Общие папки windows10 и linux в локальной сети
Автор темы - Сообщения: 15
Оказываеться в виндовс 10 нету поддержки samba по у молчании.Добавил и сразу винда увидела свою расшариваемую папку .Но ни линукс не хочет подключаться к винде.но ни винда к линуксу.И по прежнему линукс не хочеть открывать свою сетевую папку.Хоття гостевую папку в smb.conf добавил.
Вот полный конфиг.
Вот конфиг
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
# - When such options are commented with ";", the proposed setting
# differs from the default Samba behaviour
# - When commented with "#", the proposed setting is the default
# behaviour of Samba but the option is considered important
# enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
security = user
map to guest = bad password
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = WORKGROUP
# server string is the equivalent of the NT Description field
server string = %h server (Samba, Ubuntu)
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
max log size = 1000
# We want Samba to only log to /var/log/samba/log.{smbd,nmbd}.
# Append syslog@1 if you want important messages to be sent to syslog too.
logging = file
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone server" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
server role = standalone server
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = bad user
########## Domains ###########
# The following settings only takes effect if 'server role = primary
# classic domain controller', 'server role = backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
# logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
# logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap config * : backend = tdb
; idmap config * : range = 3000-7999
; idmap config YOURDOMAINHERE : backend = tdb
; idmap config YOURDOMAINHERE : range = 100000-999999
; template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 means that usershare is disabled.
# usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
; comment = Home Directories
; browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
; read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
; create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
; directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# Un-comment the following parameter to make sure that only "username"
# can connect to \\server\username
# This might need tweaking when using external authentication schemes
; valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
[lan]
path = /home/user/lan
guest ok = yes
read only = no
create mask = 0777
directory mask = 0777
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
force user
создал новый конфиг с папкой lan с доступом гостевым.ничего не поменялось.лм сетевую папку видит а открывать не хочет.завтра подниму сеть между виндой и виндой.проверю так кабеля и свич.
- Решено: 110
Пользователь под которым с винды стучитесь в минт через smbpasswd добавлен? Если используется эта модель безопасности, нужно пользователей в самбу добавлять явным образом, задавая и пароль. Юзер должен быть уже существующим в системе, а вот пароль для него можно задать независимый от системного. Или даже добавить юзера который в системе пароля не имеет, т.е. вход в систему через него невозможен. Примерно так:
sudo smbpasswd -a myusername
- где будет предложено задать пароль для myusername.-
slant писал(а): ↑29 янв 2024, 20:24Пользователь под которым с винды стучитесь в минт через smbpasswd добавлен? Если используется эта модель безопасности, нужно пользователей в самбу добавлять явным образом, задавая и пароль. Юзер должен быть уже существующим в системе, а вот пароль для него можно задать независимый от системного. Или даже добавить юзера который в системе пароля не имеет, т.е. вход в систему через него невозможен. Примерно так:
Дело было не бобине ххххх сидел в кабине.
В винде добавил пароль пользователя.В лм добавил такого пользователя с тем же паролем по вашему совету.Пперегрузился все компы.
И винда увидела расшаренную папку линукса.А вот в лм ничего не поменялось так же не видить расшаренную папку винды и не открывает расшареную папку линукса..
Всем спасибо за советы.
еще не сочтите за нглось
как подретактировать свойсво папки lan чтоб винда могла записывать файлы но не могла удалять файлы.Это возможно?
[lan]
guest ok = yes
read only = no
create mask = 0777
[lan]
guest ok = yes
read only = no
create mask = 0777
у меня немо не видит виндовые папки , да и вообще виндовую сеть, а вот свои шары видит, в том числе и самбовские, виндовые шары я смотрю в дельфине.
- Решено: 31
Да уж, проблем с Samba в гетерогенной среде выше крыши, причём у каждого свои. Вероятно, не стоило бы читать публикации, авторы которых демонстрируют реализацию имеющихся у них потребностей, а сразу обращаться к документации производителя, то есть Samba, и штудировать её, пока не будет полного понимания всех настроек сервера Samba.
По быстрому поиску что-то похожее, но нужно проверять – ссылка
Ваш user LM, под которым вы ломитесь на Samba, имеет права на доступ к сетевым ресурсам Samba? Что касается Windows share, то, возможно, дело в версиях протокола SMB. Может быть это + это немного прояснит ситуацию.
Последний раз редактировалось пользователем 1 madesta; всего редактировалось раз: 30
Что то никто не упомянулл Warpinator.Кто нехочет возиться с samba.Хорошая альтернатива настраиваеться в два клика.
- Решено: 31
По умолчанию, Warpinator ограничивает размер файла в 250 МБ, хотя это и настраивается. Ну и тема сформулирована как общие папки, а не как возможные способы обмена информацией в ЛВС.
Даже не смотрел тему, - думал, что парни обстоятельно объяснят. (Для самого самбаизм - то еще "искусство").
Про Warpinator на сайте - тут.
- Решено: 31
Возникающая с периодичностью тема про Samba обусловлена тем, что в Windows пользователи, как правило, не в курсе альтернативных способов обмена файлами/папками по сети.
Немного не по теме, но близко:
На рубеже 1990/2000 г.г. в какой-то книжке по Windows Server 2000 читал о результатах произведенного эксперимента по определению нагрузки на сеть при использовании различных способов передачи данных. Нагрузка на сеть считалась тем выше, чем соответствующая ей условная цифра. По результатам тестов при использовании ftp было получено значение 0,1, а при использовании общих папок было получено значение 5. Далее в руководстве по настройке Windows Exchange Server 2003 авторства Microsoft вычитал любопытную мысль о том, что общие папки не являются безопасным способом обмена, поэтому если имеется возможность, то следует от них отказаться в пользу другой альтернативы. Так как в то время работал в закрытой организации с очень высокими требованиями к безопасности информации, то загорелся такой идеей. Но привычки пользователей это как непрошибаемое никакими доводами долговременное укрепление
С интересом наблюдаю за вопросами в теме и вот какой вопрос возник:
имею роутер, к нему подключен USB накопитель. Имею ноут с Win10 и имею десктоп с Linux Mint. И как то у меня не возникает вопрос обмена файлами между win и linux.
Это нормально? Или я слабак?
- Решено: 31
Зачем же так себя уничижительно – слабак? Неизвестно же, какой у вас способ обмена и условия. Решение вопроса обмена между Windows и Linux у каждого может быть сугубо индивидуальным. У меня, например, раньше было ftp, теперь Syncthing. А у кого-то в плане Share будет, на первый взгляд, верно настроено, да брандмауэр не позволяет... Кстати, наткнулся на интересную публикацию, в которой обосновывается необходимость прекращения использования SMB1 в пользу SMB2 или SMB3. А вот дяде Васе или тёте Зое будет глубоко фиолетово на все эти тонкости: "выдай общие папки и точка". И начинается таинство шаманства в домашней сети с Windows и Linux.
