Комп рабочий, переезд на другую кватриру, тут медь не разведена по комнатам, пока куплен USB-Wi-Fi. В коробочке со свистком диск с дровами, под виндой норм. Под Минт , после нескольких попыток - значек выбора сетей не появился.
Kernel: 5.15.0-138-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Xfce 4.18.1 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: MSI model: ZH77A-G43 (MS-7758) v: 1.0
serial: <superuser required> BIOS: American Megatrends v: 1.7
date: 12/24/2012
Info: quad core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 3700 min/max: 1600/3900 cores: 1: 3700 2: 3700 3: 3700
4: 3700 5: 3700 6: 3700 7: 3700 8: 3700 bogomips: 54399
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ZOTAC driver: nvidia
v: 535.183.01 bus-ID: 01:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nvidia
unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC
Device-3: Creative Labs CA0108/CA10300 [Sound Blaster Audigy Series]
driver: N/A bus-ID: 05:01.0
Sound Server-1: ALSA v: k5.15.0-138-generic running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 558.93 GiB used: 143.37 GiB (25.7%)
ID-1: /dev/sda model: SATA3 240GB SSD size: 223.57 GiB
ID-2: /dev/sdb vendor: Intel model: SSDSC2BW120A4 size: 111.79 GiB
ID-3: /dev/sdc model: SATA3 240GB SSD size: 223.57 GiB
ID-1: / size: 218.01 GiB used: 143.37 GiB (65.8%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 512 MiB used: 12 KiB (0.0%) fs: vfat dev: /dev/sda3
Swap:
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 269 Uptime: 17m Memory: 15.56 GiB used: 1.95 GiB (12.6%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3095 Shell: Bash
v: 5.1.16 inxi: 3.3.13
date: 12/24/2012
Swap:
Bus 001 Device 004: ID 0bda:b812 Realtek Semiconductor Corp. RTL88x2bu [AC1200 Techkey]
Значит ищем драйвер под Линукс для RTL88x2bu , нашел на ГитХаб , там есть консольные команды , все их выполнил, значек не появился. Без вас никак вобщем. Подпихните плиз.
