bootstrap.sh: команда не найдена
CheshireCat
Благодарил (а): 2 раза
03 фев 2019, 09:58
Патаюсь собрать boost:
&bootstrap.sh --help
https://www.boost.org/doc/libs/1_69_0/m ... st-library
Команду запускю из терминала.
Запускал и с sudo и без
Выдал права на исполнение, всё равно не запускается.
Решение rogoznik » 03 фев 2019, 10:14
Вот стянул вот это (понятия не имею то или нет). Однако файл bootstrap.sh имеется
~/src/boost  master ✔        22h23m
▶ ls
appveyor.yml     boostcpp.jam  boost.png      bootstrap.sh  doc        index.html  Jamroot  LICENSE_1_0.txt  rst.css  tools
boost-build.jam  boost.css     bootstrap.bat  circle.yml    index.htm  INSTALL     libs     more             status
▶ chmod a+x bootstrap.sh
И получил
~/src/boost  master ✔        22h24m
▶ ./bootstrap.sh --help
`./bootstrap.sh' prepares Boost for building on a few kinds of systems.
Usage: ./bootstrap.sh [OPTION]...
Defaults for the options are specified in brackets.
Configuration:
  -h, --help                display this help and exit
  --with-bjam=BJAM          use existing Boost.Jam executable (bjam)
                            [automatically built]
  --with-toolset=TOOLSET    use specific Boost.Build toolset
                            [automatically detected]
  --show-libraries          show the set of libraries that require build
                            and installation steps (i.e., those libraries
                            that can be used with --with-libraries or
                            --without-libraries), then exit
  --with-libraries=list     build only a particular set of libraries,
                            describing using either a comma-separated list of
                            library names or "all"
                            [all]
  --without-libraries=list  build all libraries except the ones listed []
  --with-icu                enable Unicode/ICU support in Regex
  --without-icu             disable Unicode/ICU support in Regex
  --with-icu=DIR            specify the root of the ICU library installation
                            and enable Unicode/ICU support in Regex
  --with-python=PYTHON      specify the Python executable [python]
  --with-python-root=DIR    specify the root of the Python installation
  --with-python-version=X.Y specify the Python version as X.Y
Installation directories:
  --prefix=PREFIX           install Boost into the given PREFIX
                            [/usr/local]
  --exec-prefix=EPREFIX     install Boost binaries into the given EPREFIX
                            [PREFIX]
More precise control over installation directories:
  --libdir=DIR              install libraries here [EPREFIX/lib]
  --includedir=DIR          install headers here [PREFIX/include]
Последний раз редактировалось пользователем 3 CheshireCat; всего редактировалось раз: 3
03 фев 2019, 10:05
CheshireCat писал(а):
03 фев 2019, 09:58
Рад за тебя.
Только откуда уверенность что все тут знают это такое?
Так сложно дать ссылку чтоб можно было сразу узнать что ты собираешь и из чего?
Откуда команду запускаешь?
Права на исполнение скрипту выдал?
03 фев 2019, 10:14
▶ ls
И получил
Configuration:
                            [all]
                            [/usr/local]
                            [PREFIX]
CheshireCat
03 фев 2019, 10:18
03 фев 2019, 10:21
03 фев 2019, 10:18
Это все что осилил? Остальные вопросы решил игнорировать. Ну ок.
CheshireCat
03 фев 2019, 10:22
Я добавил в свой вопрос ответы на все ваши вопросы.
03 фев 2019, 10:27
CheshireCat, нашел по твоей ссылке ссылку на скачивание, скачал, распаковал.
Далее в терминале
~/src
▶ cd boost_1_67_0
~/src/boost_1_67_0
~/src/boost_1_67_0
Configuration:
                            [all]
                            [/usr/local]
                            [PREFIX]
Все отрабатывает
CheshireCat
03 фев 2019, 10:31
Понял свою ошибку: я пытался запустить просто bootstrap.sh без ./. Что дает ./?
03 фев 2019, 10:33
Обращение к исполняемому файлу. Так приходится обращаться, потому что иначе shell пытается искать в каталогах из PATH, а там естественно нет такого исполняемого файла - вот и ошибка. Ну это если в двух словах.
CheshireCat
03 фев 2019, 10:39
Так теперь когда пытаюсь непосредственно начать сборку :
sudo ./bootstrap.sh
Выдает:
Permission denied
Насколько я понял, это потомучто он пытается собрать в /usr/local/, но я же через sudo это делаю.
03 фев 2019, 10:55
CheshireCat, внимательно прочти это. Так ли тебе надо чтоб оно установилось в /usr/local. Там же написано что можно задать свой префикс для установки, а потом просто добавить этот префикс в PATH. Сделать это не сложно. Открыть файл ~/.bashrc и добавить в него это
export PATH=/path/to/prefix:$PATH
03 фев 2019, 15:43
CheshireCat, собрал, запустил?
CheshireCat
03 фев 2019, 20:42
Там было ещё проблемма, не связанная напрямую с linux, но вроде собрал.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 13 гостей
