flatpak install flathub com.teamspeak.TeamSpeak
Looking for matches…
com.teamspeak.TeamSpeak permissions:
ipc network pulseaudio x11
dri file access [1] tags [2]
[1] xdg-download
[2] proprietary
ID Ветка Op Удалённый репозиторий Download
1. [✗] com.teamspeak.TeamSpeak stable i flathub 1.0 kB / 100,2 MB
Error: Во время загрузки https://files.teamspeak-services.com/re ... -3.5.6.run: Недопустимый сертификат TLS
ошибка: Failed to установить com.teamspeak.TeamSpeak: Во время загрузки https://files.teamspeak-services.com/re ... -3.5.6.run: Недопустимый сертификат TLS
[1] xdg-download
[2] proprietary
Вопрос: как установить teamspeak ?
inxxi -Fxz прилагаю
Kernel: 5.4.0-74-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.2 Uma base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Extensa 2520G v: V1.15 serial: <filter>
Mobo: Acer model: BA50_SL v: V1.15 serial: <filter> UEFI [Legacy]: Insyde
v: 1.15 date: 05/13/2016
ID-1: BAT1 charge: 33.5 Wh condition: 33.5/37.0 Wh (90%)
model: SANYO AL15A32 status: Full
Topology: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP
arch: Skylake rev: 3 L2 cache: 3072 KiB
bogomips: 19200
Speed: 2623 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 2623 2: 2612
3: 2615 4: 2600
Device-1: Intel Skylake GT2 [HD Graphics 520]
Device-2: NVIDIA GK208BM [GeForce 920M] vendor: Acer Incorporated ALI
driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.9 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.0.3
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Sound Server: ALSA v: k5.4.0-74-generic
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 3000 bus ID: 03:00.0
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb
bus ID: 1-5:7
Local Storage: total: 465.76 GiB used: 50.46 GiB (10.8%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
ID-1: / size: 456.95 GiB used: 50.46 GiB (11.0%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 47.5 C mobo: N/A gpu: nouveau temp: 49 C
Processes: 269 Uptime: 2h 20m Memory: 7.65 GiB used: 3.06 GiB (40.0%)
inxi: 3.0.38
bogomips: 19200
3: 2615 4: 2600
bus ID: 01:00.1
bus ID: 02:00.0
bus ID: 1-5:7
inxi: 3.0.38
