Linux Mint 21.3 Virginia х64 Cinnamon
Железо
Kernel: 6.9.3-1-liquorix-amd64 x86_64 bits: 64 compiler: gcc v: 11.4.0
base: Ubuntu 22.04 jammy
Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: PRIME H510M-K v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1203
date: 10/27/2021
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 1979 high: 4377 min/max: 800/4400 cores: 1: 4377
2: 4326 3: 4352 4: 4300 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800
12: 800 bogomips: 62208
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Gigabyte driver: nvidia
v: 535.171.04 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~144Hz
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 535.171.04 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Sound Server-1: ALSA v: k6.9.3-1-liquorix-amd64 running: yes
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.59 TiB used: 743.35 GiB (45.6%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SWORDFISH size: 232.89 GiB
temp: 39.9 C
ID-2: /dev/sda vendor: Western Digital model: WD10EZEX-00BBHA0
ID-3: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
ID-1: / size: 93.31 GiB used: 22.33 GiB (23.9%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 486 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 117.43 GiB used: 40.07 GiB (34.1%) fs: ext4
dev: /dev/nvme0n1p5
Swap:
ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p4
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 362 Uptime: 6h 6m Memory: 15.46 GiB used: 5.02 GiB (32.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2944 Shell: Bash
v: 5.1.16 inxi: 3.3.13
date: 10/27/2021
bus-ID: 01:00.1
temp: 39.9 C
dev: /dev/nvme0n1p3
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p5
Swap:
dev: /dev/nvme0n1p4
