Настройка битности и дискретизации для usb наушников
Xen
27 янв 2020, 00:21
Всем привет!
System: Host: elagin-TravelMate-P215-51G Kernel: 5.3.0-26-generic x86_64 bits: 64 compiler: gcc v: 7.4.0
Desktop: MATE 1.22.2 Distro: Linux Mint 19.3 Tricia base: Ubuntu 18.04 bionic
Machine: Type: Laptop System: Acer product: TravelMate P215-51G v: V1.08 serial: <filter>
Mobo: KBL model: Leo_KL v: V1.08 serial: <filter> UEFI: American Megatrends v: 1.08 date: 08/13/2019
Battery: ID-1: BAT0 charge: 52.1 Wh condition: 52.1/51.5 Wh (101%) model: AP18H8L status: Full
CPU: Topology: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
Device-2: NVIDIA GP108M [GeForce MX230] vendor: Acer Incorporated ALI driver: nvidia v: 435.21 bus ID: 01:00.0
Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce MX230/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Device-2: C-Media type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:7
Sound Server: ALSA v: k5.3.0-26-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: d000 bus ID: 02:00.0
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: d000 bus ID: 03:00.0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 938.95 GiB used: 38.28 GiB (4.1%)
ID-1: /dev/mmcblk0 type: USB model: SD size: 7.44 GiB
ID-2: /dev/sda vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB temp: 40 C
Partition: ID-1: / size: 46.68 GiB used: 11.71 GiB (25.1%) fs: ext4 dev: /dev/sda3
ID-2: /home size: 46.68 GiB used: 16.20 GiB (34.7%) fs: ext4 dev: /dev/sda4
ID-3: swap-1 size: 16.39 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 48 C
Info: Processes: 279 Uptime: 1h 02m Memory: 7.63 GiB used: 2.12 GiB (27.8%) Init: systemd runlevel: 5 Compilers:
gcc: 7.4.0 Shell: bash v: 4.4.20 inxi: 3.0.32
Linux Mint x64 19.3 Mate. Настроил звук для встроенной звуковой через /etc/pulse/daemon.conf
daemon.conf
resample-method = copy
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
default-sample-format = float32le
default-sample-rate = 44100
alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
С ней проблем нет. А вот при подключении usb наушников Smartbuy SBHG-3200 TAIPAN идёт звук битностью в 16 , независимо от того, аналоговый или цифровой выход (IE958).
hw_params
access: MMAP_INTERLEAVED
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 44100
buffer_size: 88200
pacmd list-sinks
2 sink(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: RUNNING
suspend cause: (none)
priority: 9049
volume: front-left: 51118 / 78% / -6,47 dB, front-right: 51118 / 78% / -6,47 dB
balance 0,00
base volume: 65536 / 100% / 0,00 dB
volume steps: 65537
muted: no
current latency: 27,59 ms
max request: 4 KiB
max rewind: 4 KiB
monitor source: 0
sample spec: s16le 2-канальный 4410
channel map: front-left,front-right
Стерео
used by: 1
linked by: 1
configured latency: 23,22 ms; range is 0,50 .. 2000,00 ms
card: 0 <alsa_card.usb-C-Media_Electronics_Inc._USB_Audio_Device-00>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "1"
alsa.card_name = "USB Audio Device"
alsa.long_card_name = "C-Media Electronics Inc. USB Audio Device at usb-0000:00:14.0-3, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:00:14.0-usb-0:3:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/sound/card1"
udev.id = "usb-C-Media_Electronics_Inc._USB_Audio_Device-00"
device.bus = "usb"
device.vendor.id = "0d8c"
device.vendor.name = "C-Media Electronics, Inc."
device.product.id = "0012"
device.product.name = "USB Audio Device"
device.serial = "C-Media_Electronics_Inc._USB_Audio_Device"
device.string = "front:1"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Аналоговый стерео"
device.description = "USB Audio Device Аналоговый стерео"
alsa.mixer_name = "USB Mixer"
alsa.components = "USB0d8c:0012"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-usb"
ports:
analog-output-speaker: Динамики (priority 10000, latency offset 0 usec, available: unknown)
properties:
device.icon_name = "audio-speakers"
active port: <analog-output-speaker>
index: 1
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 49152 / 75% / -7,50 dB, front-right: 49152 / 75% / -7,50 dB
balance 0,00
volume steps: 65537
muted: no
current latency: 0,00 ms
max request: 0 KiB
max rewind: 0 KiB
monitor source: 2
sample spec: s32le 2-канальный 4410
Стерео
used by: 0
linked by: 0
configured latency: 0,00 ms; range is 0,50 .. 185,76 ms
card: 1 <alsa_card.pci-0000_00_1f.3>
module: 8
properties:
alsa.resolution_bits = "32"
device.api = "alsa"
alsa.name = "ALC255 Analog"
alsa.id = "ALC255 Analog"
alsa.device = "0"
alsa.card = "0"
alsa.card_name = "HDA Intel PCH"
alsa.long_card_name = "HDA Intel PCH at 0xdf328000 irq 131"
alsa.driver_name = "snd_hda_intel"
device.bus_path = "pci-0000:00:1f.3"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.vendor.name = "Intel Corporation"
device.product.id = "9d71"
device.product.name = "Sunrise Point-LP HD Audio"
device.form_factor = "internal"
device.string = "front:0"
device.buffering.buffer_size = "65536"
device.buffering.fragment_size = "32768"
device.description = "Встроенное аудио Аналоговый стерео"
alsa.mixer_name = "Realtek ALC255"
alsa.components = "HDA:10ec0255,1025132c,00100002 HDA:8086280b,80860101,00100000"
device.icon_name = "audio-card-pci"
ports:
properties:
analog-output-headphones: Аналоговые наушники (priority 9000, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones"
Я так понимаю, что надо Alsa ковырять?
Решение Ара Магеддон » 27 янв 2020, 01:06
А девайс разве поддерживает битрейт больше 16 бит? Вот тут для такого же hwid только 16 значится.
Собственно, можно проверить командой lsusb -vd 0d8c:0012 | grep bBitResolution при воткнутой гарнитуре.
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
Настройка битности и дискредетации для usb наушников
27 янв 2020, 01:06
Xen
27 янв 2020, 11:17
Ара Магеддон писал(а):
27 янв 2020, 01:06
Да, не поддерживает. Были бы не USB или с другим чипом, то поддерживали, как я понимаю. Спасибо.
bBitResolution
Couldn't open device, some information will be missing
bBitResolution 16
bBitResolution 16
Damian
Благодарил (а): 24 раза
27 янв 2020, 12:52
А как вот на примере этой модели можно понять поддерживает ли больше 16 бит,там есть кроме usb и обычное подключение(звук и микрофон).
Ара Магеддон
Решено: 18
27 янв 2020, 15:30
Damian писал(а):
27 янв 2020, 12:52
До покупки - только гуглить. Выяснить, что за чип стоит, потом гуглить характеристики чипа. И то не факт, что ЧД/битрейт девайса будут соотвествовать максимальным характеристикам чипа.
После покупки - выяснить идентификатор устройства командой lsusb и детальную информацию командой lsusb -vd идентификатор
27 янв 2020, 16:00
Эм... Не очень хочется быть "тем самым занудой", но мимо такого названия темы пройти не могу:
Дискредитация
Дискретизация
colonel
Решено: 21
27 янв 2020, 20:54
мимо такого названия темы пройти не могу ...
дискредеИтации
ну это же не обрезание с кастрацией спутать
27 янв 2020, 21:50
colonel писал(а):
27 янв 2020, 20:54
Как бы, в данном случае совсем не в этой букве проблема. Пройдите по обоим ссылкам. :)
Xen
28 янв 2020, 10:54
27 янв 2020, 21:50
colonel писал(а):
27 янв 2020, 20:54
Спасибо за замечание! После 2- ух суток настройки Линукса на новом ноуте и не такое может быть))) К сожалению, название темы не поменять уже, насколько понимаю.
28 янв 2020, 10:59
Xen писал(а):
28 янв 2020, 10:54
:-D
 ! Сообщение из: symon2014
Поправил.
Благодарил (а): 1216 раз
28 янв 2020, 14:55
27 янв 2020, 16:00
А гугло-переводчику пофиг
colonel
Решено: 21
28 янв 2020, 19:02
27 янв 2020, 21:50
как бы, в данном случае совсем не в этой букве проблема. Пройдите по обоим ссылкам
не умничайте , как бы в данном случае подчеркнул что кроме не правильного применения термина присутствует и грамматическая ошибка.
и косяк в применении и без википедии виден , да и знакомы термины без похода по ссылкам.
Вернуться в «Звуковые карты»
