Не могу избавиться от LM
zed
29 окт 2019, 14:35
1. LM 19.2 x64 xfce
2.
Host: Paul Kernel: 4.15.0-66-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Xfce 4.12.3 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Type: Laptop System: ASUSTeK product: X550CC v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X550CC v: 1.0 serial: <filter>
BIOS: American Megatrends v: X550CC.212 date: 05/29/2013
ID-1: BAT0 charge: 23.5 Wh condition: 23.5/44.6 Wh (53%)
model: ASUSTeK X550A30 status: Full
Topology: Dual Core model: Intel Pentium 2117U bits: 64 type: MCP
arch: Ivy Bridge rev: 9 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 7183
Speed: 1058 MHz min/max: 800/1800 MHz Core speeds (MHz): 1: 877 2: 825
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: ASUSTeK driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau
unloaded: fbdev,vesa resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.0.8
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK
Sound Server: ALSA v: k4.15.0-66-generic
Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter
vendor: AzureWave driver: ath9k v: kernel port: e000 bus ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: 2.3LK-NAPI port: d000 bus ID: 04:00.2
IF: enp4s0f2 state: down mac: <filter>
Device-3: IMC Networks Atheros AR3012 Bluetooth 4.0 Adapter type: USB
driver: btusb bus ID: 1-1.1:5
Local Storage: total: 465.76 GiB used: 18.43 GiB (4.0%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050B7E660
ID-1: / size: 457.45 GiB used: 18.43 GiB (4.0%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2000
Processes: 169 Uptime: 14m Memory: 3.74 GiB used: 1011.6 MiB (26.4%)
inxi: 3.0.32
3. Не устанавливается Wndows 7 с флешки. Либо выдает "reboot and select proper boot device", либо просто-напросто запускается LM. Не смотря на то, что в Boot Option на первом месте стоит загрузочная флешка.
UncleKruk
29 окт 2019, 14:47
В BIOS отключи режим UEFI (EFI) и переведи в режим Legacy если хочешь поставить Win7. Или погугли как поставить Win 7 на UEFI GPT
zed
29 окт 2019, 14:54
Как отключить режим UEFI (EFI) и перевести в Legacy?
zed
29 окт 2019, 14:56
Лол, у меня вообще не UEFI. В чем тогда проблема?
S.A.
Благодарил (а): 9 раз
29 окт 2019, 14:59
Установочную флешку чем записывали? Попробуйте записать через Rufus.
Благодарил (а): 406 раз
29 окт 2019, 15:22
Флэха нифига ни загрузочная, - оно ж тебе простым аглицким языком об том и сказало.
29 окт 2019, 15:37
S.A. писал(а):
29 окт 2019, 14:59
В минте руфусом винду не пишут . :hoho: woeusb .
S.A.
29 окт 2019, 15:40
etamax писал(а):
29 окт 2019, 15:37
А где написано, что писАть нужно в Минте?
29 окт 2019, 15:43
S.A. писал(а):
29 окт 2019, 15:40
В первом посте . У ТС минт и он хочет установить семёрку.
zed
29 окт 2019, 15:46
Почему флешка не загрузочная? Писал ее в Минте.
29 окт 2019, 15:48
zed писал(а):
29 окт 2019, 15:46
Писал ее в Минте.
Тогда может скажешь как писал? Чтоб мы не думали , что ручкой на столе.
zed
29 окт 2019, 15:49
Походу проблема в том, что я образ Win 7 писал на Минте через Минтовской софт (USB writer). Стоит ли писать заново но на винде? (есть ноут с виндой) И через какую прогу лучше?
zed
29 окт 2019, 15:52
Все из-за USB Image Writer, да?
29 окт 2019, 15:53
Винду писать не так то просто. Из личного опыта , я писал woeusb и ставил gparted на разделе метку boot .
S.A.
29 окт 2019, 15:53
zed писал(а):
29 окт 2019, 15:49
Таким способом установочную флешку с Windows не запишите (не будет она загружаться). Если есть возможность, то проще всего записывать флешку в Windows.
zed
29 окт 2019, 15:57
Оке, запишу на Windows. Какой прогой лучше? Дабы я опять не напартачил
S.A.
29 окт 2019, 16:02
Я предлагал Rufus. Если у Вас нет UEFI, то в настройках Rufus выбрать MBR для ПК с BIOS.
29 окт 2019, 16:05
S.A. писал(а):
29 окт 2019, 16:02
Я предлагал Rufus
Вот что то у меня сомнения , но попробовать можно
Благодарил (а): 1211 раз
29 окт 2019, 16:19
etamax писал(а):
29 окт 2019, 16:05
Rufus отличная прога и подходит для записи любых загрузочных образов для любых осей (Windows. Linux). Всегда ей пользуюсь, потому как одну винду всё-таки дома держу на всякий случай, да и принтер RICOH у меня только на винде работает. На Linux его завести невозможно.
29 окт 2019, 17:15
zed писал(а):
29 окт 2019, 15:49
usb-creator-gtk
или
unetbootin (предварительно сделать флэху загрузочной в GParted)
или в консоли: sudo dd if=Виндоуз.iso of=/dev/sdf bs=4M status=progress (где sd* - флэшка)
Последний раз редактировалось пользователем 1 x230; всего редактировалось раз: 29
Вернуться в «Xfce»
