Ошибки во время загрузки
16 янв 2018, 19:21
[Firmware Bug]: TSC_DEADLINE disabled due to Errata; please update microcode to version: 0xb2 (or later)
ACPI Error: No handler for Region [RAM_] (ffff993526189990) [EmbeddedControl] (20170728/evregion-166)
ACPI Error: Region EmbeddedControl (ID=3) has no handler (20170728/exfldio-299)
ACPI Error: Method parse/execution failed \_SB.PCI0.LPCB.EC0._REG, AE_NOT_EXIST (20170728/psparse-550)
platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
acpi MSFT0101:00: platform device creation failed: -16
Вот такое вижу при загрузке каждый раз. Стоит заморачиваться?
System:    Host: darkfenix Kernel: 4.14.13-041413-generic x86_64 (64 bit gcc: 7.2.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.3 Sylvia
Machine:   System: Acer (portable) product: Aspire V3-372 v: V1.08
           Mobo: Acer model: Aspire V3-372 v: V1.08 Bios: Insyde v: V1.08 date: 06/06/2016
CPU:       Dual core Intel Core i5-6200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9600
           clock speeds: max: 2800 MHz 1: 900 MHz 2: 900 MHz 3: 900 MHz 4: 900 MHz
Graphics:  Card: Intel Sky Lake Integrated Graphics bus-ID: 00:02.0
           Display Server: X.Org 1.18.4 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.01hz
           GLX Renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
           GLX Version: 3.0 Mesa 17.2.4 Direct Rendering: Yes
Audio:     Card Intel Sunrise Point-LP HD Audio driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.14.13-041413-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter driver: ath10k_pci bus-ID: 03:00.0
Drives:    HDD Total Size: 1000.2GB (18.1% used) ID-1: /dev/sda model: WDC_WD10SPCX size: 1000.2GB
Partition: ID-1: / size: 48G used: 7.6G (17%) fs: ext4 dev: /dev/sda3
           ID-2: /home size: 481G used: 147G (33%) fs: ext4 dev: /dev/sda4
           ID-3: swap-1 size: 16.78GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 58.5C mobo: 51.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 217 Uptime: 38 min Memory: 1441.9/7869.3MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
           Client: Shell (zsh 5.1.1) inxi: 2.2.35
16 янв 2018, 19:33
16 янв 2018, 19:21
Да, думаю стоит. Драйвер микрокода обновить просит. 0xb2 (или поздний)
покажи
cat /proc/cpuinfo
16 янв 2018, 19:37
vir0id писал(а):
16 янв 2018, 19:33
покажи
cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 78
model name : Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
stepping : 3
microcode : 0x8a
cpu MHz : 500.001
cache size : 3072 KB
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp
bugs : cpu_meltdown
bogomips : 4800.00
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 78
stepping : 3
microcode : 0x8a
cpu MHz : 500.003
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs : cpu_meltdown
bogomips : 4800.00
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 78
stepping : 3
microcode : 0x8a
cpu MHz : 500.010
physical id : 0
siblings : 4
core id : 0
cpu cores : 2
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs : cpu_meltdown
bogomips : 4800.00
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 78
stepping : 3
microcode : 0x8a
cpu MHz : 500.015
physical id : 0
siblings : 4
core id : 1
cpu cores : 2
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs : cpu_meltdown
bogomips : 4800.00
clflush size : 64
power management:
16 янв 2018, 19:38
Ubuntu Kernel Bot (ubuntu-kernel-bot) написал по 2017-10-18: Отсутствуют необходимые журналы. # 4
В этой ошибке отсутствуют файлы журналов, которые помогут диагностировать проблему. При запуске ядра Ubuntu (а не основного или стороннего ядра) введите следующую команду в окне терминала:
apport-collect 1724650
а затем измените статус ошибки на «Подтвержденный».
Если из-за характера проблемы, с которой вы столкнулись, вы не можете запустить эту команду, добавьте комментарий с указанием этого факта и измените статус ошибки на «Подтвержденный».
Это изменение было внесено автоматическим сценарием, поддерживаемым командой ядра ядра Ubuntu.
Изменено в linux (Ubuntu):
статус : Новый → Незавершенный
16 янв 2018, 19:40
У тебя 0x8a а от мол просит обновить до 0xb2. Я не уверен, но попробую покапаться в гугле
16 янв 2018, 19:43
intel-microcode (3.20160607.2) нестабилен; Актуальность = низкий
* УДАЛИТЬ микрокод:
sig 0x000406e3, pf mask 0xc0, 2016-04-06, rev 0x008a, размер 96256
(закрывается: # 828819)
* Процессоры Core i7-6500U и m3-6Y30 (Skylake-UY D-1,
sig = 0x406e3, pf = 0x80) может зависать при попытке раннего микрокода
обновить до версии 0x8a, видимо, из-за какой-то прошивки
зависимость. В затронутых системах единственный способ избежать этой проблемы -
чтобы получить обновление прошивки, которое включает в себя версию микрокода 0x8a или
позже. В это время поступают сообщения об успешном и неудачном
обновления на m3-6Y30 и только неудачные обновления на i7-6500U.
Нет сообщений о Skylake-U K-1 (pf = 0x40).
+ ПРЕДУПРЕЖДЕНИЕ: небезопасно использовать систему на базе Intel Skylake-U / Y
процессор с микрокодом раньше версии 0x8a, из-за нескольких
критические ошибки, которые вызывают непредсказуемое поведение, повреждение данных,
и другие проблемы. Пользователи * должны * обновить свою прошивку, чтобы получить
микрокод 0x8a или новее, и поддерживать его в актуальном состоянии.
- Henrique de Moraes Holschuh <спрятать адрес электронной почты> Пт, 08 июл 2016 22:54:26 -0300
16 янв 2018, 19:45
vir0id писал(а):
16 янв 2018, 19:38
Т.е. баг и пока его не вылечили. Потому как эти ошибки есть и при загрузке с лайвсиди с ядром 4.10. :evil:
16 янв 2018, 19:46
vir0id писал(а):
16 янв 2018, 19:43
У меня как раз 0x8a. Или я чего-то не понял?
16 янв 2018, 19:47
16 янв 2018, 19:21
16 янв 2018, 19:47
16 янв 2018, 19:46
Ты правильно понял. Только система просит его обновить до 0xb2
16 янв 2018, 19:50
vir0id писал(а):
16 янв 2018, 19:47
Хорошо. А как это провернуть? Что-то я с таким не сталкивался
16 янв 2018, 19:50
16 янв 2018, 19:50
Я тоже. Посмотри сюда
16 янв 2018, 20:05
vir0id писал(а):
16 янв 2018, 19:50
Посмотри
Посмотрел. Поставил пакет microcode, теперь
 darkfenix@darkfenix  ~  dmesg | grep 'microcode'
[    0.000000] microcode: microcode updated early to revision 0xc2, date = 2017-11-16
[    1.438080] microcode: sig=0x406e3, pf=0x80, revision=0xc2
[    1.438301] microcode: Microcode Update Driver: v2.2.
 darkfenix@darkfenix  ~  grep 'microcode' /proc/cpuinfo
microcode	: 0xc2
microcode	: 0xc2
microcode	: 0xc2
microcode	: 0xc2
Но при перезагрузке ошибки никуда не делись :dash2:
16 янв 2018, 20:11
darkfenix, ёптель... а что теперь ему не нравится? Логи в студию
16 янв 2018, 20:17
darkfenix, интересно, а ничего что ты обновил на 0xc2, а надо было 0xb2? Какой из них новее или старее? Ну по логике "С" должен быть новее
16 янв 2018, 20:19
vir0id писал(а):
16 янв 2018, 20:11
Да фиг его знает.
vir0id писал(а):
16 янв 2018, 20:11
Логи в студию
Какой лог показать?
vir0id писал(а):
16 янв 2018, 20:17
Так же думаю. Просто это пакет, который был доступен в репах.
Вот думаю надо еще UEFI обновить. У меня версия 1.08, а на сайте есть 1.12.
UPD: там экзешник. Вот ведь :dash2:
16 янв 2018, 20:28
16 янв 2018, 20:19
Какой лог показать?
ну тот, что ты в первом посте засветил.
16 янв 2018, 20:19
Может с этого и надо было начать :-D :-D :-D
16 янв 2018, 20:19
ну да, без бубна и танцев видимо не обойдётся чувствую
16 янв 2018, 20:48
vir0id писал(а):
16 янв 2018, 20:28
Чуть дважды не обделался пока прошивал UEFI. Первый раз когда запустил и через секунду ноут вырубился, потом секунд через 5 начал шиться. Второй раз когда закончил шиться вырубился и включился только секунд через 5. :crazy:
vir0id писал(а):
16 янв 2018, 20:28
ACPI Error: No handler for Region [RAM_] (ffff97b866189ee8) [EmbeddedControl] (20170728/evregion-166)
Ошибки по фирмвари нет. Думаю она пропала после установки микрокода. Остальное осталось как было
16 янв 2018, 21:02
16 янв 2018, 20:48
Было бы жостко.
С памятью чё-то. Попробуй... эм.... правда не уверен поможет ли... В /etc/default/grub прописать параметр iommu=soft. Но я не уверен. У меня он сработал, когда я мучался с памятью.
16 янв 2018, 21:03
аа неее... погоди
Сейчас этот форум просматривают: Twitter[Bot] и 1 гость
