Блютуза как бы нет
Sander
Благодарил (а): 25 раз
Блютуза как бы нет
18 апр 2022, 16:43
Купил ноутбук
Kernel: 5.4.0-107-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: Cinnamon 5.2.7 Distro: Linux Mint 20.3 Una
base: Ubuntu 20.04 focal
Type: Laptop System: HP product: HP Laptop 15-dw1xxx
v: Type1ProductConfigId serial: <filter>
Mobo: HP model: 85F1 v: 37.28 serial: <filter> UEFI: Insyde v: F.41
date: 12/21/2020
ID-1: BAT1 charge: 39.6 Wh condition: 41.9/41.0 Wh (102%)
model: Hewlett-Packard PABAS0241231 status: Discharging
Topology: Dual Core model: Intel Pentium 6405U bits: 64 type: MT MCP
arch: Kaby Lake rev: C L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19200
Speed: 800 MHz min/max: 400/2400 MHz Core speeds (MHz): 1: 800 2: 800
3: 801 4: 800
Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.13 driver: modesetting
unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT1) v: 4.6 Mesa 21.2.6
Device-1: Intel vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Sound Server: ALSA v: k5.4.0-107-generic
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 01:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8821ce v: v5.5.2.1_35598.20191029
port: 3000 bus ID: 02:00.0
Local Storage: total: 238.47 GiB used: 10.69 GiB (4.5%)
ID-1: /dev/nvme0n1 model: KXG60ZNV256G KIOXIA size: 238.47 GiB
ID-1: / size: 69.90 GiB used: 9.43 GiB (13.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 139.80 GiB used: 1.23 GiB (0.9%) fs: ext4
dev: /dev/nvme0n1p3
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 198 Uptime: 5h 23m Memory: 3.65 GiB used: 1.00 GiB (27.4%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
без ОС.
Установил Linux Mint 20.3.
В характеристиках блютуз присутствует (было бы странно если бы небыло), но система его не видит.
Покопался в сети ничего не помогло. Команда rfkill list выдаёт:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Блютуза как бы нет. Что скажете?
Блютуза как бы нет
18 апр 2022, 16:52
Sander, сделай пробу
Sander
Блютуза как бы нет
18 апр 2022, 18:21
Блютуза как бы нет
18 апр 2022, 19:04
Sander, попробуй ядро 5.13
Sander
Блютуза как бы нет
18 апр 2022, 19:28
18 апр 2022, 19:04
Ничего не поменялось
Блютуза как бы нет
18 апр 2022, 19:34
Sander, а на клавиатуре нет кнопок включения/выключения bluetooth?
Блютуза как бы нет
18 апр 2022, 19:59
Sander, проверь установлен ли пакет rtl8821ce-dkms
Sander
Блютуза как бы нет
18 апр 2022, 20:06
18 апр 2022, 19:34
Кнопки нет. Перепробовал все сочетания с fn- ничего.
18 апр 2022, 19:59
Установлен
Sander
Блютуза как бы нет
21 апр 2022, 12:56
Нашёл в сети инструкцию к ноутбуку. Никаких специальных кнопок или сочетани для включения блютуза нет. Кроме кнопки "В самолёте", которая должна отключать/ включать и вайфай и блютуз, но по факту с линуксом не работает. Обноружение и включение блютуз описаны только для винды. Кстати, вайфая при первом запуске тоже нет, пока через диспетчер драйверов не установишь rtl8821ce-dkms, который там нужно выбрать. Ну, то есть как выбрать, кроме него там ничег и нет- просто отметить точкой.
Что теперь? Забыть про блютуз на этом ноуте с линуксом или могут быть варианты?
Благодарил (а): 1218 раз
Блютуза как бы нет
21 апр 2022, 13:26
Sander писал(а):
21 апр 2022, 12:56
Воткни USB свисток блютуз
Решено: 37
Блютуза как бы нет
21 апр 2022, 13:44
Sander, из под винды посмотреть что за чип блютуз вкорячен и поискать исходники на него на гитхабе или уже может уже в ядрах новых он есть...
M_o_n_g_o_l
Благодарил (а): 77 раз
Блютуза как бы нет
21 апр 2022, 17:53
Sander, Приносили как-то давно ноут на обслугу, там попадалась такая хрень. По одному и тому же протоколу идут вместе и Wifi и Синезуб, под Win работало вроде исправно, а под Lin только Wifi. Кастую hellonet, воткни USB свисток.
Sander
Блютуза как бы нет
21 апр 2022, 22:34
hellonet писал(а):
21 апр 2022, 13:26
Да, это крайний вариант, если сложится ситуация, когда без блютуз никак. Сейчас же я просто разбираюсь с новоприобретённым девайсом и хотелось бы запустить все его возможности.
21 апр 2022, 13:44
Выше давал ссылку Probe, честно говоря я не невеликий спец, но во всех этих буквах которые выскакивают по ссылке, я никакого блютуз адаптера не обнаружил. Что же этот экстро-супер-мега проект всё таки не всё может рассмотреть в железе? Или это я не смог рассмотреть? Кто сможет вот это расшифровать?
eno1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether XXX txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet XXX netmask XXX
inet6 XXX prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 8873 bytes 963896 (963.8 KB)
TX packets 8873 bytes 963896 (963.8 KB)
wlo1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet XXX netmask XXX broadcast XXX
inet6 XXX prefixlen 64 scopeid 0x20<link>
RX packets 8943 bytes 1173993422 (1.1 GB)
RX errors 0 dropped 148 overruns 0 frame 0
TX packets 4621 bytes 40393479 (40.3 MB)
Блютуза как бы нет
22 апр 2022, 07:32
Sander писал(а):
21 апр 2022, 22:34
Там нечего расшифровывать - кол-во полученных/переданных пакетов/байтов тем или иным сетевым устройством.
Ставь винду, заводи там блютуз(если заведется) и выясняй что за чип для блютуз они вкорячили
В пробе не видать блютуз. Почему - это уже не относится к теме
Блютуза как бы нет
22 апр 2022, 07:48
22 апр 2022, 07:32
Может данная модель ноута вообще без блютуза? Я бы тоже на винде испытал. Можно ещё проверить версию адаптера Bluetooth через терминал:
sudo hcitool -a
У меня этого нет, но вдруг:
И ещё- в файле /boot/config.txt строка dtoverlay=pi3-disable-bt должна быть закомментирована. Если этого не сделать, то она отключит Bluetooth от UART и вместо этого соединит UART с выводами GPIO
Сотрудник
Блютуза как бы нет
22 апр 2022, 09:06
Sander, В BIOS ноутбука в настройках есть пункт настройки блютуз (может отключен). В менеджере программ найти и установить программы и драйвера для Bluetooth: Bluetooth, bluebery, bluez-tools, blueman и тд. Примеры команд для настройки в терминале Здесь все подробно по настройке.
Sander
Блютуза как бы нет
22 апр 2022, 09:38
hellonet писал(а):
22 апр 2022, 07:48
Ругается многоэтажно:
hcitool: invalid option -- 'a'
hcitool - HCI Tool ver 5.48
Usage:
hcitool [options] <command> [command parameters]
Options:
--help Display help
-i dev HCI device
Commands:
dev Display local devices
inq Inquire remote devices
scan Scan for remote devices
name Get name from remote device
info Get information from remote device
spinq Start periodic inquiry
epinq Exit periodic inquiry
cmd Submit arbitrary HCI commands
con Display active connections
cc Create connection to remote device
dc Disconnect from remote device
sr Switch master/slave role
cpt Change connection packet type
rssi Display connection RSSI
lq Display link quality
tpl Display transmit power level
afh Display AFH channel map
lp Set/display link policy settings
lst Set/display link supervision timeout
auth Request authentication
enc Set connection encryption
key Change connection link key
clkoff Read clock offset
clock Read local or remote clock
lescan Start LE scan
leinfo Get LE remote information
lewladd Add device to LE White List
lewlrm Remove device from LE White List
lewlsz Read size of LE White List
lewlclr Clear LE White List
lerladd Add device to LE Resolving List
lerlrm Remove device from LE Resolving List
lerlclr Clear LE Resolving List
lerlsz Read size of LE Resolving List
lerlon Enable LE Address Resolution
lerloff Disable LE Address Resolution
lecc Create a LE Connection
ledc Disconnect a LE Connection
lecup LE Connection Update
For more information on the usage of each command use:
hcitool <command> --help
hellonet писал(а):
22 апр 2022, 07:48
У меня тоже нет
Sander
Блютуза как бы нет
22 апр 2022, 09:44
Сотрудник писал(а):
22 апр 2022, 09:06
Не нету. Я туда сразу полез. Настройки БИОС на этом ноуте вообще какие то беднненькие.
Сотрудник писал(а):
22 апр 2022, 09:06
Этим сейчас и займусь, спасибо.
Sander
Блютуза как бы нет
22 апр 2022, 10:11
Сотрудник писал(а):
22 апр 2022, 09:06
В общем этим я тоже уже занимался. Только Блюеман не ставил. Но он тоже ничего не изменил, так как опять всё упирается в блютузадаптер.
Хорошо, спасибо всем кто пытался помочь. Теперь попробую установить винду.
Блютуза как бы нет
22 апр 2022, 10:42
Сотрудник писал(а):
22 апр 2022, 09:06
И Здесь
