Realtek RTL8723DE модуль для Linux ядро версии >= 4.11
Aston_
#21
09 июл 2018, 20:41
darkfenix,
aston@aston-HP:~/Загрузки/rtl8723de$ make
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.15.0-20-generic/build M=/home/aston/Загрузки/rtl8723de  modules
make[1]: вход в каталог «/usr/src/linux-headers-4.15.0-20-generic»
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_cmd.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_security.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_debug.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_io.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_ioctl_query.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_ioctl_set.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_ieee80211.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_mlme.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_mlme_ext.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_mi.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_wlan_util.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_vht.o
  CC [M]  /home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.o
In file included from ./include/linux/kernel.h:10:0,
                 from ./include/linux/list.h:9,
                 from ./include/linux/module.h:9,
                 from /home/aston/Загрузки/rtl8723de/include/basic_types.h:81,
                 from /home/aston/Загрузки/rtl8723de/include/drv_types.h:31,
                 from /home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.c:22:
/home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.c: In function ‘pwr_state_check_handler’:
./include/linux/compiler.h:328:38: error: call to ‘__compiletime_assert_398’ declared with attribute error: pointer type mismatch in container_of()
  _compiletime_assert(condition, msg, __compiletime_assert_, __LINE__)
./include/linux/compiler.h:308:4: note: in definition of macro ‘__compiletime_assert’
    prefix ## suffix();    \
./include/linux/compiler.h:328:2: note: in expansion of macro ‘_compiletime_assert’
./include/linux/build_bug.h:47:37: note: in expansion of macro ‘compiletime_assert’
 #define BUILD_BUG_ON_MSG(cond, msg) compiletime_assert(!(cond), msg)
./include/linux/kernel.h:947:2: note: in expansion of macro ‘BUILD_BUG_ON_MSG’
  BUILD_BUG_ON_MSG(!__same_type(*(ptr), ((type *)0)->member) && \
./include/linux/timer.h:144:2: note: in expansion of macro ‘container_of’
  container_of(callback_timer, typeof(*var), timer_fieldname)
/home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.c:398:37: note: in expansion of macro ‘from_timer’
  struct pwrctrl_priv *pwrctrlpriv = from_timer(pwrctrlpriv, t, pwr_state_check_timer);
scripts/Makefile.build:332: recipe for target '/home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.o' failed
make[2]: *** [/home/aston/Загрузки/rtl8723de/core/rtw_pwrctrl.o] Error 1
Makefile:1552: recipe for target '_module_/home/aston/Загрузки/rtl8723de' failed
make[1]: *** [_module_/home/aston/Загрузки/rtl8723de] Error 2
make[1]: выход из каталога «/usr/src/linux-headers-4.15.0-20-generic»
Makefile:1884: recipe for target 'modules' failed
make: *** [modules] Error 2
И сного ошибки
#22
09 июл 2018, 20:58
Если тебе ядро 4.15 не принципиально. Поставь ядро 4.14 при помощи ukuu.
Только что пробовал с 4.14.57 - собирается.
Видимо что-то изменилось в ядрах 4.15+, т.к. на 4.17.5 тоже не собирается.
Перед пересборкой сделай make clean
#23
09 июл 2018, 20:59
Aston_ писал(а):
09 июл 2018, 20:41
Это конечно маловероятно, но все же я КРАЙНЕ рекомендую НИКОГДА не делать манипуляций в каталогах с русскими названиями. Создайте себе в домашнем каталоге папку tmp и там куражтесь сколько влезет.
Никогда не знаешь когда выстрелит косяк с названиями в пути содержащими не только латиницу (включая пробелы, русские буквы и остальные неожиданные символы).
ALISX
Благодарил (а): 7 раз
#24
10 июл 2018, 10:48
А power managment работает у кого-нибудь?У меня для RTL8723DE жрет аккумулятор дико, а iwconfig power on говорит, что операция не поддерживается.
#25
10 июл 2018, 10:55
ALISX, это вопрос отдельной темы.
ALISX
#26
10 июл 2018, 10:59
Кстати, может кому-то понадобится. Ставил дрова отсюда - https://github.com/lwfinger/rtlwifi_new.git. Но по инструкции из issues вот такой:
git clone https://github.com/lwfinger/rtlwifi_new.git -b extended
cd rtlwifi_new
make
sudo make install
sudo reboot
Без переключения на ветку extended скомпилированный модуль не добавлялся.
Последний раз редактировалось пользователем 1 rogoznik; всего редактировалось раз: 10
Причина: BBcode
Aston_
#27
11 июл 2018, 19:56
09 июл 2018, 20:58
Большое спасибо за этот совет! Поставил ядро 4,14,54. Перезагрузился на него и... вифи сразу заработал, без лишних манипуляций !!!
Так же спасибо всем кто помогал мне разобраться с этой проблемой !
G.A.P
Благодарил (а): 11 раз
#28
01 окт 2018, 19:27
G.A.P писал(а):
26 июн 2018, 20:04
Подтверждаю, решение работает, только что завёлся вайфай на новеньком НР под минтом 19
После установки Kernel: 4.15.0-34-generic x86_64 bits пришлось снова применять костыль, вайфай сам не взлетел :sad:
Win10Pro + AMD
G.A.P
#29
01 окт 2018, 22:59
G.A.P писал(а):
01 окт 2018, 19:27
После обновления до Kernel: 4.15.0-36-generic x86_64 bits вайфай стал работать без костылей :smile:
Network
Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Card-2: Realtek Device d723
driver: rtl8723de v: v5.1.1.8_21285.20171026 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:d723
IF: wlp3s0 state: up speed: N/A duplex: N/A mac: <filter>
Тему можно закрывать.
Win10Pro + AMD
G.A.P
#30
31 дек 2018, 00:40
G.A.P писал(а):
01 окт 2018, 22:59
Не будет работать при чистой установке 19.1 - ставим дрова на ядре 4.15-20, работает.
Обновляемся до 4.15-43 - жопа НГ, какие то пакеты доставлял, всё равно не добился вайфая.
Перешел на 4.18 - поставил дрова без проблем, все старые ярда похерил и работает :smile:
Win10Pro + AMD
G.A.P
#31
30 янв 2019, 12:21
G.A.P писал(а):
31 дек 2018, 00:40
Перешел на 4.18
обновился на 4.18.0-14 вайфай ожидаемо не взлетел, применил костыльный метод.
Win10Pro + AMD
G.A.P
#32
02 апр 2019, 21:36
G.A.P писал(а):
30 янв 2019, 12:21
Я ещё жив и обновляюсь - 4.18.0-17 вайфай пашет без бубна :vic:
Win10Pro + AMD
Благодарил (а): 212 раз
#33
02 апр 2019, 22:09
Целый квест прямо.. :-D
Первый раз вижу такие частые регрессии и исправления при обновлении ядра. Я б наверно уже давно на LMDE перешел.. :smile:
G.A.P
#34
02 апр 2019, 22:24
AlexZ писал(а):
02 апр 2019, 22:09
Целый квест прямо.
Квест был когда в обновляторе напротив ядра 4.18.0-16 было "поддерживается до августа 2019", а напротив свежепоставленного 4.18.0-17 "не поддерживается" - я аж перезагрузился пару раз :blink2: :-D
Win10Pro + AMD
G.A.P
#35
15 май 2019, 11:58
G.A.P писал(а):
02 апр 2019, 21:36
Обновил ядро линуксовое до 5.0.0-15 - на старое откатить пришлось, не пашет вайфайный костылик в новом.
На 4.18.0-20 всё работает нормально.
Win10Pro + AMD
G.A.P
#36
01 авг 2019, 22:28
G.A.P писал(а):
15 май 2019, 11:58
Есть кто живой? :smile:
Не нашлись костыли под ядро 5.0 случайно, а то опять прилетело, пока что не ставлю :-D
Win10Pro + AMD
#37
02 авг 2019, 06:54
Ещё наклейка на "костыль".
https://askubuntu.com/questions/1118497 ... ea/1118523
:hoho:
G.A.P
#38
02 авг 2019, 10:20
etamax, дело в том что этот костыль, которым я и они пользуются, не хочет работать с ядром 5.0 и настраивать нечего... так надеялся что в новом ядре этот головняк пролечат.
а с приёмом сигнала у меня изначально проблем не было с этим костылём, на 4 ядре, возможно ревизии адаптера этого убогого разные бывают.
Win10Pro + AMD
G.A.P
#39
02 авг 2019, 10:32
Ой-ой, меня в гугле забанили - сейчас буду пробовать новый костыль :thumbs:
Win10Pro + AMD
G.A.P
#40
02 авг 2019, 11:29
Наверное глупый вопрос, а костыль от 4 ядра надо обязательно анинсталить, или можно тупо накатить новый? а то оно что то ругнулось на существующий модуль, но после ребута так и не поставилось...
Короче, вернулся на 4 ядро.
Win10Pro + AMD
Вернуться в «Руководства»
