Драйвер wifi Qualcomm Device 1103 (rev 01)
Sidorsan
08 мар 2022, 04:30
Всем привет, не получается установить драйвер WI-FI на ноутбук Honor magicbook 16 (2022). Весь интернет перерыл.
08 мар 2022, 09:31
Sidorsan, читай красное поле вверху страницы и дополни тему информацией
Sidorsan
08 мар 2022, 17:20
Linux Mint 20.3 Una
Kernel: 5.4.0-100-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
Desktop: Xfce 4.16.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: HONOR product: HYM-WXX v: M1010 serial: <filter>
Mobo: HONOR model: HYM-WXX-PCB v: M1010 serial: <filter> UEFI: HONOR
v: 2.06 date: 12/07/2021
ID-1: BAT0 charge: 39.0 Wh condition: 56.2/55.3 Wh (102%)
model: Sunwoda- HB6181V1ECW-41 status: Unknown
Topology: 6-Core model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 79050
Speed: 1206 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1260 2: 1277
3: 1297 4: 1297 5: 1135 6: 1135 7: 1135 8: 1135 9: 1135 10: 1135 11: 1135
12: 1134
Device-1: AMD driver: N/A bus ID: 04:00.0
Display: x11 server: X.Org 1.20.13 driver: ati,fbdev
unloaded: modesetting,radeon,vesa resolution: 1920x1080~77Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.2.6
Device-1: AMD driver: snd_hda_intel v: kernel bus ID: 04:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
bus ID: 04:00.5
Device-3: AMD Family 17h HD Audio driver: snd_hda_intel v: kernel
bus ID: 04:00.6
Sound Server: ALSA v: k5.4.0-100-generic
Device-1: Qualcomm vendor: Foxconn driver: N/A port: N/A bus ID: 02:00.0
IF-ID-1: usb0 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 1.38 TiB used: 9.28 GiB (0.7%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL2512HCJQ-00B00
ID-2: /dev/sda type: USB vendor: JMicron Tech model: N/A size: 931.51 GiB
ID-1: / size: 244.50 GiB used: 9.23 GiB (3.8%) fs: ext4 dev: /dev/sda2
Message: No sensors data was found. Is sensors configured?
Processes: 280 Uptime: 4m Memory: 15.06 GiB used: 1.24 GiB (8.2%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
08 мар 2022, 17:54
Sidorsan, покажи еще вывод
lspci -knn | grep -A2 Net
И обнови ядро до максимально возможного Менеджер обновлений => Вид => Ядро линукс
Sidorsan
08 мар 2022, 18:05
02:00.0 Network controller [0280]: Qualcomm Device [17cb:1103] (rev 01)
Subsystem: Foxconn International, Inc. Device [105b:e0ca]
03:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd Device [144d:a80a]
Ядро обновил, не помогло.
Последний раз редактировалось пользователем 1 Sidorsan; всего редактировалось раз: 8
08 мар 2022, 18:17
Sidorsan, ставь ядро 5.14, драйвер в ядре с этой версии
Обычной сетевухи, как я понимаю, на этом ноуте нет. Остается только вариант подключить телефон к ноуту проводом и раздать инет
Sidorsan
08 мар 2022, 18:24
Как установить 5.14? В менеджере обновлений только 5.13.
08 мар 2022, 18:41
Sidorsan, только так https://github.com/bkw777/mainline
Ну и я тогда посоветовал бы ставить ядро 5.15 т.к. оно lts, а 5.14 уже EOL
Sidorsan
08 мар 2022, 20:44
Установил
Kernel: 5.16.11-051611-generic x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.16.0
tk: Gtk 3.24.20 wm: xfwm4 dm: LightDM Distro: Linux Mint 20.3 Una
драйвер так и не появился.
09 мар 2022, 06:11
Sidorsan писал(а):
08 мар 2022, 20:44
Попробуй это https://wireless.wiki.kernel.org/en/use ... stallation Только ядро не ставь, которое 5.10. Сразу firmware скопируй
Sidorsan
09 мар 2022, 15:51
vir0id писал(а):
09 мар 2022, 06:11
Попробовал, драйвер не появился.
09 мар 2022, 17:47
Sidorsan писал(а):
09 мар 2022, 15:51
драйвер не появился
Покажи
sudo lsmod | grep ath
Sidorsan
09 мар 2022, 17:53
Покажи
ath11k_pci             28672  0
ath11k                524288  1 ath11k_pci
qmi_helpers            32768  1 ath11k
mac80211             1241088  1 ath11k
cfg80211              974848  2 ath11k,mac80211
mhi                    94208  2 ath11k_pci,qrtr_mhi
09 мар 2022, 18:21
sudo rfkill list
Sidorsan
09 мар 2022, 18:34
vir0id писал(а):
09 мар 2022, 18:21
sudo rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
09 мар 2022, 20:28
А у тебя firmware-atheros установлен?
Решено: 31
10 мар 2022, 02:44
vir0id писал(а):
09 мар 2022, 20:28
firmware-atheros
Так автору, наверное, нужно дать источник получения. Я у себя в синаптике такого не нашёл. Или оно с новым ядром атоматически прилетает? На pkgs.org пакет только для Debian.
10 мар 2022, 06:35
madesta писал(а):
10 мар 2022, 02:44
По идеи должно. Возможно пакет иначе называется в минте. Может быть он уже включен в пакет linux-firmware, я точно не уверен
Sidorsan
10 мар 2022, 15:15
vir0id писал(а):
09 мар 2022, 20:28
Не знаю, как проверить?
10 мар 2022, 15:20
Для интереса попробуй live-сесии fedora или manjaro. Будет ли там wifi работать.
Вернуться в «Работа с сетью»
