Менеджер обновлений
1o4ka
Благодарил (а): 23 раза
Менеджер обновлений
06 мар 2023, 21:54
NAME="Linux Mint"
VERSION="21.1 (Vera)"
железо:
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: KDE Plasma 5.24.7 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP Laptop 15s-eq1xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8706 v: 99.42 serial: <superuser required> UEFI: AMI
v: F.67 date: 12/29/2022
ID-1: BAT0 charge: 35.9 Wh (88.4%) condition: 40.6/40.6 Wh (100.0%)
volts: 12.2 min: 11.3 model: Hewlett-Packard Primary status: Discharging
Info: dual core model: AMD Ryzen 3 3250U with Radeon Graphics bits: 64
type: MT MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 192 KiB
L2: 1024 KiB L3: 4 MiB
Speed (MHz): avg: 1527 high: 2159 min/max: 1400/2600 boost: enabled
cores: 1: 1197 2: 1285 3: 2159 4: 1470 bogomips: 20760
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5.2:5
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: amdgpu,ati
unloaded: fbdev,modesetting,vesa gpu: amdgpu resolution: 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Vega 3 Graphics (raven2 LLVM 15.0.6 DRM 3.42
5.15.0-67-generic)
v: 4.6 Mesa 22.2.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel bus-ID: 04:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: f000
bus-ID: 02:00.0
Bluetooth:
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter>
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 238.47 GiB used: 114.73 GiB (48.1%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC711 HFM256GD3JX013N
size: 238.47 GiB temp: 25.9 C
ID-1: / size: 28.92 GiB used: 16.5 GiB (57.1%) fs: ext4 dev: /dev/nvme0n1p3
ID-2: /home size: 195.98 GiB used: 98.23 GiB (50.1%) fs: ext4
dev: /dev/nvme0n1p6
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p5
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
Processes: 245 Uptime: 22m Memory: 5.71 GiB used: 2.01 GiB (35.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 3165 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bus-ID: 1-5.2:5
5.15.0-67-generic)
bus-ID: 02:00.0
Bluetooth:
bus-ID: 1-4:3
dev: /dev/nvme0n1p6
Swap:
dev: /dev/nvme0n1p5
В связи с тем, что данная проблема случается не так уж редко, переношу сообщение из Настройки управления питанием (Пост 1o4ka #130805) в отдельную тему.
Перестал запускаться Менеджер обновлений . В системном лотке, их (менеджеров) стояло два: Центр программ Discover и Менеджер обновлений. При наличии обновлений -- "маяковали" оба. Но я всегда пользовался именно Менеджером обновлений. Diskover, при закрытии, постоянно выдаёт ошибку о внезапном прекращении работы.
Когда-то у меня были установлены две графические оболочки: Cinnamon и KDE. Потом Cinnamon был удалён. Менеджер обновлений, будучи приложением от Cinnamon, отлично работал и в KDE. Недавно мне пришлось сносить LM. После восстановления LM, Cinnamon опять возник. И опять я его удалил.
А Менеджер обновлений перестал запускаться.
При попытке запустить через консоль:
mintupdate
root@oleg-HP:/home/oleg# /usr/lib/linuxmint/mintUpdate/mintUpdate.py:1333: DeprecationWarning: Gdk.threads_init is deprecated
Gdk.threads_init()
module 'cinnamon' has no attribute 'UpdateManager'
<class 'AttributeError'>
От обычного пользователя выдаёт тоже самое.
Попытка обмануть судьбу:
sudo apt install mintupdate
Построение дерева зависимостей… Готово
Уже установлен пакет mintupdate самой новой версии (5.9.7).
Всё установлено, а включаешь - не работает.
Попытка:
apt install --reinstall mintupdate
тоже не даёт желаемого результата.
Что можно предпринять?
Последний раз редактировалось пользователем 1 1o4ka; всего редактировалось раз: 6
...bis dat qui cito dat
yarichin
Менеджер обновлений
06 мар 2023, 22:01
1o4ka писал(а):
06 мар 2023, 21:54
Просто поставит систему, а не натягивать сову на глобус. Я имею ввиду установку окружения KDE на линукс минт Cinnamon.
Благодарил (а): 844 раза
Менеджер обновлений
06 мар 2023, 22:29
1o4ka, проверь наличие файла /usr/lib/python3/dist-packages/cinnamon
и попробуй переименовать его чтоб не подхватывался минтапдейтом.
Хотя может и еще что-то из нужных системе зависимостей выпилилось с удалением базового de.
yarichin
Менеджер обновлений
06 мар 2023, 22:31
06 мар 2023, 22:29
Об этом ни в одной из трёх тем не упоминалось , хотя это и напрашивается. Я про удаление.
1o4ka
Менеджер обновлений
07 мар 2023, 11:08
Chocobo,
с помощью несложной команды:
# mv /usr/lib/python3/dist-packages/cinnamon /usr/lib/python3/dist-packages/cin
переименовал требуемый файл, и тут же Менеджер обновлений заработал. Спасибо.
Вопрос закрыт.
Вернуться в «KDE»
