Проблема с установкой Wine.
elenass
27 окт 2019, 12:35
Здравствуйте! У меня операционная система Tina i386, Cinnamon.
Характеристики:
Host: SAMSUNG-R510-Elena
Kernel: 4.15.0-54-generic i686
bits: 32 compiler: gcc v: 7.4.0
Desktop: Cinnamon 4.2.4
Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: SAMSUNG
product: R510/P510 v: N/A
serial: <filter>
Mobo: SAMSUNG model: R510/P510
serial: <filter> BIOS: Phoenix
v: 06LI.MP00.20080919.SCY
date: 09/19/2008
ID-1: BAT1 charge: 10.2 Wh
condition: 16.6/44.4 Wh (37%)
model: SAMSUNG Electronics
status: Discharging
Topology: Dual Core
model: Intel Core2 Duo T5850 bits: 64
type: MCP arch: Core Merom rev: D
L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3
bogomips: 8644
Speed: 1315 MHz
min/max: 1000/2166 MHz
Core speeds (MHz): 1: 1207 2: 1195
Device-1: NVIDIA G98M [GeForce 9200M
GS]
vendor: Samsung Co driver: nvidia
v: 340.107 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6
driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa
resolution: 1280x800~60Hz
OpenGL:
renderer: GeForce 9200M GS/PCIe/SSE2
v: 3.3.0 NVIDIA 340.107
Device-1: Intel 82801I HD Audio
vendor: Samsung Co
driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA
v: k4.15.0-54-generic
Device-1: Qualcomm Atheros AR242x /
AR542x Wireless Network Adapter
vendor: Askey driver: ath5k v: kernel
port: 2000 bus ID: 02:00.0
Device-2: Marvell 88E8055 PCI-E
Gigabit Ethernet
vendor: Samsung Co driver: sky2
v: 1.30 port: 5000 bus ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 186.31 GiB
used: 15.28 GiB (8.2%)
ID-1: /dev/sda vendor: Fujitsu
model: MHZ2200BH G2 size: 186.31 GiB
temp: 51 C
ID-1: / size: 182.38 GiB
used: 15.28 GiB (8.4%) fs: ext4
dev: /dev/sda1
System Temperatures: cpu: 70.0 C
mobo: 70.0 C gpu: nvidia temp: 75 C
Processes: 184 Uptime: 35m
Memory: 1.96 GiB
used: 1.21 GiB (61.7%) Init: systemd
runlevel: 5 Compilers: gcc: 7.4.0
Shell: bash v: 4.4.20 inxi: 3.0.32
Я установил Wine командой:
root@SAMSUNG-R510-Elena:/home/elena/Загрузки# apt-get install winehq-stable
wine-stable wine-stable-i386
Рекомендуемые пакеты:
libcapi20-3 libodbc1 libosmesa6 libsdl2-2.0-0
Следующие НОВЫЕ пакеты будут установлены:
wine-stable wine-stable-i386 winehq-stable
Обновлено 0 пакетов, установлено 3 новых пакетов, для удаления отмечено 0 пакетов, и 100 пакетов не обновлено.
Необходимо скачать 24,0 MB архивов.
После данной операции объём занятого дискового пространства возрастёт на 214 MB.
Хотите продолжить? [Д/н] Д
Пол:1 http://packages.linuxmint.com tina/import i386 wine-stable-i386 i386 4.0~bionic [22,9 MB]
Пол:2 http://packages.linuxmint.com tina/import i386 wine-stable i386 4.0~bionic [1 124 kB]
Пол:3 http://packages.linuxmint.com tina/import i386 winehq-stable i386 4.0~bionic [1 888 B]
Получено 24,0 MB за 26с (931 kB/s)
Выбор ранее не выбранного пакета wine-stable-i386.
(Чтение базы данных … на данный момент установлено 259245 файлов и каталогов.)
Подготовка к распаковке …/wine-stable-i386_4.0~bionic_i386.deb …
Распаковывается wine-stable-i386 (4.0~bionic) …
Выбор ранее не выбранного пакета wine-stable.
Подготовка к распаковке …/wine-stable_4.0~bionic_i386.deb …
Распаковывается wine-stable (4.0~bionic) …
Выбор ранее не выбранного пакета winehq-stable.
Подготовка к распаковке …/winehq-stable_4.0~bionic_i386.deb …
Распаковывается winehq-stable (4.0~bionic) …
Настраивается пакет wine-stable-i386 (4.0~bionic) …
Настраивается пакет wine-stable (4.0~bionic) …
Настраивается пакет winehq-stable (4.0~bionic) …
Обрабатываются триггеры для gnome-menus (3.13.3-11ubuntu1.1) …
Обрабатываются триггеры для mime-support (3.60ubuntu1) …
Обрабатываются триггеры для desktop-file-utils (0.23+linuxmint6) …
Обрабатываются триггеры для libc-bin (2.27-3ubuntu1) …
Обрабатываются триггеры для man-db (2.8.3-2ubuntu0.1) …
Захожу в меню и не вижу Wine.
Почему это могло произойти?
Я качал образ амд64, а установился и386 можно это исправить?
27 окт 2019, 13:48
Пакет установки универсальный значит. Если система 64 то ставит 64, если 32 то ставит 32.
27 окт 2019, 13:50
Dja писал(а):
27 окт 2019, 13:48
Это ты о чем, о каком пакете?
elenass писал(а):
27 окт 2019, 12:35
Потому что нечего добавлять в меню.
27 окт 2019, 14:18
darkfenix, о скриптовом. Качаешь, извлекаешь из архива. Там папки 32 и 64. пускаешь install и он ставит из той папки, которая твоей системы. 64-64 32-32 полно таких. К принтеру такой ставил.
27 окт 2019, 14:19
elenass писал(а):
27 окт 2019, 12:35
Неплохо бы перезагрузиться да и запустить что нибудь , там кое что ещё может подтянуться.
colonel
Решено: 21
27 окт 2019, 17:59
elenass писал(а):
27 окт 2019, 12:35
ничего не надо исправлять. скорее всего 386 -e установились по зависимостям. и потребуются для работы вайна.
elenass писал(а):
27 окт 2019, 12:35
27 окт 2019, 13:50
почему? очевидно недостаток в работе установщика вайна или сборки деб-пакета , из-за чего в меню не "прописался" раздел Wine и сторока запуска конфигуратора Wine-cofigurator (ну и ещё некоторых вайновских сопутствующих программок)
а может вы не нашли в меню эти строку.
если нет строки Wine-cofigurator то можете сами ручками в редакторе меню создать такую строку с командой запуска - winecfg
Благодарил (а): 212 раз
29 окт 2019, 23:19
elenass писал(а):
27 окт 2019, 12:35
Снова да ладом.. :hoho:
Чем не устроил тот же winehq-stable в Менеджере программ (в категории Выбор редакции), через пакет wine-installer и везде всё показывающий?
colonel писал(а):
27 окт 2019, 17:59
elenass писал(а): ↑
27 окт 2019, 12:35
О чем это? У него система 32-бит ("Tina i386") и он про установочный образ спрашивает
colonel
Решено: 21
30 окт 2019, 00:19
AlexZ писал(а):
29 окт 2019, 23:19
...О чем это?...
да ни о чём ...
напутал немного и всвязи со сказанным во #2 - "Пакет установки универсальный значит. Если система 64 то ставит 64, если 32 то ставит 32."
решил что речь о том что устанавливался вайн64бит, и ТС спрашивал почему и откуда у него установились и 32битные пакеты вайна
в общем, забыть и наплевать.
к сказанному в том же сообщении по поводу "Почему это могло произойти?" претензии есть?
