система медленно грузится с ssd
сергей197
03 мар 2023, 14:47
Kernel: 5.4.0-144-generic x86_64 bits: 64 compiler: gcc v: 9.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 20.3 Una base: Ubuntu 20.04 focal
Type: Laptop System: Acer product: Aspire A317-53 v: V1.20
serial: <filter>
Mobo: TGL model: Lilac_TL v: V1.20 serial: <filter> UEFI: Insyde v: 1.20
date: 11/03/2021
ID-1: BAT1 charge: 36.2 Wh condition: 36.2/37.0 Wh (98%)
model: Murata AP16M4J status: Full
Topology: Dual Core model: 11th Gen Intel Core i3-1115G4 bits: 64
type: MT MCP arch: Tiger Lake rev: 1 L2 cache: 6144 KiB
bogomips: 23961
Speed: 1043 MHz min/max: 400/4100 MHz Core speeds (MHz): 1: 1031 2: 1114
3: 854 4: 977
Device-1: Intel vendor: Acer Incorporated ALI driver: N/A
bus ID: 0000:00:02.0
Display: x11 server: X.Org 1.20.13 driver: fbdev
unloaded: modesetting,vesa resolution: 1920x1080~77Hz
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel vendor: Acer Incorporated ALI driver: sof-audio-pci
bus ID: 0000:00:1f.3
Sound Server: ALSA v: k5.4.0-144-generic
Device-1: Intel driver: iwlwifi v: kernel port: 4000 bus ID: 0000:00:14.3
IF: wlp0s20f3 state: up mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 0000:01:00.0
Local Storage: total: 119.24 GiB used: 17.22 GiB (14.4%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM128GD3JX016N
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller
driver: vmd v: 0.6 bus ID: 0000:00:0e.0
ID-1: / size: 18.16 GiB used: 12.79 GiB (70.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /home size: 98.23 GiB used: 4.42 GiB (4.5%) fs: ext4
dev: /dev/nvme0n1p3
System Temperatures: cpu: 28.0 C mobo: N/A
Processes: 223 Uptime: 49m Memory: 7.55 GiB used: 2.28 GiB (30.2%)
Init: systemd runlevel: 5 Compilers: gcc: 9.4.0 Shell: bash v: 5.0.17
inxi: 3.0.38
сергей197
03 мар 2023, 14:51
e@e-Aspire-A317-53:~$ systemd-analyze blame
680ms systemd-rfkill.service >
416ms dev-nvme0n1p2.device >
363ms networkd-dispatcher.service >
251ms e2scrub_reap.service >
222ms accounts-daemon.service >
198ms ubuntu-system-adjustments.service >
176ms udisks2.service >
158ms lightdm.service >
155ms plymouth-quit-wait.service >
150ms upower.service >
139ms systemd-resolved.service >
129ms networking.service >
116ms ModemManager.service >
111ms systemd-logind.service >
102ms avahi-daemon.service >
91ms NetworkManager.service >
89ms user@1000.service >
87ms apparmor.service >
80ms systemd-journal-flush.service >
80ms polkit.service >
75ms systemd-udev-trigger.service >
72ms keyboard-setup.service >
69ms gpu-manager.service >
lines 1-23
03 мар 2023, 15:04
А медленно это сколько?
Просто по предоставленным данным - не видно чтоб медленно грузилась
сергей197
03 мар 2023, 15:06
а какие данные предоставить я жду 58 секунд
Решено: 31
03 мар 2023, 15:12
Не поленился, сложил все перечисленные в спойлере цифирки и получил величину 3793ms. Если я ещё не разучился считать арифметику, то 3783ms ~ 3,8 секунды. Общий результат Startup finished in ... не покажете? (systemd-analyze). М.б. у вас затык в районе времени загрузки userspace?
03 мар 2023, 15:17
сергей197, а покажи вывод
systemd-analyze
сергей197
03 мар 2023, 15:21
Startup finished in 5.239s (firmware) + 1.544s (loader) + 50.858s (kernel) + 1.434s (userspace) = 59.077s
graphical.target reached after 1.194s in userspace
сергей197
03 мар 2023, 15:22
нет я конечно понимаю ваше удивление сам в шоке
Решено: 31
03 мар 2023, 15:25
сергей197 писал(а):
03 мар 2023, 15:22
сам в шоке
И я такого kernel ещё не видел :wacko2:
03 мар 2023, 15:25
И заодно: командой journalctl -b > boot.txt можно получить файлик с логом от последнего старта (boot.txt). Так вот, и содержимое этого файла тоже покажите.
Я подобное видел, но не факт что по той же причине. kernel - там включено все время от окончания инициализации UEFI, до момента когда ядро запускается и продолжает загружать систему. В том числе - и таймауты загрузчиков, на их менюшках разных.
сергей197
03 мар 2023, 15:29
а где искать текстовой файл я не знаю .где он должен быть примерно подскажите
Решено: 37
03 мар 2023, 15:30
сергей197, в каталоге откуда запустил команду
03 мар 2023, 15:30
В том каталоге в котором команду давали.
В текущем.
сергей197
03 мар 2023, 15:43
под спойлер не помещяется слишком много строк.как прикрепить файл.
03 мар 2023, 15:46
сергей197, в архив его и прикрепи к сообщению. Прикрепить можно чуть ниже кнопки "Отправить"
yarichin
03 мар 2023, 15:48
сергей197
03 мар 2023, 15:53
архив
boot (копия).txt.tar.gz
архив
(45.51 КБ) 13 скачиваний
(45.51 КБ) 11 скачиваний
03 мар 2023, 16:32
Сама загрузка проходит нормально. Как только ядро загружается - все летает. Затык где-то на уровне прошивки-загрузчика, именно само ядро грузится далеко не сразу...
сергей197
03 мар 2023, 16:36
так что теперь делать .можно это исправить?
yarichin
03 мар 2023, 16:41
сергей197 писал(а):
03 мар 2023, 16:36
Добавить инфы. Тебя просили показать systemd-analyze , от себя спрошу - на ноуте ещё что то стоит или стояло ? Как ставил систему ?
А совсем неплохо бы выдать инфу в таком виде --- Утилита-агрегатор логов и сведений о системе - hw-probe
