Systemd-analyze plot - делимся, сравниваем...
Bill Williamson
Решено: 34
Благодарил (а): 288 раз
systemd-analyze plot - делимся, сравниваем...
#61
23 янв 2017, 00:30
Не совсем Mint, ну так - для сравнения:
http://imgh.us/dell-pc-4.8.13-1-ARCH_1.svg
Resuming in non X mode: xrandr not found. For package install advice run: inxi --recommends
System: Host: dell-pc Kernel: 4.8.13-1-ARCH x86_64 (64 bit gcc: 6.2.1)
Desktop: Xfce 4.12.3 (Gtk 2.24.31) Distro: Arch Linux
Machine: Device: portable System: Dell product: Inspiron N5050
Mobo: Dell model: 01HXXJ v: A03 BIOS: Dell v: A03 date: 10/14/2011
Battery BAT0: charge: 44.0 Wh 1437.9% condition: 3.1/44.0 Wh (7%)
model: LGC-LGC2.2 DELL GK2X622 status: Full
CPU: Dual core Intel Core i3-2350M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9182
clock speeds: max: 2300 MHz 1: 994 MHz 2: 813 MHz 3: 806 MHz
4: 805 MHz
Graphics: Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
bus-ID: 00:02.0
Display Server: N/A drivers: intel (unloaded: modesetting,fbdev,vesa)
Resolution: 80x24
Audio: Card Intel 6 Series/C200 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.8.13-1-ARCH
Network: Card-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Card-2: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter
driver: wl bus-ID: 09:00.0
IF: wlp9s0 state: up mac: <filter>
Drives: HDD Total Size: 500.1GB (10.5% used)
ID-1: /dev/sda model: ST9500325AS size: 500.1GB
Partition: ID-1: / size: 98G used: 7.1G (8%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 97M used: 43M (47%) fs: ext2 dev: /dev/sda1
ID-3: /home size: 357G used: 41G (12%) fs: ext4 dev: /dev/sda4
ID-4: swap-1 size: 2.15GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors: System Temperatures: cpu: 59.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 169 Uptime: 3:36 Memory: 817.8/3864.4MB
Init: systemd Gcc sys: 6.3.1
Client: Shell (bash 4.4.51) inxi: 2.3.8
#62
23 янв 2017, 01:09
Последние два результата почти сопоставимы) только о железе предыдущего не знаем :smile:
но 25-30 секунд для загрузки с hdd - отличный результат
Теперь к некоторой критике советов от NikolS :smile:
NikolS писал(а): vm.swappiness=0
лучше все-таки чуть больше нуля (пятерку или единичку хотя бы), чтоб не словить OOM при внезапном жоре - может никогда и не встретится, но тут зависит от задач (значение отражает процентарный остаток оперативной памяти при котором стоит задействовать своп, поэтому при невысоких значениях параметра "эффективность использования" ОЗУ мы не потеряем)
NikolS писал(а): # gedit /etc/sysctl.conf
К минтам не применимо, там где был gedit нету утилиты которую обсуждаем (systemd-analyze), начиная с Sarah везде xapps (xed)
NikolS писал(а): # gedit /etc/init.d/rc
Здесь могу ошибаться, но станет ли systemd в работе использовать эти legacy параметры из /etc/init.d/ ? :hm:
NikolS писал(а): Немного ускорим графику, присвоив ей приоритет 20.
Иксы, лишь фронтенд занимающийся отрисовом того что просчитывается бэкендом "под капотом", поэтому отдав nice им - можно поймать и другие очевидные неприятности
Вот мои соображения.
NikolS, откуда эти советы, если не секрет?
#63
23 янв 2017, 01:17
Chocobo писал(а): К минтам не применимо, там где был gedit нету утилиты которую обсуждаем (systemd-analyze), начиная с Sarah везде xapps (xed)
Кстати, помнишь на старом форуме делали мы мне gedit cначала алиасом, а потом линком. Надо будет инкарнировать тут темку. Т.к. удобно получилось для тупого копипаста рецептов. Ну а вообще, в 17.х еще getdit был.
#64
23 янв 2017, 01:20
di_mok, в корице был, но тут же речь про системду изначльно в теме, поэтому решил пресечь такие вот выхлопы
chocobo@desktop ~ $ sudo gedit /etc/sysctl.conf
[sudo] пароль для chocobo:
sudo: gedit: команда не найдена
А так - да можно и алиас, можно и просто симлинк с xed на gedit
#65
23 янв 2017, 01:38
Chocobo писал(а): но тут же речь про системду
А, ну да. Что-то я это не учёл.
#66
23 янв 2017, 04:06
После еще некоторых твиков и оптимизаций над тем же хостом, что в #58 - удалось добиться картины в 4.3 сек (раньше не получалось :smile:)
http://imgh.us/desktop-4.4.0-53-generic_1.svg
#67
23 янв 2017, 16:34
Chocobo, ты не в курсе ureadahead.service реально ускоряет загрузку любого ДЕ? А то это чисто Каноникалская приблуда в ядро, если актуальна только для Юнити, то выкину из системыд.
NikolS
#68
23 янв 2017, 21:37
настройки оптимизации находил по-моему на compizomania точно не вспомню уже
#69
24 янв 2017, 01:09
Unborn, Врать не стану, глубоко с ним не знаком - но порывшись по инфе, вряд ли оно заточено под юнити, ибо нарисовалось еще с Убунты 9.10 и упоминается предок как редхатовский sreadahead.
NikolS, не было целью поглумится над методами, просто из разряда "доверяй но проверяй" :smile:
По твоему графику я бы выпилил еще:
  • lvm2-monitor.service (5.379s) (если при установке выбирал не LVM разделы)
    speech-dispatcher.service (2.762s) (софтварная говорилка)
    virtualbox-guest-utils.service (2.861s) (нужно только при запуске минта гостем в вбоксе - всегда под нож на железном хосте)
    vboxdrv.service (2.347s) (если виртуалбокс использовать не планируется)
Свежий Ветер
Благодарил (а): 36 раз
#70
24 янв 2017, 01:47
О, я на своем мамонте, походу, победил, и это при том, что раздел с датами автоматом монтируется. моё
Глаза боятся, а руки - крюки.
#71
29 янв 2017, 01:18
LMDE2 Betsy x64 - http://imgh.us/desktop-3.16.0-4-amd64.svg
chocobo@desktop ~ $ systemd-analyze
Startup finished in 2.037s (kernel) + 1.017s (userspace) = 3.054s
:bravo:
И это голая установка без единого твика, юзерспейс еще возможно чутка подвинется...
inxi
chocobo@desktop ~ $ inxi -Fxz
System:    Host: desktop Kernel: 3.16.0-4-amd64 x86_64 (64 bit gcc: 4.8.4)
           Desktop: Cinnamon 3.2.7 (Gtk 2.24.25-3+deb8u1)
           Distro: LinuxMint 2 betsy
Machine:   Mobo: ASUSTeK model: H61M-K v: Rev X.0x
           Bios: American Megatrends v: 0801 date: 07/21/2014
CPU:       Dual core Intel Core i5-3470T (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11574
           Clock Speeds: 1: 1628 MHz 2: 1667 MHz 3: 1600 MHz 4: 1607 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Curacao XT [Radeon R9 270X]
           bus-ID: 01:00.0
           Display Server: X.Org 1.16.4 driver: fglrx
           Resolution: 1920x1080@60.00hz
           GLX Renderer: AMD Radeon R9 200 Series
           GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Audio:     Card-1 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Card-2 Advanced Micro Devices [AMD/ATI] Cape Verde/Pitcairn HDMI Audio [Radeon HD 7700/7800 Series]
           Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 03:00.0
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 535.9GB (8.8% used)
           ID-1: /dev/sda model: WDC_WD4000AAJS size: 400.1GB
           ID-2: /dev/sdb model: SSD_Smartbuy_120 size: 120.0GB
           ID-3: USB /dev/sdc model: Transcend_16GB size: 15.8GB
Partition: ID-1: / size: 110G used: 4.7G (5%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 93G used: 39G (45%) fs: ext4 dev: /dev/sda1
           ID-3: /var size: 42G used: 753M (2%) fs: ext4 dev: /dev/sda2
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C gpu: 31.00C
Info:      Processes: 163 Uptime: 1:15 Memory: 1037.0/7945.8MB
           Init: systemd runlevel: 5 Gcc sys: 4.9.2
           Client: Shell (bash 4.3.301) inxi: 2.1.28
#72
29 янв 2017, 09:53
Да уж! Хотел тоже попробовать, но железяка не показала на LMDE таких результатов. :cray2:
До и после косметического ремонта. :smile:
Startup finished in 6.643s (kernel) + 27.490s (userspace) = 34.134s
Startup finished in 5.187s (kernel) + 15.209s (userspace) = 20.397s
#73
29 янв 2017, 10:58
Предлагаю мериться пиписьками с обязательным выводом inxi
#74
29 янв 2017, 11:29
di_mok,
Свою показуй.
System: Host: msuser64 Kernel: 4.4.0-59-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.1)
Distro: Linux Mint 18.1 Serena
Machine: Mobo: Foxconn model: 945 7MA Series
Bios: Phoenix v: 6.00 PG date: 06/19/2007
CPU: Dual core Intel Pentium D (-MCP-) cache: 2048 KB
flags: (lm nx sse sse2 sse3) bmips: 11998
clock speeds: max: 3000 MHz 1: 2400 MHz 2: 2400 MHz
Graphics: Card: Intel 82945G/GZ Integrated Graphics Controller
bus-ID: 00:02.0
Resolution: 1024x768@60.00hz
GLX Renderer: Mesa DRI Intel 945G
GLX Version: 1.4 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.4.0-59-generic
Network: Card-1: Qualcomm Atheros AR9227 Wireless Network Adapter
driver: ath9k bus-ID: 01:02.0
IF: wlp1s2 state: down mac: <filter>
Card-2: Broadcom NetXtreme BCM5788 Gigabit Ethernet
driver: tg3 v: 3.137 bus-ID: 01:03.0
IF: enp1s3 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: HDD Total Size: 520.2GB (5.3% used)
ID-1: /dev/sdb model: WDC_WD1600JB size: 160.0GB
ID-2: /dev/sdc model: ST9320325AS size: 320.1GB
ID-3: /dev/sda model: SAMSUNG_SP0411N size: 40.1GB
Partition: ID-1: / size: 24G used: 8.4G (37%) fs: ext4 dev: /dev/sdc6
ID-2: /home size: 69G used: 16G (24%) fs: ext4 dev: /dev/sdc7
ID-3: swap-1 size: 2.83GB used: 0.00GB (0%) fs: swap dev: /dev/sdc5
Sensors: System Temperatures: cpu: 40.0C mobo: N/A
Info: Processes: 188 Uptime: 35 min Memory: 1048.9/2494.9MB
Client: Shell (bash 4.3.461) inxi:
:-D
#75
29 янв 2017, 11:37
di_mok, дополнил.
#76
19 фев 2017, 00:51
А такой старт потянет на шаманский? Хочу заметить, что тут тугой бучный HDD
4.342s dev-sda1.device
2.494s accounts-daemon.service
2.219s gpu-manager.service
1.922s loadcpufreq.service
1.910s irqbalance.service
1.858s grub-common.service
1.757s console-setup.service
1.746s ondemand.service
1.448s systemd-logind.service
1.420s hddtemp.service
1.309s console-kit-log-system-start.service
1.254s speech-dispatcher.service
1.251s plymouth-start.service
1.239s lm-sensors.service
1.238s alsa-restore.service
1.231s pppd-dns.service
1.228s systemd-user-sessions.service
1.223s rsyslog.service
1.207s thermald.service
1.202s bluetooth.service
1.201s avahi-daemon.service
1.156s NetworkManager.service
983ms systemd-udevd.service
790ms keyboard-setup.service
694ms systemd-tmpfiles-setup-dev.service
483ms systemd-journald.service
462ms polkitd.service
461ms systemd-modules-load.service
456ms systemd-fsck@dev-disk-by\x2duuid-e624269f\x2dda18\x2d460e\x2da062\x2dd266a63f8cf0.service
450ms upower.service
385ms binfmt-support.service
347ms dev-hugepages.mount
318ms networking.service
308ms wpa_supplicant.service
308ms systemd-rfkill.service
305ms dev-mqueue.mount
304ms sys-kernel-debug.mount
273ms systemd-tmpfiles-setup.service
252ms home.mount
247ms setvtrgb.service
206ms cpufrequtils.service
168ms plymouth-quit.service
168ms plymouth-quit-wait.service
159ms systemd-backlight@backlight:intel_backlight.service
141ms systemd-update-utmp.service
132ms systemd-sysctl.service
130ms systemd-udev-trigger.service
105ms dev-disk-by\x2duuid-cbcf9725\x2dc407\x2d4f60\x2d8c9e\x2d46d42e18dab0.swap
99ms systemd-hostnamed.service
89ms openvpn.service
83ms kmod-static-nodes.service
72ms NetworkManager-dispatcher.service
72ms udisks2.service
71ms proc-sys-fs-binfmt_misc.mount
71ms console-kit-daemon.service
70ms systemd-remount-fs.service
62ms user@1000.service
58ms dns-clean.service
50ms systemd-random-seed.service
44ms ufw.service
41ms colord.service
32ms systemd-journal-flush.service
12ms plymouth-read-write.service
5ms systemd-update-utmp-runlevel.service
4ms ureadahead-stop.service
3ms sys-fs-fuse-connections.mount
3ms rtkit-daemon.service
2ms resolvconf.service
2ms rc-local.service
713us nvidia-persistenced.service
Железо
System: Host: dimok-nb Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.1)
Machine: System: SAMSUNG product: 300E4C/300E5C/300E7C v: 0.1
Mobo: SAMSUNG model: NP310E5C-U03RU v: FAB1
Bios: Phoenix v: P02RAP date: 08/21/2012
CPU: Dual core Intel Core i5-3210M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9976
clock speeds: max: 3100 MHz 1: 1296 MHz 2: 1261 MHz 3: 1211 MHz
4: 1296 MHz
Graphics: Card-1: Intel 3rd Gen Core processor Graphics Controller
bus-ID: 00:02.0
Card-2: NVIDIA GF108M [GeForce GT 620M] bus-ID: 01:00.0
Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa)
Resolution: 1366x768@60.05hz
GLX Renderer: Mesa DRI Intel Ivybridge Mobile
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
Audio: Card Intel 7 Series/C210 Series Family High Definition Audio Controller
Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network: Card-1: Qualcomm Atheros AR9485 Wireless Network Adapter
driver: ath9k bus-ID: 02:00.0
driver: r8169 v: 2.3LK-NAPI port: 2000 bus-ID: 03:00.0
Drives: HDD Total Size: 500.1GB (2.3% used)
ID-1: /dev/sda model: Hitachi_HTS54755 size: 500.1GB
Partition: ID-1: / size: 28G used: 6.7G (26%) fs: btrfs dev: /dev/sda1
ID-2: /home size: 435G used: 294M (1%) fs: btrfs dev: /dev/sda6
ID-3: swap-1 size: 4.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 57.0C mobo: 29.8C
Info: Processes: 234 Uptime: 11 min Memory: 939.5/3655.1MB
Client: Shell (bash 4.3.461) inxi: 2.2.35
Vagrant
#77
07 мар 2017, 22:54
Продолжаю заниматься баловством эксперименты,
теперь XFCE
Калькулятор:
System: Host: AIR Kernel: 4.4.0-64-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.1 Serena
Machine: Mobo: ASUSTeK model: M5A97 R2.0 v: Rev 1.xx
Bios: American Megatrends v: 2603 date: 06/26/2015
CPU: Hexa core AMD FX-6300 Six-Core (-MCP-) cache: 12288 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 42137
clock speeds: max: 3500 MHz 1: 2000 MHz 2: 1400 MHz 3: 2000 MHz
4: 1400 MHz 5: 1400 MHz 6: 1400 MHz
Graphics: Card: NVIDIA GF110 [GeForce GTX 570] bus-ID: 01:00.0
GLX Renderer: GeForce GTX 570/PCIe/SSE2
GLX Version: 4.5.0 NVIDIA 367.57 Direct Rendering: Yes
Audio: Card-1 NVIDIA GF110 High Definition Audio Controller
Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
Card-3 Logitech Webcam C270 driver: USB Audio usb-ID: 001-002
Sound: Advanced Linux Sound Architecture v: k4.4.0-64-generic
driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 02:00.0
Card-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 port: c000 bus-ID: 05:05.0
IF: enp5s5 state: down mac: <filter>
Drives: HDD Total Size: 500.1GB (5.8% used)
ID-1: /dev/sda model: TOSHIBA_DT01ACA0 size: 500.1GB
Partition: ID-1: / size: 19G used: 6.7G (39%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 439G used: 19G (5%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 2.00GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 16.5C mobo: N/A gpu: 0.0:48C
Fan Speeds (in rpm): cpu: 0
Info: Processes: 215 Uptime: 2:26 Memory: 720.1/7884.4MB
wanoska
Благодарил (а): 40 раз
#78
08 мар 2017, 14:34
http://imgh.us/wanoska-3.16.0-4-amd64.svg мой дебиан,
wanoska писал(а): мой
мой старый 17.3
ramo0n
Благодарил (а): 3 раза
#80
17 мар 2017, 14:07
Рабочая машина. Из дома еще одну добавлю, аж самому интересно :smile:
mint 18.1 xfce :yoyo:
