System: Kernel: 6.2.0-33-generic x86_64 bits: 64 compiler: N/A Desktop: GNOME 42.9 Distro: Ubuntu 22.04.3 LTS (Jammy Jellyfish) Machine: Type: Desktop System: LENOVO product: 90RE00HKRS v: IdeaCentre Gaming5 14IOB6 serial: <superuser required> Mobo: LENOVO model: 3730 v: NOK serial: <superuser required> UEFI: LENOVO v: M3GKT3BA date: 07/25/2022 CPU: Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB Speed (MHz): avg: 1790 high: 2600 min/max: 800/4400 cores: 1: 1268 2: 2600 3: 2600 4: 1246 5: 1265 6: 2600 7: 1218 8: 2600 9: 1237 10: 2600 11: 1150 12: 1100 bogomips: 62208 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI driver: nvidia v: 470.199.02 bus-ID: 01:00.0 Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia resolution: 1920x1080 OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 470.199.02 direct render: Yes Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 Device-2: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1 Sound Server-1: ALSA v: k6.2.0-33-generic running: yes Sound Server-2: PulseAudio v: 15.99.1 running: yes Sound Server-3: PipeWire v: 0.3.48 running: yes Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter> Bluetooth: Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-6:3 Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0 lmp-v: 5.1 Drives: Local Storage: total: 238.47 GiB used: 28.84 GiB (12.1%) ID-1: /dev/nvme0n1 vendor: Samsung model: MZALQ256HBJD-00BL1 size: 238.47 GiB temp: 30.9 C Partition: ID-1: / size: 233.18 GiB used: 28.83 GiB (12.4%) fs: ext4 dev: /dev/nvme0n1p2 ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/nvme0n1p1 Swap: ID-1: swap-1 type: file size: 2 GiB used: 512 KiB (0.0%) file: /swapfile Sensors: System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 37 C Fan Speeds (RPM): N/A gpu: nvidia fan: 22% Info: Processes: 307 Uptime: 14m Memory: 7.53 GiB used: 1.86 GiB (24.7%) Init: systemd runlevel: 5 Compilers: gcc: N/A Packages: 1784 Shell: Bash v: 5.1.16 inxi: 3.3.13
Пропадает абсолютно случайно при работе/игре/в простое.
Куда копать?
