В программе cheese выводится сообщение о том, что устройства не найдены.
Модель веб-камеры Genius FaceCam 300
Идентификатор веб-камеры 093a:2627
Используемая ОС Linux Mint 19.3 (64-bit xfce)
Что делать?
вывод inxi -Fxz в спойлере:
Host: ura-All-Series Kernel: 5.3.0-42-generic x86_64 bits: 64
compiler: gcc v: 7.4.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <filter>
BIOS: American Megatrends v: 2501 date: 07/22/2015
Topology: Dual Core model: Intel Pentium G3420 bits: 64 type: MCP
arch: Haswell rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12799
Speed: 803 MHz min/max: 800/3200 MHz Core speeds (MHz): 1: 1693 2: 1595
Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
v: 435.21 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 750 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 01:00.1
Sound Server: ALSA v: k5.3.0-42-generic
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 03:00.0
Local Storage: total: 465.76 GiB used: 12.80 GiB (2.7%)
ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
ID-1: / size: 92.47 GiB used: 12.80 GiB (13.8%) fs: ext4 dev: /dev/sda5
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): cpu: 0 gpu: nvidia fan: 25%
Processes: 187 Uptime: 12m Memory: 7.72 GiB used: 1.63 GiB (21.2%)
inxi: 3.0.32
bus ID: 01:00.1
inxi: 3.0.32
Bus 002 Device 002: ID 8087:8000 Intel Corp.
Bus 001 Device 002: ID 8087:8008 Intel Corp.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 006: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 003 Device 010: ID 093a:2627 Pixart Imaging, Inc.
Bus 003 Device 004: ID 04da:0f0b Panasonic (Matsushita)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
