC mode is Invariant, tentative frequency 2806357778 Hz
[ 13.593075] vboxdrv: Successfully loaded version 5.1.14 (interface 0x00280000)
[ 14.051824] VBoxNetFlt: Successfully started.
[ 14.103419] VBoxNetAdp: Successfully started.
[ 14.196994] VBoxPciLinuxInit
[ 14.273495] vboxpci: IOMMU not found (not registered)
[ 16.828291] IPv6: ADDRCONF(NETDEV_UP): enp5s0: link is not ready
[ 16.831243] sky2 0000:05:00.0 enp5s0: enabling interface
[ 16.831456] IPv6: ADDRCONF(NETDEV_UP): enp5s0: link is not ready
[ 17.739643] vgaarb: device changed decodes: PCI:0000:04:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 17.739647] vgaarb: device changed decodes: PCI:0000:03:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 18.647510] sky2 0000:05:00.0 enp5s0: Link is up at 100 Mbps, full duplex, flow control both
[ 18.647532] IPv6: ADDRCONF(NETDEV_CHANGE): enp5s0: link becomes ready
[ 261.940209] kactivitymanage[2081]: segfault at 7f7fc9fd5cd0 ip 00007f7fc8103301 sp 00007ffe9517e528 error 4 in libQt5Sql.so.5.6.1[7f7fc80ed000+45000]
[ 261.940567] QDBusConnection[2519]: segfault at 7f84141c0f10 ip 00007f8427a5e6c7 sp 00007f840fffe9e0 error 4 in libQt5Core.so.5.6.1[7f84277ac000+4c0000]
[ 2466.331593] perf interrupt took too long (2502 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
сейчас перезагружусь и скину "плохой")
пошел "плохой вариант" dmesg:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.0-64-generic (buildd@lgw01-56) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.4) ) #85-Ubuntu SMP Mon Feb 20 11:50:30 UTC 2017 (Ubuntu 4.4.0-64.85-generic 4.4.44)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-64-generic root=UUID=1675ecfa-ad11-4c18-8d91-693fb9ccccfe ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Legacy x87 FPU detected.
[ 0.000000] x86/fpu: Using 'lazy' FPU context switches.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4c00-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000bf77ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000bf780000-0x00000000bf797fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000bf798000-0x00000000bf7dbfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000bf7dc000-0x00000000bfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffe00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000005bfffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/P6X58D-E, BIOS 0303 05/25/2010
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x5c0000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E3FFF write-protect
[ 0.000000] E4000-EBFFF write-through
[ 0.000000] EC000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 5C0000000 mask FC0000000 uncachable
[ 0.000000] 1 base 000000000 mask C00000000 write-back
[ 0.000000] 2 base 400000000 mask E00000000 write-back
[ 0.000000] 3 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 4 base 0BF800000 mask FFF800000 uncachable
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] original variable MTRRs
[ 0.000000] reg 0, base: 23GB, range: 1GB, type UC
[ 0.000000] reg 1, base: 0GB, range: 16GB, type WB
[ 0.000000] reg 2, base: 16GB, range: 8GB, type WB
[ 0.000000] reg 3, base: 3GB, range: 1GB, type UC
[ 0.000000] reg 4, base: 3064MB, range: 8MB, type UC
[ 0.000000] total RAM covered: 22520M
[ 0.000000] Found optimal setting for mtrr clean up
[ 0.000000] gran_size: 64K chunk_size: 2G num_reg: 7 lose cover RAM: 0G
[ 0.000000] New variable MTRRs
[ 0.000000] reg 0, base: 0GB, range: 4GB, type WB
[ 0.000000] reg 1, base: 3064MB, range: 8MB, type UC
[ 0.000000] reg 2, base: 3GB, range: 1GB, type UC
[ 0.000000] reg 3, base: 4GB, range: 4GB, type WB
[ 0.000000] reg 4, base: 8GB, range: 8GB, type WB
[ 0.000000] reg 5, base: 16GB, range: 8GB, type WB
[ 0.000000] reg 6, base: 23GB, range: 1GB, type UC
[ 0.000000] e820: update [mem 0xbf800000-0xffffffff] usable ==> reserved
[ 0.000000] e820: last_pfn = 0xbf780 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [ffff8800000ff780]
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] Base memory trampoline at [ffff880000099000] 99000 size 24576
[ 0.000000] BRK [0x0220c000, 0x0220cfff] PGTABLE
[ 0.000000] BRK [0x0220d000, 0x0220dfff] PGTABLE
[ 0.000000] BRK [0x0220e000, 0x0220efff] PGTABLE
[ 0.000000] BRK [0x0220f000, 0x0220ffff] PGTABLE
[ 0.000000] BRK [0x02210000, 0x02210fff] PGTABLE
[ 0.000000] BRK [0x02211000, 0x02211fff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x33310000-0x3597ffff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FBA30 000014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 0x00000000BF780000 000044 (v01 052510 RSDT1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: FACP 0x00000000BF780200 000084 (v01 052510 FACP1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: DSDT 0x00000000BF7804B0 00B384 (v01 A1631 A1631001 00000001 INTL 20060113)
[ 0.000000] ACPI: FACS 0x00000000BF798000 000040
[ 0.000000] ACPI: APIC 0x00000000BF780390 0000D8 (v01 052510 APIC1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: MCFG 0x00000000BF780470 00003C (v01 052510 OEMMCFG 20100525 MSFT 00000097)
[ 0.000000] ACPI: OEMB 0x00000000BF798040 000072 (v01 052510 OEMB1439 20100525 MSFT 00000097)
[ 0.000000] ACPI: HPET 0x00000000BF78F4B0 000038 (v01 052510 OEMHPET 20100525 MSFT 00000097)
[ 0.000000] ACPI: ASPT 0x00000000BF798360 000034 (v06 052510 PerfTune 20100525 MSFT 00000097)
[ 0.000000] ACPI: OSFR 0x00000000BF78F4F0 0000B0 (v01 052510 OEMOSFR 20100525 MSFT 00000097)
[ 0.000000] ACPI: SSDT 0x00000000BF79A1C0 000363 (v01 DpgPmm CpuPm 00000012 INTL 20060113)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] No NUMA configuration found
[ 0.000000] Faking a node at [mem 0x0000000000000000-0x00000005bfffffff]
[ 0.000000] NODE_DATA(0) allocated [mem 0x5bffe8000-0x5bffecfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000005bfffffff]
[ 0.000000] Device empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000bf77ffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000005bfffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000005bfffffff]
[ 0.000000] On node 0 totalpages: 5764894
[ 0.000000] DMA zone: 64 pages used for memmap
[ 0.000000] DMA zone: 21 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 12190 pages used for memmap
[ 0.000000] DMA32 zone: 780160 pages, LIFO batch:31
[ 0.000000] Normal zone: 77824 pages used for memmap
[ 0.000000] Normal zone: 4980736 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] IOAPIC[1]: apic_id 9, version 32, address 0xfec8a000, GSI 24-47
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a301 base: 0xfed00000
[ 0.000000] smpboot: Allowing 16 CPUs, 8 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000e4fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000e5000-0x000fffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf780000-0xbf797fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf798000-0xbf7dbfff]
[ 0.000000] PM: Registered nosave memory: [mem 0xbf7dc000-0xbfffffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xc0000000-0xfedfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xffdfffff]
[ 0.000000] PM: Registered nosave memory: [mem 0xffe00000-0xffffffff]
[ 0.000000] e820: [mem 0xc0000000-0xfedfffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:512 nr_cpumask_bits:512 nr_cpu_ids:16 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 33 pages/cpu @ffff8805a9200000 s98264 r8192 d28712 u262144
[ 0.000000] pcpu-alloc: s98264 r8192 d28712 u262144 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 5674795
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.0-64-generic root=UUID=1675ecfa-ad11-4c18-8d91-693fb9ccccfe ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Calgary: detecting Calgary via BIOS EBDA area
[ 0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[ 0.000000] Memory: 22572668K/23059576K available (8452K kernel code, 1293K rwdata, 3980K rodata, 1488K init, 1316K bss, 486908K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=512 to nr_cpu_ids=16.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=16
[ 0.000000] NR_IRQS:33024 nr_irqs:960 16
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2806.383 MHz processor
[ 0.000032] Calibrating delay loop (skipped), value calculated using timer frequency.. 5612.76 BogoMIPS (lpj=11225532)
[ 0.000035] pid_max: default: 32768 minimum: 301
[ 0.000042] ACPI: Core revision 20150930
[ 0.007833] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.007858] Security Framework initialized
[ 0.007860] Yama: becoming mindful.
[ 0.007882] AppArmor: AppArmor initialized
[ 0.009977] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[ 0.016859] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[ 0.019817] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.019854] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.020245] Initializing cgroup subsys io
[ 0.020250] Initializing cgroup subsys memory
[ 0.020258] Initializing cgroup subsys devices
[ 0.020261] Initializing cgroup subsys freezer
[ 0.020264] Initializing cgroup subsys net_cls
[ 0.020267] Initializing cgroup subsys perf_event
[ 0.020270] Initializing cgroup subsys net_prio
[ 0.020275] Initializing cgroup subsys hugetlb
[ 0.020277] Initializing cgroup subsys pids
[ 0.020298] CPU: Physical Processor ID: 0
[ 0.020299] CPU: Processor Core ID: 0
[ 0.020304] mce: CPU supports 9 MCE banks
[ 0.020317] CPU0: Thermal monitoring enabled (TM1)
[ 0.020326] process: using mwait in idle threads
[ 0.020329] Last level iTLB entries: 4KB 512, 2MB 7, 4MB 7
[ 0.020330] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[ 0.020633] Freeing SMP alternatives memory: 32K (ffffffff820b9000 - ffffffff820c1000)
[ 0.071567] ftrace: allocating 32123 entries in 126 pages
[ 0.086125] smpboot: APIC(0) Converting physical 0 to logical package 0
[ 0.086127] smpboot: Max logical packages: 4
[ 0.086131] DMAR-IR: This system BIOS has enabled interrupt remapping
on a chipset that contains an erratum making that
feature unstable. To maintain system stability
interrupt remapping is being disabled. Please
contact your BIOS vendor for an update
[ 0.086136] Switched APIC routing to physical flat.
[ 0.086686] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.234084] smpboot: CPU0: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz (family: 0x6, model: 0x1a, stepping: 0x5)
[ 0.234103] Performance Events: PEBS fmt1+, 16-deep LBR, Nehalem events, Intel PMU driver.
[ 0.234120] core: CPU erratum AAJ80 worked around
[ 0.234121] core: CPUID marked event: 'bus cycles' unavailable
[ 0.234123] ... version: 3
[ 0.234124] ... bit width: 48
[ 0.234125] ... generic registers: 4
[ 0.234126] ... value mask: 0000ffffffffffff
[ 0.234127] ... max period: 000000007fffffff
[ 0.234128] ... fixed-purpose events: 3
[ 0.234129] ... event mask: 000000070000000f
[ 0.235039] x86: Booting SMP configuration:
[ 0.235041] .... node #0, CPUs: #1
[ 0.237818] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.237919] #2 #3 #4 #5 #6 #7
[ 0.252551] x86: Booted up 1 node, 8 CPUs
[ 0.252554] smpboot: Total of 8 processors activated (44902.12 BogoMIPS)
[ 0.258924] devtmpfs: initialized
[ 0.263960] evm: security.selinux
[ 0.263961] evm: security.SMACK64
[ 0.263962] evm: security.SMACK64EXEC
[ 0.263963] evm: security.SMACK64TRANSMUTE
[ 0.263964] evm: security.SMACK64MMAP
[ 0.263964] evm: security.ima
[ 0.263965] evm: security.capability
[ 0.264030] PM: Registering ACPI NVS region [mem 0xbf798000-0xbf7dbfff] (278528 bytes)
[ 0.264114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.264194] pinctrl core: initialized pinctrl subsystem
[ 0.264299] RTC time: 18:15:48, date: 02/22/17
[ 0.264402] NET: Registered protocol family 16
[ 0.274090] cpuidle: using governor ladder
[ 0.286086] cpuidle: using governor menu
[ 0.286091] PCCT header not found.
[ 0.286178] ACPI: bus type PCI registered
[ 0.286180] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.286244] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.286246] PCI: not using MMCONFIG
[ 0.286247] PCI: Using configuration type 1 for base access
[ 0.298514] ACPI: Added _OSI(Module Device)
[ 0.298516] ACPI: Added _OSI(Processor Device)
[ 0.298517] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.298518] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.300042] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.327333] ACPI: Dynamic OEM Table Load:
[ 0.327345] ACPI: SSDT 0xFFFF8805A8D1E000 001E1C (v01 DpgPmm P001Ist 00000011 INTL 20060113)
[ 0.327919] ACPI: Interpreter enabled
[ 0.327937] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.327939] ACPI: Using IOAPIC for interrupt routing
[ 0.327967] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.328777] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.328782] pmd_set_huge: Cannot satisfy [mem 0xe0000000-0xe0200000] with a huge-page mapping due to MTRR override.
[ 0.329237] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.334286] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.334291] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.334295] acpi PNP0A08:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.334526] PCI host bridge to bus 0000:00
[ 0.334529] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.334531] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.334532] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.334534] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.334535] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xdfffffff window]
[ 0.334537] pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfed8ffff window]
[ 0.334539] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.334549] pci 0000:00:00.0: [8086:3405] type 00 class 0x060000
[ 0.334605] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
[ 0.334683] pci 0000:00:01.0: [8086:3408] type 01 class 0x060400
[ 0.334737] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.334784] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.334820] pci 0000:00:02.0: [8086:3409] type 01 class 0x060400
[ 0.334872] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.334917] pci 0000:00:02.0: System wakeup disabled by ACPI
[ 0.334951] pci 0000:00:03.0: [8086:340a] type 01 class 0x060400
[ 0.335004] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.335051] pci 0000:00:03.0: System wakeup disabled by ACPI
[ 0.335087] pci 0000:00:07.0: [8086:340e] type 01 class 0x060400
[ 0.335140] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.335185] pci 0000:00:07.0: System wakeup disabled by ACPI
[ 0.335225] pci 0000:00:14.0: [8086:342e] type 00 class 0x080000
[ 0.335329] pci 0000:00:14.1: [8086:3422] type 00 class 0x080000
[ 0.335432] pci 0000:00:14.2: [8086:3423] type 00 class 0x080000
[ 0.335531] pci 0000:00:14.3: [8086:3438] type 00 class 0x080000
[ 0.335628] pci 0000:00:1a.0: [8086:3a37] type 00 class 0x0c0300
[ 0.335671] pci 0000:00:1a.0: reg 0x20: [io 0x9800-0x981f]
[ 0.335748] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.335785] pci 0000:00:1a.1: [8086:3a38] type 00 class 0x0c0300
[ 0.335828] pci 0000:00:1a.1: reg 0x20: [io 0x9880-0x989f]
[ 0.335905] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.335939] pci 0000:00:1a.2: [8086:3a39] type 00 class 0x0c0300
[ 0.335983] pci 0000:00:1a.2: reg 0x20: [io 0x9c00-0x9c1f]
[ 0.336059] pci 0000:00:1a.2: System wakeup disabled by ACPI
[ 0.336099] pci 0000:00:1a.7: [8086:3a3c] type 00 class 0x0c0320
[ 0.336126] pci 0000:00:1a.7: reg 0x10: [mem 0xfb8ff000-0xfb8ff3ff]
[ 0.336194] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.336237] pci 0000:00:1a.7: System wakeup disabled by ACPI
[ 0.336273] pci 0000:00:1b.0: [8086:3a3e] type 00 class 0x040300
[ 0.336298] pci 0000:00:1b.0: reg 0x10: [mem 0xfb8f8000-0xfb8fbfff 64bit]
[ 0.336355] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.336428] pci 0000:00:1c.0: [8086:3a40] type 01 class 0x060400
[ 0.336493] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.336537] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.336572] pci 0000:00:1c.2: [8086:3a44] type 01 class 0x060400
[ 0.336637] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.336681] pci 0000:00:1c.2: System wakeup disabled by ACPI
[ 0.336718] pci 0000:00:1d.0: [8086:3a34] type 00 class 0x0c0300
[ 0.336762] pci 0000:00:1d.0: reg 0x20: [io 0x9080-0x909f]
[ 0.336839] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.336873] pci 0000:00:1d.1: [8086:3a35] type 00 class 0x0c0300
[ 0.336916] pci 0000:00:1d.1: reg 0x20: [io 0x9400-0x941f]
[ 0.336993] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.337028] pci 0000:00:1d.2: [8086:3a36] type 00 class 0x0c0300
[ 0.337071] pci 0000:00:1d.2: reg 0x20: [io 0x9480-0x949f]
[ 0.337147] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.337188] pci 0000:00:1d.7: [8086:3a3a] type 00 class 0x0c0320
[ 0.337214] pci 0000:00:1d.7: reg 0x10: [mem 0xfb8fe000-0xfb8fe3ff]
[ 0.337282] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.337327] pci 0000:00:1d.7: System wakeup disabled by ACPI
[ 0.337360] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.337439] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.337474] pci 0000:00:1f.0: [8086:3a16] type 00 class 0x060100
[ 0.337554] pci 0000:00:1f.0: can't claim BAR 13 [io 0x0800-0x087f]: address conflict with ACPI CPU throttle [io 0x0810-0x0815]
[ 0.337558] pci 0000:00:1f.0: quirk: [io 0x0500-0x053f] claimed by ICH6 GPIO
[ 0.337561] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.337646] pci 0000:00:1f.2: [8086:3a20] type 00 class 0x01018f
[ 0.337664] pci 0000:00:1f.2: reg 0x10: [io 0x8000-0x8007]
[ 0.337671] pci 0000:00:1f.2: reg 0x14: [io 0x7c00-0x7c03]
[ 0.337678] pci 0000:00:1f.2: reg 0x18: [io 0x7880-0x7887]
[ 0.337685] pci 0000:00:1f.2: reg 0x1c: [io 0x7800-0x7803]
[ 0.337692] pci 0000:00:1f.2: reg 0x20: [io 0x7480-0x748f]
[ 0.337699] pci 0000:00:1f.2: reg 0x24: [io 0x7400-0x740f]
[ 0.337784] pci 0000:00:1f.3: [8086:3a30] type 00 class 0x0c0500
[ 0.337799] pci 0000:00:1f.3: reg 0x10: [mem 0xfb8fd000-0xfb8fd0ff 64bit]
[ 0.337818] pci 0000:00:1f.3: reg 0x20: [io 0x1000-0x101f]
[ 0.337897] pci 0000:00:1f.5: [8086:3a26] type 00 class 0x010185
[ 0.337915] pci 0000:00:1f.5: reg 0x10: [io 0x9000-0x9007]
[ 0.337922] pci 0000:00:1f.5: reg 0x14: [io 0x8c00-0x8c03]
[ 0.337929] pci 0000:00:1f.5: reg 0x18: [io 0x8880-0x8887]
[ 0.337936] pci 0000:00:1f.5: reg 0x1c: [io 0x8800-0x8803]
[ 0.337943] pci 0000:00:1f.5: reg 0x20: [io 0x8480-0x848f]
[ 0.337949] pci 0000:00:1f.5: reg 0x24: [io 0x8400-0x840f]
[ 0.338074] pci 0000:01:00.0: [1b4b:91a3] type 00 class 0x01018f
[ 0.338097] pci 0000:01:00.0: reg 0x10: [io 0xac00-0xac07]
[ 0.338104] pci 0000:01:00.0: reg 0x14: [io 0xa880-0xa883]
[ 0.338111] pci 0000:01:00.0: reg 0x18: [io 0xa800-0xa807]
[ 0.338118] pci 0000:01:00.0: reg 0x1c: [io 0xa480-0xa483]
[ 0.338124] pci 0000:01:00.0: reg 0x20: [io 0xa400-0xa40f]
[ 0.338131] pci 0000:01:00.0: reg 0x24: [mem 0xfb9ff800-0xfb9fffff]
[ 0.338138] pci 0000:01:00.0: reg 0x30: [mem 0xfb9e0000-0xfb9effff pref]
[ 0.338164] pci 0000:01:00.0: PME# supported from D3hot
[ 0.346110] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.346115] pci 0000:00:01.0: bridge window [io 0xa000-0xafff]
[ 0.346120] pci 0000:00:01.0: bridge window [mem 0xfb900000-0xfb9fffff]
[ 0.346189] pci 0000:02:00.0: [1033:0194] type 00 class 0x0c0330
[ 0.346219] pci 0000:02:00.0: reg 0x10: [mem 0xfbafe000-0xfbafffff 64bit]
[ 0.346289] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.354109] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.354116] pci 0000:00:02.0: bridge window [mem 0xfba00000-0xfbafffff]
[ 0.354180] pci 0000:03:00.0: [1002:68da] type 00 class 0x030000
[ 0.354203] pci 0000:03:00.0: reg 0x10: [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.354212] pci 0000:03:00.0: reg 0x18: [mem 0xfbbc0000-0xfbbdffff 64bit]
[ 0.354219] pci 0000:03:00.0: reg 0x20: [io 0xb000-0xb0ff]
[ 0.354230] pci 0000:03:00.0: reg 0x30: [mem 0xfbba0000-0xfbbbffff pref]
[ 0.354257] pci 0000:03:00.0: supports D1 D2
[ 0.354301] pci 0000:03:00.1: [1002:aa60] type 00 class 0x040300
[ 0.354323] pci 0000:03:00.1: reg 0x10: [mem 0xfbbfc000-0xfbbfffff 64bit]
[ 0.354372] pci 0000:03:00.1: supports D1 D2
[ 0.362112] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.362116] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff]
[ 0.362121] pci 0000:00:03.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 0.362127] pci 0000:00:03.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.362190] pci 0000:04:00.0: [1002:9540] type 00 class 0x030000
[ 0.362216] pci 0000:04:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.362225] pci 0000:04:00.0: reg 0x18: [mem 0xfbce0000-0xfbceffff 64bit]
[ 0.362231] pci 0000:04:00.0: reg 0x20: [io 0xc000-0xc0ff]
[ 0.362242] pci 0000:04:00.0: reg 0x30: [mem 0xfbcc0000-0xfbcdffff pref]
[ 0.362270] pci 0000:04:00.0: supports D1 D2
[ 0.362314] pci 0000:04:00.1: [1002:aa38] type 00 class 0x040300
[ 0.362342] pci 0000:04:00.1: reg 0x10: [mem 0xfbcfc000-0xfbcfffff 64bit]
[ 0.362400] pci 0000:04:00.1: supports D1 D2
[ 0.370116] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.370121] pci 0000:00:07.0: bridge window [io 0xc000-0xcfff]
[ 0.370125] pci 0000:00:07.0: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 0.370131] pci 0000:00:07.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.370188] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.370196] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.370247] pci 0000:05:00.0: [11ab:4364] type 00 class 0x020000
[ 0.370290] pci 0000:05:00.0: reg 0x10: [mem 0xfbdfc000-0xfbdfffff 64bit]
[ 0.370301] pci 0000:05:00.0: reg 0x18: [io 0xd800-0xd8ff]
[ 0.370341] pci 0000:05:00.0: reg 0x30: [mem 0xfbdc0000-0xfbddffff pref]
[ 0.370386] pci 0000:05:00.0: supports D1 D2
[ 0.370388] pci 0000:05:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.378122] pci 0000:00:1c.2: PCI bridge to [bus 05]
[ 0.378128] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.378132] pci 0000:00:1c.2: bridge window [mem 0xfbd00000-0xfbdfffff]
[ 0.378193] pci 0000:07:02.0: [1106:3044] type 00 class 0x0c0010
[ 0.378215] pci 0000:07:02.0: reg 0x10: [mem 0xfbeff000-0xfbeff7ff]
[ 0.378224] pci 0000:07:02.0: reg 0x14: [io 0xec00-0xec7f]
[ 0.378285] pci 0000:07:02.0: supports D2
[ 0.378286] pci 0000:07:02.0: PME# supported from D2 D3hot D3cold
[ 0.378352] pci 0000:00:1e.0: PCI bridge to [bus 07] (subtractive decode)
[ 0.378356] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.378359] pci 0000:00:1e.0: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.378364] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.378365] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.378367] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.378368] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.378370] pci 0000:00:1e.0: bridge window [mem 0xc0000000-0xdfffffff window] (subtractive decode)
[ 0.378371] pci 0000:00:1e.0: bridge window [mem 0xf0000000-0xfed8ffff window] (subtractive decode)
[ 0.378894] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 10 11 12 14 *15)
[ 0.378938] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 *11 12 14 15)
[ 0.378981] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.379024] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 6 7 10 11 12 14 15)
[ 0.379068] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12 *14 15)
[ 0.379111] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 *7 10 11 12 14 15)
[ 0.379154] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 *4 6 7 10 11 12 14 15)
[ 0.379198] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 6 7 *10 11 12 14 15)
[ 0.379248] ACPI: Enabled 3 GPEs in block 00 to 3F
[ 0.379373] vgaarb: setting as boot device: PCI:0000:03:00.0
[ 0.379376] vgaarb: device added: PCI:0000:03:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.379379] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=none,locks=none
[ 0.379380] vgaarb: loaded
[ 0.379381] vgaarb: bridge control possible 0000:04:00.0
[ 0.379382] vgaarb: bridge control possible 0000:03:00.0
[ 0.379583] SCSI subsystem initialized
[ 0.379629] libata version 3.00 loaded.
[ 0.379649] ACPI: bus type USB registered
[ 0.379663] usbcore: registered new interface driver usbfs
[ 0.379671] usbcore: registered new interface driver hub
[ 0.379692] usbcore: registered new device driver usb
[ 0.379815] PCI: Using ACPI for IRQ routing
[ 0.385443] PCI: Discovered peer bus ff
[ 0.385444] PCI: root bus ff: using default resources
[ 0.385445] PCI: Probing PCI hardware (bus ff)
[ 0.385470] ACPI: \: failed to evaluate _DSM (0x1001)
[ 0.385471] PCI host bridge to bus 0000:ff
[ 0.385473] pci_bus 0000:ff: root bus resource [io 0x0000-0xffff]
[ 0.385475] pci_bus 0000:ff: root bus resource [mem 0x00000000-0xfffffffff]
[ 0.385476] pci_bus 0000:ff: No busn resource found for root bus, will use [bus ff-ff]
[ 0.385479] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.385483] pci 0000:ff:00.0: [8086:2c41] type 00 class 0x060000
[ 0.385524] pci 0000:ff:00.1: [8086:2c01] type 00 class 0x060000
[ 0.385563] pci 0000:ff:02.0: [8086:2c10] type 00 class 0x060000
[ 0.385600] pci 0000:ff:02.1: [8086:2c11] type 00 class 0x060000
[ 0.385637] pci 0000:ff:03.0: [8086:2c18] type 00 class 0x060000
[ 0.385673] pci 0000:ff:03.1: [8086:2c19] type 00 class 0x060000
[ 0.385709] pci 0000:ff:03.4: [8086:2c1c] type 00 class 0x060000
[ 0.385745] pci 0000:ff:04.0: [8086:2c20] type 00 class 0x060000
[ 0.385781] pci 0000:ff:04.1: [8086:2c21] type 00 class 0x060000
[ 0.385818] pci 0000:ff:04.2: [8086:2c22] type 00 class 0x060000
[ 0.385853] pci 0000:ff:04.3: [8086:2c23] type 00 class 0x060000
[ 0.385891] pci 0000:ff:05.0: [8086:2c28] type 00 class 0x060000
[ 0.385927] pci 0000:ff:05.1: [8086:2c29] type 00 class 0x060000
[ 0.385962] pci 0000:ff:05.2: [8086:2c2a] type 00 class 0x060000
[ 0.385999] pci 0000:ff:05.3: [8086:2c2b] type 00 class 0x060000
[ 0.386037] pci 0000:ff:06.0: [8086:2c30] type 00 class 0x060000
[ 0.386072] pci 0000:ff:06.1: [8086:2c31] type 00 class 0x060000
[ 0.386112] pci 0000:ff:06.2: [8086:2c32] type 00 class 0x060000
[ 0.386148] pci 0000:ff:06.3: [8086:2c33] type 00 class 0x060000
[ 0.386195] pci_bus 0000:ff: busn_res: [bus ff] end is updated to ff
[ 0.386197] pci_bus 0000:ff: busn_res: can not insert [bus ff] under domain [bus 00-ff] (conflicts with (null) [bus 00-ff])
[ 0.386202] PCI: pci_cache_line_size set to 64 bytes
[ 0.386281] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.386282] e820: reserve RAM buffer [mem 0xbf780000-0xbfffffff]
[ 0.386387] NetLabel: Initializing
[ 0.386389] NetLabel: domain hash size = 128
[ 0.386389] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.386400] NetLabel: unlabeled traffic allowed by default
[ 0.386466] HPET: 4 timers in total, 0 timers will be used for per-cpu timer
[ 0.386470] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
[ 0.386473] hpet0: 4 comparators, 64-bit 14.318180 MHz counter
[ 0.388656] amd_nb: Cannot enumerate AMD northbridges
[ 0.388675] clocksource: Switched to clocksource hpet
[ 0.394276] AppArmor: AppArmor Filesystem Enabled
[ 0.394335] pnp: PnP ACPI init
[ 0.394414] system 00:00: [mem 0xfbf00000-0xfbffffff] has been reserved
[ 0.394416] system 00:00: [mem 0xfc000000-0xfcffffff] has been reserved
[ 0.394418] system 00:00: [mem 0xfd000000-0xfdffffff] has been reserved
[ 0.394420] system 00:00: [mem 0xfe000000-0xfebfffff] has been reserved
[ 0.394421] system 00:00: [mem 0xfec8a000-0xfec8afff] could not be reserved
[ 0.394423] system 00:00: [mem 0xfed10000-0xfed10fff] has been reserved
[ 0.394426] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.394487] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.394650] system 00:02: [io 0x0290-0x029f] has been reserved
[ 0.394654] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.394835] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.394837] system 00:03: [io 0x0800-0x087f] could not be reserved
[ 0.394839] system 00:03: [io 0x0500-0x057f] could not be reserved
[ 0.394841] system 00:03: [io 0x0600-0x0607] has been reserved
[ 0.394843] system 00:03: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.394845] system 00:03: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.394847] system 00:03: [mem 0xfed40000-0xfed8ffff] has been reserved
[ 0.394849] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.394948] system 00:04: [mem 0xffc00000-0xffdfffff] has been reserved
[ 0.394952] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.395046] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.395048] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.395051] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.395137] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.395140] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.395277] system 00:07: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.395280] system 00:07: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.395281] system 00:07: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.395283] system 00:07: [mem 0x00100000-0xbfffffff] could not be reserved
[ 0.395285] system 00:07: [mem 0xfed90000-0xffffffff] could not be reserved
[ 0.395288] system 00:07: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.395387] pnp: PnP ACPI: found 8 devices
[ 0.401466] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.401500] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 06] add_size 1000
[ 0.401503] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 06] add_size 400000 add_align 100000
[ 0.401510] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05] add_size 200000 add_align 100000
[ 0.401523] pci 0000:00:1f.0: BAR 13: [io size 0x0080] has bogus alignment
[ 0.401526] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] res_to_dev_res add_size 400000 min_align 100000
[ 0.401528] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x004fffff] res_to_dev_res add_size 400000 min_align 100000
[ 0.401530] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.401532] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.401533] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.401535] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.401539] pci 0000:00:1c.0: BAR 14: assigned [mem 0xf0000000-0xf03fffff]
[ 0.401544] pci 0000:00:1c.2: BAR 15: assigned [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.401546] pci 0000:00:1c.0: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.401549] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.401551] pci 0000:00:01.0: bridge window [io 0xa000-0xafff]
[ 0.401555] pci 0000:00:01.0: bridge window [mem 0xfb900000-0xfb9fffff]
[ 0.401560] pci 0000:00:02.0: PCI bridge to [bus 02]
[ 0.401564] pci 0000:00:02.0: bridge window [mem 0xfba00000-0xfbafffff]
[ 0.401570] pci 0000:00:03.0: PCI bridge to [bus 03]
[ 0.401572] pci 0000:00:03.0: bridge window [io 0xb000-0xbfff]
[ 0.401575] pci 0000:00:03.0: bridge window [mem 0xfbb00000-0xfbbfffff]
[ 0.401578] pci 0000:00:03.0: bridge window [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.401582] pci 0000:00:07.0: PCI bridge to [bus 04]
[ 0.401584] pci 0000:00:07.0: bridge window [io 0xc000-0xcfff]
[ 0.401588] pci 0000:00:07.0: bridge window [mem 0xfbc00000-0xfbcfffff]
[ 0.401591] pci 0000:00:07.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.401595] pci 0000:00:1c.0: PCI bridge to [bus 06]
[ 0.401597] pci 0000:00:1c.0: bridge window [io 0x2000-0x2fff]
[ 0.401601] pci 0000:00:1c.0: bridge window [mem 0xf0000000-0xf03fffff]
[ 0.401604] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.401609] pci 0000:00:1c.2: PCI bridge to [bus 05]
[ 0.401611] pci 0000:00:1c.2: bridge window [io 0xd000-0xdfff]
[ 0.401615] pci 0000:00:1c.2: bridge window [mem 0xfbd00000-0xfbdfffff]
[ 0.401618] pci 0000:00:1c.2: bridge window [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.401623] pci 0000:00:1e.0: PCI bridge to [bus 07]
[ 0.401625] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.401629] pci 0000:00:1e.0: bridge window [mem 0xfbe00000-0xfbefffff]
[ 0.401637] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.401638] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.401640] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.401641] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.401643] pci_bus 0000:00: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.401645] pci_bus 0000:00: resource 9 [mem 0xf0000000-0xfed8ffff window]
[ 0.401646] pci_bus 0000:01: resource 0 [io 0xa000-0xafff]
[ 0.401648] pci_bus 0000:01: resource 1 [mem 0xfb900000-0xfb9fffff]
[ 0.401649] pci_bus 0000:02: resource 1 [mem 0xfba00000-0xfbafffff]
[ 0.401651] pci_bus 0000:03: resource 0 [io 0xb000-0xbfff]
[ 0.401653] pci_bus 0000:03: resource 1 [mem 0xfbb00000-0xfbbfffff]
[ 0.401654] pci_bus 0000:03: resource 2 [mem 0xc0000000-0xcfffffff 64bit pref]
[ 0.401656] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 0.401657] pci_bus 0000:04: resource 1 [mem 0xfbc00000-0xfbcfffff]
[ 0.401659] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.401660] pci_bus 0000:06: resource 0 [io 0x2000-0x2fff]
[ 0.401662] pci_bus 0000:06: resource 1 [mem 0xf0000000-0xf03fffff]
[ 0.401663] pci_bus 0000:06: resource 2 [mem 0xfaf00000-0xfaffffff 64bit pref]
[ 0.401665] pci_bus 0000:05: resource 0 [io 0xd000-0xdfff]
[ 0.401666] pci_bus 0000:05: resource 1 [mem 0xfbd00000-0xfbdfffff]
[ 0.401668] pci_bus 0000:05: resource 2 [mem 0xf0400000-0xf05fffff 64bit pref]
[ 0.401669] pci_bus 0000:07: resource 0 [io 0xe000-0xefff]
[ 0.401671] pci_bus 0000:07: resource 1 [mem 0xfbe00000-0xfbefffff]
[ 0.401672] pci_bus 0000:07: resource 4 [io 0x0000-0x0cf7 window]
[ 0.401674] pci_bus 0000:07: resource 5 [io 0x0d00-0xffff window]
[ 0.401675] pci_bus 0000:07: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.401677] pci_bus 0000:07: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.401678] pci_bus 0000:07: resource 8 [mem 0xc0000000-0xdfffffff window]
[ 0.401680] pci_bus 0000:07: resource 9 [mem 0xf0000000-0xfed8ffff window]
[ 0.401683] pci_bus 0000:ff: resource 4 [io 0x0000-0xffff]
[ 0.401685] pci_bus 0000:ff: resource 5 [mem 0x00000000-0xfffffffff]
Mint 18.1 и 2 карты radeon
[ 0.401716] NET: Registered protocol family 2
[ 0.401940] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.402374] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.402546] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.402588] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.402694] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[ 0.402833] NET: Registered protocol family 1
[ 0.404315] pci 0000:03:00.0: Video device with shadowed ROM
[ 0.404345] PCI: CLS 256 bytes, default 64
[ 0.404390] Trying to unpack rootfs image as initramfs...
[ 0.992355] Freeing initrd memory: 39360K (ffff880033310000 - ffff880035980000)
[ 0.992379] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.992381] software IO TLB [mem 0xbb780000-0xbf780000] (64MB) mapped at [ffff8800bb780000-ffff8800bf77ffff]
[ 0.992586] Scanning for low memory corruption every 60 seconds
[ 0.993055] futex hash table entries: 4096 (order: 6, 262144 bytes)
[ 0.993113] audit: initializing netlink subsys (disabled)
[ 0.993127] audit: type=2000 audit(1487787348.840:1): initialized
[ 0.993448] Initialise system trusted keyring
[ 0.993551] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.994896] zbud: loaded
[ 0.995073] VFS: Disk quotas dquot_6.6.0
[ 0.995109] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.995360] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.995565] fuse init (API version 7.23)
[ 0.995688] Key type big_key registered
[ 0.995701] Allocating IMA MOK and blacklist keyrings.
[ 0.996032] Key type asymmetric registered
[ 0.996035] Asymmetric key parser 'x509' registered
[ 0.996069] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.996102] io scheduler noop registered
[ 0.996105] io scheduler deadline registered (default)
[ 0.996133] io scheduler cfq registered
[ 0.996359] pcieport 0000:00:1c.0: enabling device (0106 -> 0107)
[ 0.996763] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.996771] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.996800] vesafb: mode is 1400x1050x32, linelength=5632, pages=0
[ 0.996801] vesafb: scrolling: redraw
[ 0.996803] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0
[ 0.996822] vesafb: framebuffer at 0xc0000000, mapped to 0xffffc90003800000, using 5824k, total 5824k
[ 0.996914] Console: switching to colour frame buffer device 175x65
[ 0.996949] fb0: VESA VGA frame buffer device
[ 0.996964] intel_idle: MWAIT substates: 0x1120
[ 0.996974] intel_idle: v0.4.1 model 0x1A
[ 0.996975] intel_idle: lapic_timer_reliable_states 0x2
[ 0.997279] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.997282] ACPI: Power Button [PWRB]
[ 0.997314] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.997316] ACPI: Power Button [PWRF]
[ 0.997553] GHES: HEST is not enabled!
[ 0.997637] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.998978] Linux agpgart interface v0.103
[ 1.002254] brd: module loaded
[ 1.003615] loop: module loaded
[ 1.003735] ata_piix 0000:00:1f.2: version 2.13
[ 1.003839] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.004730] scsi host0: ata_piix
[ 1.004910] scsi host1: ata_piix
[ 1.004946] ata1: SATA max UDMA/133 cmd 0x8000 ctl 0x7c00 bmdma 0x7480 irq 20
[ 1.004950] ata2: SATA max UDMA/133 cmd 0x7880 ctl 0x7800 bmdma 0x7488 irq 20
[ 1.005055] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.005786] scsi host2: ata_piix
[ 1.005930] scsi host3: ata_piix
[ 1.005964] ata3: SATA max UDMA/133 cmd 0x9000 ctl 0x8c00 bmdma 0x8480 irq 20
[ 1.005966] ata4: SATA max UDMA/133 cmd 0x8880 ctl 0x8800 bmdma 0x8488 irq 20
[ 1.006048] libphy: Fixed MDIO Bus: probed
[ 1.006051] tun: Universal TUN/TAP device driver, 1.6
[ 1.006052] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.006096] PPP generic driver version 2.4.2
[ 1.006156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.006165] ehci-pci: EHCI PCI platform driver
[ 1.006283] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.006289] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.006300] ehci-pci 0000:00:1a.7: debug port 1
[ 1.010211] ehci-pci 0000:00:1a.7: cache line size of 256 is not supported
[ 1.010221] ehci-pci 0000:00:1a.7: irq 18, io mem 0xfb8ff000
[ 1.020945] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.020999] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.021001] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.021003] usb usb1: Product: EHCI Host Controller
[ 1.021004] usb usb1: Manufacturer: Linux 4.4.0-64-generic ehci_hcd
[ 1.021006] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.021139] hub 1-0:1.0: USB hub found
[ 1.021149] hub 1-0:1.0: 6 ports detected
[ 1.021408] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.021413] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 1.021423] ehci-pci 0000:00:1d.7: debug port 1
[ 1.025316] ehci-pci 0000:00:1d.7: cache line size of 256 is not supported
[ 1.025326] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfb8fe000
[ 1.036863] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.036913] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.036915] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.036916] usb usb2: Product: EHCI Host Controller
[ 1.036918] usb usb2: Manufacturer: Linux 4.4.0-64-generic ehci_hcd
[ 1.036919] usb usb2: SerialNumber: 0000:00:1d.7
[ 1.037047] hub 2-0:1.0: USB hub found
[ 1.037056] hub 2-0:1.0: 6 ports detected
[ 1.037207] ehci-platform: EHCI generic platform driver
[ 1.037216] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.037220] ohci-pci: OHCI PCI platform driver
[ 1.037231] ohci-platform: OHCI generic platform driver
[ 1.037238] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.037345] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.037349] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.037355] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.037377] uhci_hcd 0000:00:1a.0: irq 16, io base 0x00009800
[ 1.037413] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.037415] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.037417] usb usb3: Product: UHCI Host Controller
[ 1.037418] usb usb3: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.037420] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.037548] hub 3-0:1.0: USB hub found
[ 1.037557] hub 3-0:1.0: 2 ports detected
[ 1.037749] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.037754] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.037760] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.037782] uhci_hcd 0000:00:1a.1: irq 21, io base 0x00009880
[ 1.037817] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.037819] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.037820] usb usb4: Product: UHCI Host Controller
[ 1.037821] usb usb4: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.037823] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.037947] hub 4-0:1.0: USB hub found
[ 1.037955] hub 4-0:1.0: 2 ports detected
[ 1.038156] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 1.038160] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 1.038166] uhci_hcd 0000:00:1a.2: detected 2 ports
[ 1.038187] uhci_hcd 0000:00:1a.2: irq 19, io base 0x00009c00
[ 1.038223] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.038225] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.038226] usb usb5: Product: UHCI Host Controller
[ 1.038227] usb usb5: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.038229] usb usb5: SerialNumber: 0000:00:1a.2
[ 1.038356] hub 5-0:1.0: USB hub found
[ 1.038364] hub 5-0:1.0: 2 ports detected
[ 1.038560] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.038565] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 1.038571] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 1.038588] uhci_hcd 0000:00:1d.0: irq 23, io base 0x00009080
[ 1.038622] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.038624] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.038625] usb usb6: Product: UHCI Host Controller
[ 1.038627] usb usb6: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.038628] usb usb6: SerialNumber: 0000:00:1d.0
[ 1.038750] hub 6-0:1.0: USB hub found
[ 1.038758] hub 6-0:1.0: 2 ports detected
[ 1.038954] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.038958] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 1.038964] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 1.038981] uhci_hcd 0000:00:1d.1: irq 19, io base 0x00009400
[ 1.039015] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.039017] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.039018] usb usb7: Product: UHCI Host Controller
[ 1.039020] usb usb7: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.039021] usb usb7: SerialNumber: 0000:00:1d.1
[ 1.039142] hub 7-0:1.0: USB hub found
[ 1.039151] hub 7-0:1.0: 2 ports detected
[ 1.039344] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.039349] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 1.039354] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 1.039373] uhci_hcd 0000:00:1d.2: irq 18, io base 0x00009480
[ 1.039407] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.039409] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.039410] usb usb8: Product: UHCI Host Controller
[ 1.039412] usb usb8: Manufacturer: Linux 4.4.0-64-generic uhci_hcd
[ 1.039413] usb usb8: SerialNumber: 0000:00:1d.2
[ 1.039506] hub 8-0:1.0: USB hub found
[ 1.039511] hub 8-0:1.0: 2 ports detected
[ 1.039640] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.039645] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 9
[ 1.039754] xhci_hcd 0000:02:00.0: hcc params 0x014042cb hci version 0x96 quirks 0x00000004
[ 1.039895] usb usb9: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.039897] usb usb9: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.039898] usb usb9: Product: xHCI Host Controller
[ 1.039900] usb usb9: Manufacturer: Linux 4.4.0-64-generic xhci-hcd
[ 1.039901] usb usb9: SerialNumber: 0000:02:00.0
[ 1.039993] hub 9-0:1.0: USB hub found
[ 1.040000] hub 9-0:1.0: 2 ports detected
[ 1.040074] xhci_hcd 0000:02:00.0: xHCI Host Controller
[ 1.040077] xhci_hcd 0000:02:00.0: new USB bus registered, assigned bus number 10
[ 1.043127] usb usb10: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.043142] usb usb10: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.043143] usb usb10: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.043145] usb usb10: Product: xHCI Host Controller
[ 1.043146] usb usb10: Manufacturer: Linux 4.4.0-64-generic xhci-hcd
[ 1.043148] usb usb10: SerialNumber: 0000:02:00.0
[ 1.043240] hub 10-0:1.0: USB hub found
[ 1.043250] hub 10-0:1.0: 2 ports detected
[ 1.043365] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.046184] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.046189] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.046317] mousedev: PS/2 mouse device common for all mice
[ 1.046466] rtc_cmos 00:01: RTC can wake from S4
[ 1.046583] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.046606] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 1.046614] i2c /dev entries driver
[ 1.046659] device-mapper: uevent: version 1.0.3
[ 1.046723] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 1.046746] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.047340] NET: Registered protocol family 10
[ 1.047721] NET: Registered protocol family 17
[ 1.047736] Key type dns_resolver registered
[ 1.048119] microcode: CPU0 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048160] microcode: CPU1 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048167] microcode: CPU2 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048210] microcode: CPU3 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048266] microcode: CPU4 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048303] microcode: CPU5 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048316] microcode: CPU6 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048353] microcode: CPU7 sig=0x106a5, pf=0x2, revision=0xf
[ 1.048411] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.048630] registered taskstats version 1
[ 1.048643] Loading compiled-in X.509 certificates
[ 1.049595] Loaded X.509 cert 'Build time autogenerated kernel key: 11f495fa9f4186f263f5fd144a167c99990e2f12'
[ 1.049616] zswap: loaded using pool lzo/zbud
[ 1.051639] Key type trusted registered
[ 1.055254] Key type encrypted registered
[ 1.055262] AppArmor: AppArmor sha1 policy hashing enabled
[ 1.055268] ima: No TPM chip found, activating TPM-bypass!
[ 1.055293] evm: HMAC attrs: 0x1
[ 1.055833] Magic number: 5:258:292
[ 1.055873] tty tty25: hash matches
[ 1.055910] memory memory154: hash matches
[ 1.056221] rtc_cmos 00:01: setting system clock to 2017-02-22 18:15:49 UTC (1487787349)
[ 1.058271] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.058272] EDD information not available.
[ 1.058315] PM: Hibernation image not present or could not be loaded.
[ 1.335584] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.335611] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 1.346299] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.617113] usb 1-1: New USB device found, idVendor=048d, idProduct=1336
[ 1.617118] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.617121] usb 1-1: Product: Mass Storage Device
[ 1.617123] usb 1-1: Manufacturer: Generic
[ 1.617126] usb 1-1: SerialNumber: 00000000000006
[ 1.663573] ata2.00: SATA link down (SStatus 0 SControl 300)
[ 1.663586] ata2.01: SATA link down (SStatus 0 SControl 300)
[ 1.800920] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.800933] ata1.01: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.817230] ata1.00: ATA-9: ST2000DM001-1ER164, CC25, max UDMA/133
[ 1.817235] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.817445] ata1.01: ATA-9: WDC WD20EZRX-00D8PB0, 80.00A80, max UDMA/133
[ 1.817449] ata1.01: 3907029168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.833240] ata1.00: configured for UDMA/133
[ 1.841253] ata1.01: configured for UDMA/133
[ 1.841639] scsi 0:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC25 PQ: 0 ANSI: 5
[ 1.842215] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.842256] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.842262] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 1.842714] sd 0:0:0:0: [sda] Write Protect is off
[ 1.842720] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.842828] scsi 0:0:1:0: Direct-Access ATA WDC WD20EZRX-00D 0A80 PQ: 0 ANSI: 5
[ 1.842923] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.843325] sd 0:0:1:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[ 1.843330] sd 0:0:1:0: [sdb] 4096-byte physical blocks
[ 1.843333] sd 0:0:1:0: Attached scsi generic sg1 type 0
[ 1.843438] sd 0:0:1:0: [sdb] Write Protect is off
[ 1.843441] sd 0:0:1:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.843529] sd 0:0:1:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.858308] sda: sda1 sda2 sda3
[ 1.885020] sdb: sdb1
[ 1.885539] sd 0:0:1:0: [sdb] Attached SCSI disk
[ 1.885743] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.887837] Freeing unused kernel memory: 1488K (ffffffff81f45000 - ffffffff820b9000)
[ 1.887839] Write protecting the kernel read-only data: 14336k
[ 1.888787] Freeing unused kernel memory: 1776K (ffff880001844000 - ffff880001a00000)
[ 1.889280] Freeing unused kernel memory: 116K (ffff880001de3000 - ffff880001e00000)
[ 1.903857] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903919] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903931] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.903944] random: systemd-udevd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.904489] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.904530] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.905016] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.905067] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.905123] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.905168] random: udevadm: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.916838] usb 5-1: new full-speed USB device number 2 using uhci_hcd
[ 1.935765] FUJITSU Extended Socket Network Device Driver - version 1.0 - Copyright (c) 2015 FUJITSU LIMITED
[ 1.935956] wmi: Mapper loaded
[ 1.945340] ahci 0000:01:00.0: version 3.0
[ 1.945426] ahci 0000:01:00.0: controller can do FBS, turning on CAP_FBS
[ 1.946552] sky2: driver version 1.30
[ 1.946615] sky2 0000:05:00.0: Yukon-2 EC Ultra chip revision 3
[ 1.946878] sky2 0000:05:00.0 eth0: addr 20:cf:30:0b:0e:90
[ 1.947573] [drm] Initialized drm 1.1.0 20060810
[ 1.960792] ahci 0000:01:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl IDE mode
[ 1.960797] ahci 0000:01:00.0: flags: 64bit ncq fbs pio
[ 1.961914] scsi host4: ahci
[ 1.962029] scsi host5: ahci
[ 1.962136] scsi host6: ahci
[ 1.962246] scsi host7: ahci
[ 1.962346] scsi host8: ahci
[ 1.962449] scsi host9: ahci
[ 1.962554] scsi host10: ahci
[ 1.962655] scsi host11: ahci
[ 1.962718] ata5: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ff900 irq 36
[ 1.962721] ata6: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ff980 irq 36
[ 1.962723] ata7: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffa00 irq 36
[ 1.962725] ata8: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffa80 irq 36
[ 1.962728] ata9: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffb00 irq 36
[ 1.962730] ata10: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffb80 irq 36
[ 1.962733] ata11: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffc00 irq 36
[ 1.962736] ata12: SATA max UDMA/133 abar m2048@0xfb9ff800 port 0xfb9ffc80 irq 36
[ 1.982259] [drm] radeon kernel modesetting enabled.
[ 1.984496] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 1.984498] AMD IOMMUv2 functionality not available on this system
[ 1.988192] CRAT table not found
[ 1.988194] Finished initializing topology ret=0
[ 1.988535] kfd kfd: Initialized module
[ 1.988696] tsc: Refined TSC clocksource calibration: 2806.362 MHz
[ 1.988699] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2873baf475a, max_idle_ns: 440795305123 ns
[ 1.988771] checking generic (c0000000 5b0000) vs hw (c0000000 10000000)
[ 1.988773] fb: switching to radeondrmfb from VESA VGA
[ 1.988801] Console: switching to colour dummy device 80x25
[ 1.989204] [drm] initializing kernel modesetting (REDWOOD 0x1002:0x68DA 0x174B:0x1621).
[ 1.989216] [drm] register mmio base: 0xFBBC0000
[ 1.989217] [drm] register mmio size: 131072
[ 1.989253] ATOM BIOS: REDWOOD
[ 1.989333] radeon 0000:03:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
[ 1.989335] radeon 0000:03:00.0: GTT: 1024M 0x0000000080000000 - 0x00000000BFFFFFFF
[ 1.989337] [drm] Detected VRAM RAM=2048M, BAR=256M
[ 1.989338] [drm] RAM width 128bits DDR
[ 1.989378] [TTM] Zone kernel: Available graphics memory: 11307720 kiB
[ 1.989380] [TTM] Zone dma32: Available graphics memory: 2097152 kiB
[ 1.989381] [TTM] Initializing pool allocator
[ 1.989385] [TTM] Initializing DMA pool allocator
[ 1.989399] [drm] radeon: 2048M of VRAM memory ready
[ 1.989400] [drm] radeon: 1024M of GTT memory ready.
[ 1.989408] [drm] Loading REDWOOD Microcode
[ 1.989461] [drm] Internal thermal controller with fan control
[ 1.990152] sky2 0000:05:00.0 enp5s0: renamed from eth0
[ 2.012286] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 2.012375] scsi host12: usb-storage 1-1:1.0
[ 2.012450] usbcore: registered new interface driver usb-storage
[ 2.014106] usbcore: registered new interface driver uas
[ 2.018611] firewire_ohci 0000:07:02.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[ 2.020885] [drm] radeon: dpm initialized
[ 2.021018] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 2.021713] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 2.068115] [drm] PCIE GART of 1024M enabled (table at 0x000000000025E000).
[ 2.068252] radeon 0000:03:00.0: WB enabled
[ 2.068255] radeon 0000:03:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00 and cpu addr 0xffff8800357c5c00
[ 2.068257] radeon 0000:03:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c and cpu addr 0xffff8800357c5c0c
[ 2.069189] radeon 0000:03:00.0: fence driver on ring 5 use gpu addr 0x000000000005c418 and cpu addr 0xffffc9000381c418
[ 2.069191] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.069192] [drm] Driver supports precise vblank timestamp query.
[ 2.069193] radeon 0000:03:00.0: radeon: MSI limited to 32-bit
[ 2.069224] radeon 0000:03:00.0: radeon: using MSI.
[ 2.069250] [drm] radeon: irq initialized.
[ 2.085993] [drm] ring test on 0 succeeded in 1 usecs
[ 2.086001] [drm] ring test on 3 succeeded in 2 usecs
[ 2.128787] usb 5-1: New USB device found, idVendor=062a, idProduct=4101
[ 2.128789] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.128792] usb 5-1: Product: 2.4G Keyboard Mouse
[ 2.128793] usb 5-1: Manufacturer: MOSART Semi.
[ 2.135673] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.142930] usbcore: registered new interface driver usbhid
[ 2.142931] usbhid: USB HID core driver
[ 2.144449] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.0/0003:062A:4101.0001/input/input5
[ 2.197063] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:1a.2-1/input0
[ 2.197326] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:1a.2/usb5/5-1/5-1:1.1/0003:062A:4101.0002/input/input6
[ 2.253437] hid-generic 0003:062A:4101.0002: input,hiddev0,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:1a.2-1/input1
[ 2.261761] [drm] ring test on 5 succeeded in 1 usecs
[ 2.261767] [drm] UVD initialized successfully.
[ 2.262001] [drm] ib test on ring 0 succeeded in 0 usecs
[ 2.262035] [drm] ib test on ring 3 succeeded in 0 usecs
[ 2.288803] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.288823] ata10: SATA link down (SStatus 0 SControl 300)
[ 2.288841] ata5: SATA link down (SStatus 0 SControl 300)
[ 2.288858] ata11: SATA link down (SStatus 0 SControl 300)
[ 2.288878] ata12: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.288896] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.288912] ata9: SATA link down (SStatus 0 SControl 300)
[ 2.288927] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.288974] ata12.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66
[ 2.289104] ata12.00: configured for UDMA/66
[ 2.297179] scsi 11:0:0:0: Processor Marvell 91xx Config 1.01 PQ: 0 ANSI: 5
[ 2.312786] ata12.00: exception Emask 0x1 SAct 0x0 SErr 0x0 action 0x6
[ 2.312789] ata12.00: irq_stat 0x40000001
[ 2.312796] ata12.00: cmd a0/01:00:00:00:01/00:00:00:00:00/a0 tag 1 dma 16640 in
Inquiry 12 01 00 00 ff 00res 00/00:00:00:00:00/00:00:00:00:00/00 Emask 0x3 (HSM violation)
[ 2.312799] ata12: hard resetting link
[ 2.520906] firewire_core 0000:07:02.0: created device fw0: GUID 001fc6000000eb61, S400
[ 2.640775] ata12: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.641064] ata12.00: configured for UDMA/66
[ 2.641138] ata12: EH complete
[ 2.641595] scsi 11:0:0:0: Attached scsi generic sg2 type 3
[ 2.908802] [drm] ib test on ring 5 succeeded
[ 2.910176] [drm] Radeon Display Connectors
[ 2.910178] [drm] Connector 0:
[ 2.910179] [drm] HDMI-A-1
[ 2.910180] [drm] HPD2
[ 2.910181] [drm] DDC: 0x6470 0x6470 0x6474 0x6474 0x6478 0x6478 0x647c 0x647c
[ 2.910182] [drm] Encoders:
[ 2.910183] [drm] DFP1: INTERNAL_UNIPHY2
[ 2.910184] [drm] Connector 1:
[ 2.910184] [drm] DVI-I-1
[ 2.910185] [drm] HPD1
[ 2.910186] [drm] DDC: 0x6460 0x6460 0x6464 0x6464 0x6468 0x6468 0x646c 0x646c
[ 2.910187] [drm] Encoders:
[ 2.910187] [drm] DFP2: INTERNAL_UNIPHY1
[ 2.910188] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 2.910189] [drm] Connector 2:
[ 2.910190] [drm] VGA-1
[ 2.910191] [drm] DDC: 0x6430 0x6430 0x6434 0x6434 0x6438 0x6438 0x643c 0x643c
[ 2.910192] [drm] Encoders:
[ 2.910192] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 3.017676] clocksource: Switched to clocksource tsc
[ 3.018495] scsi 12:0:0:0: Direct-Access Generic Storage Device 0.00 PQ: 0 ANSI: 2
[ 3.018852] sd 12:0:0:0: Attached scsi generic sg3 type 0
[ 3.020420] sd 12:0:0:0: [sdc] Attached SCSI removable disk
[ 3.052243] [drm] fb mappable at 0xC045F000
[ 3.052244] [drm] vram apper at 0xC0000000
[ 3.052245] [drm] size 8294400
[ 3.052246] [drm] fb depth is 24
[ 3.052247] [drm] pitch is 7680
[ 3.052447] fbcon: radeondrmfb (fb0) is primary device
[ 3.052594] Console: switching to colour frame buffer device 160x64
[ 3.052641] radeon 0000:03:00.0: fb0: radeondrmfb frame buffer device
[ 3.064989] [drm] Initialized radeon 2.43.0 20080528 for 0000:03:00.0 on minor 0
[ 3.065026] radeon 0000:04:00.0: enabling device (0000 -> 0003)
[ 3.065410] [drm] initializing kernel modesetting (RV710 0x1002:0x9540 0x1458:0x21AE).
[ 3.065429] [drm] register mmio base: 0xFBCE0000
[ 3.065432] [drm] register mmio size: 65536
[ 3.177532] ATOM BIOS: GV
[ 3.177545] [drm] GPU not posted. posting now...
[ 3.178864] radeon 0000:04:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 3.178866] radeon 0000:04:00.0: GTT: 1024M 0x0000000020000000 - 0x000000005FFFFFFF
[ 3.178867] [drm] Detected VRAM RAM=512M, BAR=256M
[ 3.178868] [drm] RAM width 64bits DDR
[ 3.178875] [drm] radeon: 512M of VRAM memory ready
[ 3.178876] [drm] radeon: 1024M of GTT memory ready.
[ 3.178884] [drm] Loading RV710 Microcode
[ 3.178934] [drm] Internal thermal controller with fan control
[ 3.184041] [drm] radeon: dpm initialized
[ 3.184102] [drm] GART: num cpu pages 262144, num gpu pages 262144
[ 3.184792] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 3.186750] [drm] PCIE GART of 1024M enabled (table at 0x000000000025E000).
[ 3.186810] radeon 0000:04:00.0: WB enabled
[ 3.186813] radeon 0000:04:00.0: fence driver on ring 0 use gpu addr 0x0000000020000c00 and cpu addr 0xffff88059c977c00
[ 3.186814] radeon 0000:04:00.0: fence driver on ring 3 use gpu addr 0x0000000020000c0c and cpu addr 0xffff88059c977c0c
[ 3.187408] radeon 0000:04:00.0: fence driver on ring 5 use gpu addr 0x000000000005c598 and cpu addr 0xffffc9000501c598
[ 3.187409] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.187410] [drm] Driver supports precise vblank timestamp query.
[ 3.187411] radeon 0000:04:00.0: radeon: MSI limited to 32-bit
[ 3.187436] radeon 0000:04:00.0: radeon: using MSI.
[ 3.187461] [drm] radeon: irq initialized.
[ 3.234096] [drm] ring test on 0 succeeded in 1 usecs
[ 3.234103] [drm] ring test on 3 succeeded in 2 usecs
[ 3.408745] [drm] ring test on 5 succeeded in 1 usecs
[ 3.408750] [drm] UVD initialized successfully.
[ 3.408967] [drm] ib test on ring 0 succeeded in 0 usecs
[ 3.408987] [drm] ib test on ring 3 succeeded in 0 usecs
[ 4.056886] [drm] ib test on ring 5 succeeded
[ 4.059001] [drm] Radeon Display Connectors
[ 4.059003] [drm] Connector 0:
[ 4.059004] [drm] VGA-2
[ 4.059005] [drm] DDC: 0x7e50 0x7e50 0x7e54 0x7e54 0x7e58 0x7e58 0x7e5c 0x7e5c
[ 4.059006] [drm] Encoders:
[ 4.059007] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 4.059007] [drm] Connector 1:
[ 4.059008] [drm] HDMI-A-2
[ 4.059009] [drm] HPD1
[ 4.059010] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 4.059011] [drm] Encoders:
[ 4.059011] [drm] DFP1: INTERNAL_UNIPHY
[ 4.059012] [drm] Connector 2:
[ 4.059013] [drm] DVI-I-2
[ 4.059014] [drm] HPD4
[ 4.059015] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 4.059015] [drm] Encoders:
[ 4.059016] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 4.059017] [drm] DFP2: INTERNAL_UNIPHY2
[ 4.112064] [drm] fb mappable at 0xD045F000
[ 4.112066] [drm] vram apper at 0xD0000000
[ 4.112066] [drm] size 5242880
[ 4.112067] [drm] fb depth is 24
[ 4.112068] [drm] pitch is 5120
[ 4.112242] radeon 0000:04:00.0: fb1: radeondrmfb frame buffer device
[ 4.112404] [drm] Initialized radeon 2.43.0 20080528 for 0000:04:00.0 on minor 1
[ 4.956788] floppy0: no floppy controllers found
[ 5.484770] raid6: sse2x1 gen() 7255 MB/s
[ 5.552773] raid6: sse2x1 xor() 5658 MB/s
[ 5.620741] raid6: sse2x2 gen() 8571 MB/s
[ 5.688772] raid6: sse2x2 xor() 6666 MB/s
[ 5.756773] raid6: sse2x4 gen() 9827 MB/s
[ 5.824773] raid6: sse2x4 xor() 7306 MB/s
[ 5.824775] raid6: using algorithm sse2x4 gen() 9827 MB/s
[ 5.824776] raid6: .... xor() 7306 MB/s, rmw enabled
[ 5.824777] raid6: using ssse3x2 recovery algorithm
[ 5.826082] xor: measuring software checksum speed
[ 5.864689] prefetch64-sse: 12345.000 MB/sec
[ 5.904694] generic_sse: 10897.000 MB/sec
[ 5.904695] xor: using function: prefetch64-sse (12345.000 MB/sec)
[ 5.919767] Btrfs loaded
[ 5.932189] random: nonblocking pool is initialized
[ 6.111391] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.837301] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 6.837457] systemd[1]: Detected architecture x86-64.
[ 6.841243] systemd[1]: Set hostname to <io-serena>.
[ 7.789537] systemd[1]: Listening on udev Kernel Socket.
[ 7.789614] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.789644] systemd[1]: Listening on LVM2 poll daemon socket.
[ 7.789654] systemd[1]: Reached target Remote File Systems (Pre).
[ 7.789687] systemd[1]: Listening on Journal Socket.
[ 7.789711] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 7.789784] systemd[1]: Created slice User and Session Slice.
[ 7.789885] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 7.789916] systemd[1]: Listening on LVM2 metadata daemon socket.
[ 7.789976] systemd[1]: Created slice System Slice.
[ 7.808813] systemd[1]: Starting Load Kernel Modules...
[ 7.864837] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 7.864943] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 7.865309] systemd[1]: Started Braille Device Support.
[ 7.865873] systemd[1]: Started Read required files in advance.
[ 7.866471] systemd[1]: Starting Set console keymap...
[ 7.866505] systemd[1]: Reached target Slices.
[ 7.866892] systemd[1]: Mounting Debug File System...
[ 7.866970] systemd[1]: Listening on udev Control Socket.
[ 7.867479] systemd[1]: Starting Uncomplicated firewall...
[ 7.867537] systemd[1]: Listening on Journal Socket (/dev/log).
[ 7.868011] systemd[1]: Mounting POSIX Message Queue File System...
[ 7.888881] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 7.888901] systemd[1]: Reached target User and Group Name Lookups.
[ 7.889251] systemd[1]: Mounting Huge Pages File System...
[ 7.889301] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 7.889653] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 7.889670] systemd[1]: Reached target Encrypted Volumes.
[ 7.889737] systemd[1]: Listening on Journal Audit Socket.
[ 7.889766] systemd[1]: Listening on Syslog Socket.
[ 7.890130] systemd[1]: Starting Journal Service...
[ 7.890154] systemd[1]: Reached target Remote File Systems.
[ 7.992406] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 8.019068] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.070126] systemd[1]: Started Uncomplicated firewall.
[ 8.132688] lp: driver loaded but no devices found
[ 8.136571] ppdev: user-space parallel port driver
[ 8.232736] systemd[1]: Mounted Debug File System.
[ 8.232820] systemd[1]: Mounted POSIX Message Queue File System.
[ 8.232883] systemd[1]: Mounted Huge Pages File System.
[ 8.279402] systemd[1]: Started Load Kernel Modules.
[ 8.300897] systemd[1]: Starting Apply Kernel Variables...
[ 8.301319] systemd[1]: Mounting FUSE Control File System...
[ 8.303536] systemd[1]: Mounted FUSE Control File System.
[ 8.329986] systemd[1]: Started Journal Service.
[ 9.426439] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 9.571638] systemd-journald[415]: Received request to flush runtime journal from PID 1
[ 9.885112] i5500_temp 0000:00:14.3: Sensor seems to be disabled
[ 9.935421] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20150930/utaddress-254)
[ 9.935427] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.935430] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20150930/utaddress-254)
[ 9.935433] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.935434] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x000000000000053F (\GPS0) (20150930/utaddress-254)
[ 9.935437] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 9.935437] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 10.019569] EDAC MC: Ver: 3.0.0
[ 10.055588] EDAC MC0: Giving out device to module i7core_edac.c controller i7 core #0: DEV 0000:ff:03.0 (POLLED)
[ 10.055630] EDAC PCI0: Giving out device to module i7core_edac controller EDAC PCI controller: DEV 0000:ff:03.0 (POLLED)
[ 10.055636] EDAC i7core: Driver loaded, 1 memory controller(s) found.
[ 10.067523] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.396598] kvm: VM_EXIT_LOAD_IA32_PERF_GLOBAL_CTRL does not work properly. Using workaround
[ 10.661670] snd_hda_intel 0000:03:00.1: Handle vga_switcheroo audio client
[ 10.661773] snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
[ 10.697266] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/0000:03:00.1/sound/card1/input7
[ 10.697526] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:07.0/0000:04:00.1/sound/card2/input8
[ 10.723310] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC889: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 10.723313] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 10.723315] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 10.723316] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 10.723318] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 10.723319] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 10.723321] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 10.723323] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 10.723324] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 10.738366] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 10.738471] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 10.738584] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 10.738698] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 10.738804] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 10.738888] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 10.738978] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 10.739062] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 11.039555] Adding 9764860k swap on /dev/sda1. Priority:-1 extents:1 across:9764860k FS
[ 11.600120] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ 12.548487] cgroup: new mount options do not match the existing superblock, will be ignored
[ 12.812815] floppy0: no floppy controllers found
[ 12.812828] work still pending
[ 14.068181] vboxdrv: module verification failed: signature and/or required key missing - tainting kernel
[ 14.071389] vboxdrv: Found 8 processor cores
[ 14.088912] vboxdrv: TSC mode is Invariant, tentative frequency 2806352425 Hz
[ 14.088914] vboxdrv: Successfully loaded version 5.1.14 (interface 0x00280000)
[ 14.319360] VBoxNetFlt: Successfully started.
[ 14.386004] VBoxNetAdp: Successfully started.
[ 14.489471] VBoxPciLinuxInit
[ 14.557937] vboxpci: IOMMU not found (not registered)
[ 17.228423] IPv6: ADDRCONF(NETDEV_UP): enp5s0: link is not ready
[ 17.231451] sky2 0000:05:00.0 enp5s0: enabling interface
[ 17.231656] IPv6: ADDRCONF(NETDEV_UP): enp5s0: link is not ready
[ 17.985470] vgaarb: device changed decodes: PCI:0000:04:00.0,olddecodes=io+mem,decodes=none:owns=none
[ 17.985474] vgaarb: device changed decodes: PCI:0000:03:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 18.989407] sky2 0000:05:00.0 enp5s0: Link is up at 100 Mbps, full duplex, flow control both
[ 18.989422] IPv6: ADDRCONF(NETDEV_CHANGE): enp5s0: link becomes ready
karrik, дайте вывод
cat /sys/kernel/debug/vgaswitcheroo/switch
Для обоих случаев
Для обоих случаев
SemenSinchenko, "Дело в том, что у меня ни бамблби, ни вгасвитчероо нет; в ядро вгасвитчероо встроен, но файл настроек не появляется, бамблби вообще не нашел..."
mount debugfs пытался - не работает.
cat: /sys/kernel/debug/vgaswitcheroo/switch: Нет такого файла или каталога
karrik, может наудачу попробовать добавить radeon.runpm=0 к параметрам ядра в GRUB?
Тогда управление должно перейти на vgaswitcheroo наверное.
Понятно, что она просто вырублена, поэтому и failed to set DRM interface version 1.4: Permission denied?, но как это вообще может быть связано с демоном самбы...
Ну и давайте попробуем все же завести иксы без ДМ, в tty1 sudo start-stop-daemon -stop /usr/bin/sddm, а потом startx
SemenSinchenko, это предварительно при работе всех мониторов:
Заенаблил демон тимвьюера, перезагрузился, воспряли 2 моника, далее перешел в tty1:
таж херня:
ну, и, в tty1 через startx запустились все 3 моника с нулевыми настройками KDE
Есть мысли?
у меня остается ощущение, что не успевает что-то догрузиться(((
user@io-serena ~ $ sudo start-stop-daemon --stop --name /usr/bin/sddm
[sudo] пароль для user:
No /usr/bin/sddm found running; none killed.
user@io-serena ~ $ sudo start-stop-daemon --stop --name /usr/bin/kdm
No /usr/bin/kdm found running; none killed.
таж херня:
Есть мысли?
SemenSinchenko, гениально!
Что-то не успевает догрузиться до X-ов!
если в "плохом режиме" загрузиться(reboot), и после загрузки выйти из сеанса и заново зайти(X-ы перезагрузятся) - все ОК!
теперь есть мысли?)
теперь есть мысли?)
karrik, попробуйте другой dm. Например lightdm. Или что то такое. А что там в xinit? И в xinit.rc?
SemenSinchenko, подскажите как можно попробовать другой dm? я пока не понимаю((( на разбирательства уйдет некое время...
в xinit... /etc/X11/xinit:
user@io-serena ~ $ sudo ls -ABl /etc/X11/xinit/
итого 16
-rwxr-xr-x 1 root root 164 апр 26 2016 xinitrc
drwxr-xr-x 2 root root 4096 апр 12 2016 xinitrc.d
-rw-r--r-- 1 root root 134 мар 21 2015 xinputrc
-rwxr-xr-x 1 root root 46 апр 26 2016 xserverrc
далее...
xinitrc
xinputrc:
xserverrc:
xinitrc.d - папка - пусто
Но, у меня все же вопрос: я написал если запускать даже проблемный вариант, затем просто рестартовать иксы все работает...
может я чего-то не понимаю?(
итого 16
далее...
xinitrc
#!/bin/sh
# /etc/X11/xinit/xinitrc
# global xinitrc file, used by all X sessions started by xinit (startx)
# invoke global X session script
. /etc/X11/Xsession
. /etc/X11/Xsession
GNU nano 2.5.3 Файл: /etc/X11/xinit/xinputrc
# im-config(8) generated on Sun, 30 Mar 2014 02:45:02 +0900
run_im default
# im-config signature: d57688c8151277a0c25d15aa0523da6b -
run_im default
#!/bin/sh
exec /usr/bin/X -nolisten tcp "$@"
karrik, ну по моему это ещё один костыль будет - создать свой xinitrc, который два раза подряд запускает иксы.
А попытка дописать radeon.runpm=0 к параметрам ядра не дало эффекта?
SemenSinchenko, никакого эффекта вообще((
мысли я так понимаю заканчиваются?
karrik, к сожалению да....
Последнее - попробуйте собрать самбу из stable-ветки дебиана. В тестинг ветке бывает такое, что драйвера не успевают за обновлениями и т.д.
