Transmission проблемы с загрузкой
Isemann
Благодарил (а): 2 раза
27 авг 2022, 12:50
Linux Mint 21 x64 Vanessa Cinnamon
Параметры
Kernel: 5.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.11 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4400 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 801 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 515.65.01 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 515.65.01 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.15.0-46-generic running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.14 TiB used: 54.31 GiB (4.7%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 37.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-1: / size: 93.31 GiB used: 14.39 GiB (15.4%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 5.2 MiB (1.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 10.12 GiB (8.6%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 303 Uptime: 1h 9m Memory: 15.46 GiB used: 2.39 GiB (15.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 2486 Shell: Bash
v: 5.1.16 inxi: 3.3.13
При попытке загрузить файл на жесткий диск выдает ошибку: Ошибка ввода-вывода, отказано в доступе. К тому же не удается переместить файлы из /home/username в /home/data. хотя Timeshift без проблем сохраняет туда снимки.
HDD WesternDigital 1Tb смонтирован как /home/data
warning
Решено: 7
Благодарил (а): 161 раз
27 авг 2022, 13:07
1. В топике указано transmission как тореент клиент, а на скриншоте qbittorrent.
2. Попробуйте все таки воспользоваться transmission и посмотреть если проблема останется
3. Проверить раздел на битые блоки (badblocks и fsck в помощь)
hw-probe: тыц!
warning
Решено: 7
27 авг 2022, 13:10
UPD: глянул на скриншот еще раз после отправки своего сообщения и, думается мне, топик стартер уже подменил скриншот на другой... вот засада...
hw-probe: тыц!
warning
Решено: 7
27 авг 2022, 13:19
Есть еще совет на убунтовском форуме:
"НАСТРОЙКАХ отключить резервировать место для всего файла"
Если не поможет, то возможно битые блоки, писал выше про badblocks и fsck:
проверяем и сохраняем список
sudo badblocks -v /dev/nvme0n1 > ~/blockslist.list
пытаемся восстановить работоспособность, используя список блоков
sudo fsck -t ext4 -l ~/blockslist.list /dev/nvme0n1
hw-probe: тыц!
Isemann
27 авг 2022, 13:36
warning писал(а):
27 авг 2022, 13:19
Пробовал QBitTorrent та же проблема. По поводу битых блоков Pass completed, 0 bad blocks found. (0/0/0 errors)
27 авг 2022, 14:17
Isemann писал(а):
27 авг 2022, 12:50
1. Покажите вывод команды mount
2. Проверьте владельца и права доступа на /home/data - возможно у вас владельцем оказался root а права что-то вроде 755. Торрент клиент, в отличии от timeshift писать будет под именем пользователя (или своим собственным, если настроен как демон) - ему таких прав не хватит.
Isemann
27 авг 2022, 14:32
27 авг 2022, 14:17
Isemann писал(а):
27 авг 2022, 12:50
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=8014904k,nr_inodes=2003726,mode=755,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=1621336k,mode=755,inode64)
/dev/nvme0n1p3 on / type ext4 (rw,relatime,errors=remount-ro)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=29,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=26293)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
none on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
/dev/nvme0n1p5 on /home type ext4 (rw,relatime)
/dev/nvme0n1p1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=1621336k,nr_inodes=405334,mode=700,uid=1000,gid=1000,inode64)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sda1 on /home/data type ext4 (rw,relatime)
portal on /root/.cache/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
gvfsd-fuse on /root/.cache/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0)
2. Действительно владелец root. Также указано время в которое я пытался изменить права доступа.
27 авг 2022, 14:46
Isemann писал(а):
27 авг 2022, 14:32
sudo chown -R <user>:<user> /home/data должно решить вашу проблему. Вместо <user> - ваше имя пользователя в системе.
Isemann
27 авг 2022, 14:55
27 авг 2022, 14:46
Isemann писал(а):
27 авг 2022, 14:32
Большое спасибо. Проблема с правами и работой Transmission решена.
Вернуться в «Работа с сетью»
