дек 20 12:14:47 comp polkitd(authority=local)[967]: Registered Authentication Agent for unix-process:3065:112735 (system bus name :1.101 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale ru_RU.UTF-8)
дек 20 12:14:52 comp polkit-agent-helper-1[3071]: pam_ecryptfs: pam_sm_authenticate: /home/user is already mounted
дек 20 12:14:52 comp polkitd(authority=local)[967]: Operator of unix-session:c2 successfully authenticated as unix-user:user to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.102 [systemctl start home-user-public.mount] (owned by unix-user:user)
дек 20 12:14:52 comp systemd[1]: Mounting Mount point for cifs...
-- Subject: Начинается запуск юнита home-user-public.mount
-- Defined-By: systemd
-- Support:
http://www.ubuntu.com/support
-- Начат процесс запуска юнита home-user-public.mount.
дек 20 12:14:52 comp kernel: FS-Cache: Loaded
дек 20 12:14:52 comp kernel: FS-Cache: Netfs 'cifs' registered for caching
дек 20 12:14:52 comp kernel: Key type cifs.spnego registered
дек 20 12:14:52 comp kernel: Key type cifs.idmap registered
дек 20 12:14:52 comp kernel: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3 (or SMB2.1) specify vers=1.0 on mount.
дек 20 12:14:52 comp kernel: CIFS VFS: ioctl error in smb2_get_dfs_refer rc=-5
дек 20 12:14:52 comp systemd[1]: Mounted Mount point for cifs.
-- Subject: Запуск юнита home-user-public.mount завершен
-- Support:
-- Процесс запуска юнита home-user-public.mount был завершен.
-- Результат: RESULT.
