cinnamon
железо:
Kernel: 5.15.0-67-generic x86_64 bits: 64 compiler: gcc v: 11.3.0
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: Gigabyte model: H81M-S2PV serial: <superuser required>
UEFI: American Megatrends v: F9 date: 08/11/2015
Info: dual core model: Intel Pentium G3420 bits: 64 type: MCP arch: Haswell
rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
Speed (MHz): avg: 3193 min/max: 800/3200 cores: 1: 3193 2: 3193
bogomips: 12771
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107 [GeForce GTX 750] vendor: Palit Microsystems
driver: nouveau v: kernel bus-ID: 01:00.0
Device-3: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4:3
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: nouveau resolution: 1920x1080~60Hz
OpenGL: renderer: NV117 v: 4.3 Mesa 22.2.5 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-3: NVIDIA GM107 High Definition Audio [GeForce 940MX]
vendor: Palit Microsystems driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-4: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.15.0-67-generic running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 3-1:2
IF: wlxc46e1f210c3f state: up mac: <filter>
Local Storage: total: 1.35 TiB used: 282.46 GiB (20.5%)
ID-1: /dev/sda vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-2: /dev/sdb vendor: Toshiba model: DT01ACA050 size: 465.76 GiB
ID-3: /dev/sdc type: USB vendor: Patriot model: Burst Elite 480GB
ID-1: / size: 91.11 GiB used: 16.15 GiB (17.7%) fs: ext4 dev: /dev/sdc2
ID-2: /home size: 287.8 GiB used: 77.4 GiB (26.9%) fs: ext4
dev: /dev/sdc4
Swap:
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) dev: /dev/sda5
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 38.0 C
Processes: 245 Uptime: 11h 30m Memory: 15.52 GiB used: 6.01 GiB (38.7%)
Init: systemd runlevel: 5 Compilers: gcc: 11.3.0 Packages: 2896 Shell: Bash
v: 5.1.16 inxi: 3.3.13
выскакивает сообщение:
Выходное аудиоустройство не установлено
Поиски решения по сети не дали никаких результатов. Не смог я подключить звук в виртуальной винде.
Подскажите, это можно сделать?
