Kernel: 5.15.0-116-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: MATE 1.26.0 Distro: Linux Mint 21.1 Vera base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP ProBook 450 G5 v: N/A
serial: <superuser required>
Mobo: HP model: 837D v: KBC Version 02.41.00 serial: <superuser required>
UEFI: HP v: Q85 Ver. 01.23.00 date: 11/29/2022
ID-1: BAT0 charge: 35.4 Wh (97.3%) condition: 36.4/48.0 Wh (75.9%)
volts: 11.7 min: 11.4 model: Hewlett-Packard Primary status: N/A
Info: quad core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 800 min/max: 400/3400 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 28800
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM108M [GeForce 930MX] vendor: Hewlett-Packard
driver: nvidia v: 535.183.01 bus-ID: 01:00.0
Device-3: Lite-On HP HD Camera type: USB driver: uvcvideo bus-ID: 1-6:3
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
resolution: 1: 1920x1080~60Hz 2: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.15.0-116-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 03:00.0
Bluetooth:
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-7:4
bt-v: 2.1 lmp-v: 4.2
Local Storage: total: 931.51 GiB used: 481.71 GiB (51.7%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-60Z10T0
ID-1: / size: 49.98 GiB used: 32.18 GiB (64.4%) fs: xfs dev: /dev/dm-2
mapped: centos-root
ID-2: /boot/efi size: 96 MiB used: 60.8 MiB (63.3%) fs: vfat
dev: /dev/sda2
ID-3: /home size: 741.66 GiB used: 449.47 GiB (60.6%) fs: xfs
dev: /dev/dm-1 mapped: centos-home
Swap:
ID-1: swap-1 type: partition size: 7.75 GiB used: 0 KiB (0.0%)
dev: /dev/dm-0 mapped: centos-swap
System Temperatures: cpu: 43.0 C pch: 39.5 C mobo: 41.0 C
Processes: 306 Uptime: 39m Memory: 7.64 GiB used: 3.77 GiB (49.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2547 Shell: Bash
v: 5.1.16 inxi: 3.3.13
bus-ID: 03:00.0
Bluetooth:
bus-ID: 1-7:4
mapped: centos-root
dev: /dev/sda2
Swap:
где может быть проблема, подскажите, до этого все работало как часы
