Зависание linux mint 19 cinnamon
zanichka
Благодарил (а): 2 раза
#61
29 авг 2018, 19:28
Так, ну во снова началось. Сейчас сидел смотрел ролик на ютубе и на тебе. время примерно 19:17
-- Logs begin at Wed 2018-08-01 20:42:19 MSK, end at Wed 2018-08-29 19:20:39 MSK. --
авг 29 13:54:28 cat1-System-Product-Name kernel: ACPI BIOS Error (bug): Failure creating [\_SB.SMIC], AE_ALREADY_EXISTS (20180531/dswload2-316)
авг 29 13:54:28 cat1-System-Product-Name kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20180531/psobject-221)
авг 29 13:54:28 cat1-System-Product-Name kernel: ACPI BIOS Error (bug): Failure creating [\_SB.SMIB], AE_ALREADY_EXISTS (20180531/dsfield-594)
авг 29 13:54:28 cat1-System-Product-Name kernel: kfd kfd: kgd2kfd_probe failed
авг 29 13:54:28 cat1-System-Product-Name kernel: [drm:construct [amdgpu]] *ERROR* construct: Invalid Connector ObjectID from Adapter Service for connector index:2! type 0 expected 3
авг 29 13:54:28 cat1-System-Product-Name kernel: [drm:construct [amdgpu]] *ERROR* construct: Invalid Connector ObjectID from Adapter Service for connector index:3! type 0 expected 3
авг 29 13:54:55 cat1-System-Product-Name lightdm[1480]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
авг 29 13:54:55 cat1-System-Product-Name lightdm[1480]: PAM adding faulty module: pam_kwallet.so
авг 29 13:55:01 cat1-System-Product-Name lightdm[1641]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
авг 29 13:55:01 cat1-System-Product-Name lightdm[1641]: PAM adding faulty module: pam_kwallet.so
авг 29 13:55:11 cat1-System-Product-Name pulseaudio[1978]: [pulseaudio] pid.c: Daemon already running.
авг 29 13:55:36 cat1-System-Product-Name pulseaudio[1908]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
авг 29 14:14:33 cat1-System-Product-Name anacron[1041]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
авг 29 17:22:30 cat1-System-Product-Name systemd[1647]: Failed to start flatpak-com.viber.Viber-23895.scope.
авг 29 17:22:37 cat1-System-Product-Name systemd[1647]: Failed to start flatpak-com.viber.Viber-23986.scope.
авг 29 17:27:39 cat1-System-Product-Name systemd[1647]: Failed to start flatpak-com.viber.Viber-24691.scope.
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: [gfxhub] VMC page fault (src_id:0 ring:24 vmid:1 pasid:32768)
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f823000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: VM_L2_PROTECTION_FAULT_STATUS:0x00101031
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f826000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f82d000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f837000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f830000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f828000 from 27
авг 29 19:17:59 cat1-System-Product-Name kernel: amdgpu 0000:08:00.0: at page 0x000000010f83a000 from 27
авг 29 19:18:09 cat1-System-Product-Name kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring gfx timeout, last signaled seq=745813, last emitted seq=745815
warning
Решено: 7
Благодарил (а): 161 раз
#62
30 авг 2018, 10:18
Обновил микрокод процессора и пока больше нет зависаний..Правда у меня Intel, а у топик стартера вроде AMD
hw-probe: тыц!
warning
Решено: 7
#63
01 сен 2018, 14:01
Только что опять намертво встала система.. Пробовал выйти в tty - безуспешно...попытался REINSUB...тоже без результатов..
В общем помогает только аварийное выключение..что уже порядком надоело :)
Скопировал содержимое двух логов. Но вот что интересно...Действо произошло в 13:37 (плюс минус минута). Один лог обрывается на 07: с_копейками ..Второй, соответственно, после перезагрузки в 13:41.. Что там между остается загадкой...Но может хоть что-то подскажете :)
-- Logs begin at Вс 2018-08-26 17:55:44 MSK, end at Сб 2018-09-01 13:53:38 MSK. --
авг 30 22:51:38 root systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-d0029757\x2da284\x2d4e44\x2d987d\x2da3bfb25e05cc.device.
авг 30 22:51:40 root ntpdate[546]: name server cannot be used: Temporary failure in name resolution (-3)
авг 30 22:51:45 root bluetoothd[840]: Failed to obtain handles for "Service Changed" characteristic
авг 30 22:51:45 root bluetoothd[840]: Not enough free handles to register service
авг 30 22:51:45 root bluetoothd[840]: Error adding Link Loss service
авг 30 22:51:45 root bluetoothd[840]: Current Time Service could not be registered
авг 30 22:51:45 root bluetoothd[840]: gatt-time-server: Input/output error (5)
авг 30 22:51:45 root bluetoothd[840]: Sap driver initialization failed.
авг 30 22:51:45 root bluetoothd[840]: sap-server: Operation not permitted (1)
авг 30 22:51:46 root kernel: kvm: disabled by bios
авг 30 22:51:47 root NetworkManager[613]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
авг 30 22:51:48 root wpa_supplicant[942]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
авг 30 22:51:48 root wpa_supplicant[942]: dbus: Failed to construct signal
авг 30 22:51:49 root lightdm[965]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
авг 30 22:51:49 root lightdm[965]: PAM adding faulty module: pam_kwallet.so
авг 30 22:51:49 root lightdm[965]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
авг 30 22:51:49 root lightdm[965]: PAM adding faulty module: pam_kwallet5.so
авг 30 22:51:53 root lightdm[1225]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
авг 30 22:51:53 root lightdm[1225]: PAM adding faulty module: pam_kwallet.so
авг 30 22:51:53 root lightdm[1225]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
авг 30 22:51:53 root lightdm[1225]: PAM adding faulty module: pam_kwallet5.so
авг 30 22:52:04 root pulseaudio[1441]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
авг 30 22:52:04 root pulseaudio[1485]: [pulseaudio] pid.c: Daemon already running.
авг 31 00:12:41 root sudo[4035]: warning : a password is required ; TTY=pts/6 ; PWD=/home/warning ; USER=root ; COMMAND=/usr/sbin/hddtemp -nq -u C /dev/sda
авг 31 01:58:58 root pkexec[14594]: pam_ck_connector(polkit-1:session): cannot determine display-device
авг 31 10:36:07 root bluetoothd[840]: Failed to obtain handles for "Service Changed" characteristic
авг 31 10:36:07 root bluetoothd[840]: Not enough free handles to register service
авг 31 10:36:07 root bluetoothd[840]: Error adding Link Loss service
авг 31 10:36:07 root bluetoothd[840]: Current Time Service could not be registered
авг 31 10:36:07 root bluetoothd[840]: gatt-time-server: Input/output error (5)
авг 31 10:36:07 root bluetoothd[840]: Sap driver initialization failed.
авг 31 10:36:07 root bluetoothd[840]: sap-server: Operation not permitted (1)
авг 31 12:13:20 root pkexec[19386]: pam_ck_connector(polkit-1:session): cannot determine display-device
авг 31 12:27:55 root bluetoothd[840]: Failed to obtain handles for "Service Changed" characteristic
авг 31 12:27:55 root bluetoothd[840]: Not enough free handles to register service
авг 31 12:27:55 root bluetoothd[840]: Error adding Link Loss service
авг 31 12:27:55 root bluetoothd[840]: Current Time Service could not be registered
авг 31 12:27:55 root bluetoothd[840]: gatt-time-server: Input/output error (5)
авг 31 12:27:55 root bluetoothd[840]: Sap driver initialization failed.
авг 31 12:27:55 root bluetoothd[840]: sap-server: Operation not permitted (1)
авг 31 12:33:29 root anacron[19801]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
авг 31 16:12:31 root pkexec[9172]: pam_ck_connector(polkit-1:session): cannot determine display-device
авг 31 22:27:50 root bluetoothd[840]: Failed to obtain handles for "Service Changed" characteristic
авг 31 22:27:50 root bluetoothd[840]: Not enough free handles to register service
авг 31 22:27:50 root bluetoothd[840]: Error adding Link Loss service
авг 31 22:27:50 root bluetoothd[840]: Current Time Service could not be registered
авг 31 22:27:50 root bluetoothd[840]: gatt-time-server: Input/output error (5)
авг 31 22:27:50 root bluetoothd[840]: Sap driver initialization failed.
авг 31 22:27:50 root bluetoothd[840]: sap-server: Operation not permitted (1)
авг 31 23:42:53 root kernel: rtlwifi: AP off, try to reconnect now
сен 01 00:33:46 root pkexec[27966]: pam_ck_connector(polkit-1:session): cannot determine display-device
сен 01 07:31:33 root bluetoothd[840]: Failed to obtain handles for "Service Changed" characteristic
сен 01 07:31:33 root bluetoothd[840]: Not enough free handles to register service
сен 01 07:31:33 root bluetoothd[840]: Error adding Link Loss service
сен 01 07:31:33 root bluetoothd[840]: Current Time Service could not be registered
сен 01 07:31:33 root bluetoothd[840]: gatt-time-server: Input/output error (5)
сен 01 07:31:33 root bluetoothd[840]: Sap driver initialization failed.
сен 01 07:31:33 root bluetoothd[840]: sap-server: Operation not permitted (1)
сен 01 07:37:11 root anacron[28422]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
-- Logs begin at Вс 2018-08-26 17:55:44 MSK, end at Сб 2018-09-01 13:54:38 MSK. --
сен 01 13:41:06 root systemd[1]: Timed out waiting for device dev-disk-by\x2duuid-d0029757\x2da284\x2d4e44\x2d987d\x2da3bfb25e05cc.device.
сен 01 13:41:10 root ntpdate[533]: name server cannot be used: Temporary failure in name resolution (-3)
сен 01 13:41:16 root bluetoothd[887]: Failed to obtain handles for "Service Changed" characteristic
сен 01 13:41:16 root bluetoothd[887]: Not enough free handles to register service
сен 01 13:41:16 root bluetoothd[887]: Error adding Link Loss service
сен 01 13:41:16 root bluetoothd[887]: Current Time Service could not be registered
сен 01 13:41:16 root bluetoothd[887]: gatt-time-server: Input/output error (5)
сен 01 13:41:16 root bluetoothd[887]: Sap driver initialization failed.
сен 01 13:41:16 root bluetoothd[887]: sap-server: Operation not permitted (1)
сен 01 13:41:17 root kernel: kvm: disabled by bios
сен 01 13:41:17 root NetworkManager[564]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
сен 01 13:41:18 root wpa_supplicant[921]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
сен 01 13:41:18 root wpa_supplicant[921]: dbus: Failed to construct signal
сен 01 13:41:19 root lightdm[933]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
сен 01 13:41:19 root lightdm[933]: PAM adding faulty module: pam_kwallet.so
сен 01 13:41:19 root lightdm[933]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
сен 01 13:41:19 root lightdm[933]: PAM adding faulty module: pam_kwallet5.so
сен 01 13:41:25 root lightdm[1200]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
сен 01 13:41:25 root lightdm[1200]: PAM adding faulty module: pam_kwallet.so
сен 01 13:41:25 root lightdm[1200]: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
сен 01 13:41:25 root lightdm[1200]: PAM adding faulty module: pam_kwallet5.so
сен 01 13:41:34 root pulseaudio[1430]: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
сен 01 13:41:34 root pulseaudio[1477]: [pulseaudio] pid.c: Daemon already running.
LM18.3 Xfce
hw-probe: тыц!
Решено: 36
#64
01 сен 2018, 22:16
WARNING, ищи кернел парик... Скорее всего где-то в дровах
Благодарил (а): 26 раз
#65
06 сен 2018, 21:09
Unborn писал(а):
21 авг 2018, 16:38
Но отключать, не использовать ACPI, - это просто тупо клоунский совет и решение.
Мой юный категоричный друг. Совет дал возможность загрузиться и понаблюдать за работой, посмотреть логи, потыкать железо утилитами и пр.
И — хорошо бы за лексиконом следить, сынок, не на базаре.
Unborn писал(а):
21 авг 2018, 16:38
УЕФИ ни при чем. Это очень хорошая вещь. Годами шли к этому. Вендоров от спеков вправо-влево шатает, народ на линукс мучается
Хорошая?!
Unborn писал(а):
21 авг 2018, 16:38
не каждый ЦП имеет аппаратную поддержку виртуализации, и версия УЕФИ должна соответствовать модели ЦП. Прежде чем устанавливать крайние версии прошивок, проверяйте совместимость с моделью ЦП.
Лол. Такая хорошая вещь, аж кушать не могу.
Слава Б-гу, с админством завязал до наступления текущей безблагодатной эпохи, а три машинки, которые на мне, умеют в биос, и с ними нет проблем.
Друзьям и коллегам не так повезло.
#66
06 сен 2018, 21:32
Я невероятно извиняюсь, но перечитывать тему нет никакого желания, а поиск слова memtest не нашел.
Вы memtest86 гоняли, хотя бы один проход?
В моей практике бывали случаи с деградировавшей памятью, которая стала поглючивать, и система вела себя странно. Кроме того, опухание конденсаторов возможно не только на материнке, но и в БП. Если нет возможности «подкинуть» заведомо исправный БП, вскроете этот и посмотрите внимательно конденсаторы на предмет вздутия.
Еще возможно ослабевание контакта в разъемах блока питания, жестяные трубочки внутри пластмасски. Однажды такой контакт вынудил клиента купить новый БП (тот самый случай случай, когда нечего подкинуть). А когда я тот старый БП взял на посмотреть и запустил у себя на работе, тут оно и вскрылось. Один ослабевший контакт был виной внезапных перезагрузок и удивительных записей в системном логе фрибсди, которые вели мысли совсем не туда.
Еще помню случай, когда мамка была не притянута болтиками к стойкам, болтики болтались, простите за каламбур. Тоже ни с того ни с сего происходили подвисания и полные зависания.
Еще видюха глючная может подсирать.
В общем, железо невредно потыкать и попроверять на характерные бяки. Для начала memtest из загрузочного меню прогнать. Несколько часов, если сразу ошибки не полезут.
Если что, кидайте в личку ссылку на свой вопрос, я тут редко бываю.
#67
06 сен 2018, 23:12
027 писал(а):
06 сен 2018, 21:09
Как владелец металлолома + неосилятор, так сразу кушать не могу, всё плохо. А раз админил, то знал, что ефи то как раз пришло с серверов на десктопы, первые яблочники внедрять начали. Просто время на устаканивание много ушло из-за M$. Классической БСВВ уже давно нет. Уже даже Виста знала и умела ефи. И платы уже выпускались с подобием ефи. АМД жалуйтесь, УЕФИ и Линукс тут сбоку.
StarMAUGLI писал(а):
25 авг 2018, 16:41
А почему именно такой совет? (просто хочется понять)
Просто в ядре 4.17 уже много чего пофиксили.WARNING, ошибки в драйвере amdgpu. Блутуз тоже добавляет. Наушники наверно какие-то беспроводные пытаешься подключить, там и пульса что-то ругается. Устанавливай лучше Арч, а не дистр, который отстаёт на 2 года от железа. Там дело быстрее идёт.
027 писал(а):
06 сен 2018, 21:32
У ТС железо вчера из магазина. То, что опухало, давно уже твёрдотельно.
linux-firmware нужно новее установить.
warning
Решено: 7
#68
06 сен 2018, 23:21
Unborn писал(а):
06 сен 2018, 23:12
я им вообще не пользуюсь...вроде даже отключал из стартапа..видимо нет )
драйвера вроде все что в комплекте шли с дистром..сам ничего не ставил, ибо под мою рухлядь ничего и быть не может )
hw-probe: тыц!
#69
06 сен 2018, 23:34
WARNING писал(а):
06 сен 2018, 23:21
в твоём логе блютуз
WARNING писал(а):
01 сен 2018, 14:01
Остальное, про amdgpu, фирмварь и Арч для zanichka,
#70
07 сен 2018, 00:25
Unborn писал(а):
06 сен 2018, 23:12
Unborn писал(а):
06 сен 2018, 23:12
Собсна, на этом гражданина Унборна можно дальше не слушать. Собиратель популярных ярлыков лора/опеннета и советователь арча. Ах, где мои семнадцать лет...
#71
07 сен 2018, 19:22
027 писал(а):
07 сен 2018, 00:25
А они у тебя никуда и не делись. В дополнение к вздутию, контактикам, болтикам и гаечкам, тебе нужно было ТС посоветовать сменить термопасту. Обычно одмины со стажем с её замены советы начинают. А заканчивают советом установить очередную супер-пупер виндоговносборку, в которой всё работает.
А вот установить Арч действительно стоит, так как в нем быстрее всех различные фиксы в ядро включают.
Ну или хотя бы на Арче основанное. Хоть Антергос например.
StarMAUGLI
Решено: 19
Благодарил (а): 697 раз
#72
07 сен 2018, 22:55
zanichka писал(а):
29 авг 2018, 19:28
на 19:17 у тебя идет логирование по amdgpu
тебе здесь советовали попробовать ядро 4.17
Unborn писал(а):
06 сен 2018, 23:12
Не пробовал?
У тебя железо новое, и ядро под него нужно с соответствующими дровами. Я в своем LM18.3 это ядро посмотреть не могу (там ядра на 4.15 заканчиваются), но у тебя в LM19 оно должно быть в менеджере обновлений по идее.
Если и 4.17 не поможет, то можно заглянуть на https://www.kernel.org/ посмотреть, Линус нового наваял. На сегодня у него вроде 4.18.6 - стабильное. А 4.17.19 уже EOL (end of life - конец жизни)
Попробовать Арч (имхо) тоже хороший для твоего железа вариант.
Но Арч на старте (если ты им раньше не пользовался) отожрет у тебя немало времени (в арч-вики и по форумам) пока ты сделаешь из него то, что тебе нужно. Принимать взвешенные решения придется по каждому чиху. Если готов к этому, то пробуй.
StarMAUGLI
Решено: 19
#73
08 сен 2018, 00:38
WARNING писал(а):
01 сен 2018, 14:01
в самом деле странный перерыв.
попробовал порыть в этом направлении. Вот что нарыл:
отсюда https://habr.com/post/325792/ из дебатов после статьи
Еще раз, проблема потери логов и повреждения логов, она разная. Причина одинаковая, внезапно крешнулось ядро или хардварь, но ведет к разным проблемам.
Т.е. или сервис вообще не успевает начать сброс буферов, тогда логи просто все.
Или запись обрывается внезапно. И если для текста это некритично, то прерванная перезапись\аппенд блока в бинарной базе эту базу повреждает.
Можете писать любую избыточную информацию, проблема в незаписи блока или обрыве блока и последнее для бинарного формата критично
там же есть какие-то (неразвернутые) советы на перевод логов из бинарного вида в текстовый, но с этим я пока не разобрался (может еще кто-то что-то подскажет?)
соответственно вопрос: а что у тебя происходит с памятью? (в hw-probe в разделе meminfo у тебя MemFree: 240024 kB - этого кажется маловато... впрочем данный лог у тебя наверное возрастной?)
посмотри как сейчас загружена память (через системный монитор или командой free в консоли).
Также исходя из вышеизложенного, может стоит прогнать память memtest'ом (кругов 5-10)?
Потому что если это память, то можно считать, что отделался легким испугом (заменить планку (-и) или добавить если чипсет позволяет и все).
Кстати (не смотря на хиханьки двумя постами выше), ноут не греется? от пыли чистишь?
#74
08 сен 2018, 00:49
08 сен 2018, 00:38
08 сен 2018, 00:38
ТС уже угарает над вашими советами. См #1 вывод inxi. У одного вздутие, у другого ноут.
Может хоть кто-то что-то дельное про amdgpu скажет. В какой версии ядра пофиксили баг, характерный для ЦП АМД с Вегой на новых платах, или ещё живет.
StarMAUGLI
Решено: 19
#75
08 сен 2018, 01:11
Unborn, читай внимательнее кому я отвечаю.
ТС - zanichka,
а я отвечаю WARNING-у, который привел свой лог, со своей проблемой. И у него в подписи есть hw-probe - представляешь? И у него в отличии от ТС - Леново с Intel(R) Celeron(R) CPU N2830 @ 2.16GHz, а не новый десктоп с AMD.
WARNING писал(а):
06 сен 2018, 23:21
а zanichka, я отвечал постом выше. И вобщем-то мой совет близок к твоему, только написанный человеческим языком. Без звездных закидонов.
Так что читай внимательнее, прежде чем флудить.
#76
08 сен 2018, 11:13
08 сен 2018, 01:11
Пардон.
Но вот говорят же - не пишите в чужие темы свои проблемы. Помню проблему, только конфиг железа освежу - посмотрю и ответы иненно по теме внимательно в основном.
А WARNING-у, влюблённому в свою винговносборку, что сказать? Что железо 2015 года, и ОС нужно в УЕФИ устанавливать? Что еррор - acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM из-за несогласованности с прошивкой. В параметры загрузки можно добавить pcie_aspm=force
ASPM - Active State Power Management.
И блютуз при таком раскладе живет своей жизнью. Карта то не очень - rtl8723be.
bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2 [ 19.490666] Bluetooth: hci0: Failed to load rtl_bt/rtl8723b_config.bin [ 19.490671] Bluetooth: hci0: rtl: loading rtl_bt/rtl8723b_fw.bin
Может софтина какая вешает систему.
warning
Решено: 7
#77
08 сен 2018, 12:47
08 сен 2018, 00:38
ноут не греется, от пыли периодически чищу
да, про память в курсе, мало..прогоню, конечно, memtest.
Примерно неделю назад заметил, что conky постоянно жаловался( при запуске в терминале) на переменную $ . Запустил повторный процесс conky и система встала колом. Проделал еще раз - результат тот же.
По итогу убрал тот конфиг, поставил другой для проверки. Пока тишина. Если и не причина, то довольно интересное совпадение.
hw-probe: тыц!
zanichka
#78
09 сен 2018, 20:36
Всем спасибо за помощь, но все таки подвернулся вариант и я обменял amd на intel, уже третий день пока полет нормальный. Уж больно надоела эта канитель.
Благодарил (а): 212 раз
#79
09 сен 2018, 20:53
zanichka писал(а):
09 сен 2018, 20:36
Молодец, правильный выбор.
А то перспектива нерадужная..
AlexZ писал(а):
26 авг 2018, 21:29
Для десктопа апреля 2018г с АМД тебе только новые ядра пытать, со временем вероятно появится полноценная поддержка..
"со временем" это пара-тройка лет, я думаю.. :smile:
