Вывод
Host: VAIO Kernel: 5.0.0-15-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa base: Ubuntu 18.04 bionic Machine: Type: Laptop System: Sony product: VPCEB1E1R v: C603S026 serial: <filter> Mobo: Sony model: VAIO serial: <filter> BIOS: American Megatrends v: R0220Y8 date: 01/12/2010 CPU: Topology: Dual Core model: Intel Core i3 M 330 bits: 64 type: MT MCP arch: Nehalem rev: 2 L2 cache: 3072 KiB flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17025 Speed: 1058 MHz min/max: 933/2133 MHz Core speeds (MHz): 1: 1129 2: 1167 3: 1182 4: 1146 Graphics: Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: Sony driver: radeon v: kernel bus ID: 01:00.0 Display: x11 server: X.Org 1.19.6 driver: ati,radeon unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 5.0.0-15-generic LLVM 7.0.0) v: 3.3 Mesa 18.2.8 direct render: Yes Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony driver: snd_hda_intel v: kernel bus ID: 00:1b.0 Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series] vendor: Sony driver: snd_hda_intel v: kernel bus ID: 01:00.1 Device-3: JMTek LLC. type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1.6:4 Sound Server: ALSA v: k5.0.0-15-generic Network: Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter vendor: Foxconn T77H126.00 802.11bgn driver: ath9k v: kernel port: d000 bus ID: 02:00.0 IF: wlp2s0 state: down mac: <filter> Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB] vendor: Sony driver: sky2 v: 1.30 port: a000 bus ID: 04:00.0 IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter> Drives: Local Storage: total: 298.09 GiB used: 11.22 GiB (3.8%) ID-1: /dev/sda vendor: Toshiba model: MK3265GSX size: 298.09 GiB Partition: ID-1: / size: 29.76 GiB used: 10.71 GiB (36.0%) fs: ext4 dev: /dev/sda6 ID-2: swap-1 size: 3.81 GiB used: 523.0 MiB (13.4%) fs: swap dev: /dev/sda5 Sensors: System Temperatures: cpu: 48.0 C mobo: N/A gpu: radeon temp: 51 C Fan Speeds (RPM): N/A Info: Processes: 211 Uptime: 3h 35m Memory: 3.71 GiB used: 2.37 GiB (64.0%) Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.19 inxi: 3.0.27
