железо:
Kernel: 5.15.0-56-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
Desktop: Cinnamon 5.6.5 Distro: Linux Mint 21.1 Vera
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 2787 high: 3193 min/max: 800/3200 cores: 1: 2381
2: 3193 bogomips: 12770
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.0.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-56-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 261.34 GiB (19.0%)
ID-1: /dev/sda vendor: Patriot model: Burst Elite 480GB size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-1: / size: 97.97 GiB used: 16.19 GiB (16.5%) fs: ext4 dev: /dev/sda5
ID-2: /boot/efi size: 96 MiB used: 30.3 MiB (31.5%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 245.44 GiB used: 56.21 GiB (22.9%) fs: ext4
dev: /dev/sda7
Swap:
ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
dev: /dev/sda6
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/sdb5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
Processes: 240 Uptime: 1d 11h 51m Memory: 15.52 GiB used: 4.77 GiB (30.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2800 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Что было перед этим? Вынимал SSD из системного блока, запускал (через внешний бокс, USB3) на ноуте. Потом вставил SSD обратно в системный блок
Потом сделал резервные копии OC на внешний накопитель. Вроде всё, как обычно.
С утра стационар повёл себя странно. Начал зависать. Перезагрузил, и собственно, всё. Стационар перестал видеть SSD. Отключил системник, проверил соединения. Вроде, всё в норме. Включил ПК. И вот какая получилась картина. Комп видит SSD:
Вот он: Р0 Patriot
Но при загрузке P0 выскакивает ошибка:
Попытка восстановить ОСь LM посредством LiveCD заканчивается ничем. LiveSD не видит SSD:
Обратите внимание на скрин. Здесь должны быть ещё три раздела: Винда на SSD, /LM и /home на SSD.
А здесь только винда с HDD и Магея с HDD со своим хомяком. Ну, ещё виден home LiveCD.
Короче, восстанавливать LM некуда.
Подскажите, что можно предпринять?
