встроенная вэб-камера
Автор темы - Сообщения: 12
Здравствуйте. Не работает встроенная вэб-камера в ноутбуке Asus X83V...камера не определяется системой в 19.3, хотя работала в 18.3 ...чтобы это значило, и что можно сделать ?
- Решено: 40
Host: aleksey-N80Vb Kernel: 5.3.0-51-generic x86_64 bits: 64 compiler: gcc
v: 7.5.0 Desktop: Xfce 4.14.1 Distro: Linux Mint 19.3 Tricia
base: Ubuntu 18.04 bionic
Type: Laptop System: ASUSTeK product: N80Vb v: 1.0 serial: <filter>
Mobo: ASUSTeK model: N80Vb v: 1.0 serial: <filter>
BIOS: American Megatrends v: 207 date: 12/05/2008
ID-1: BAT0 charge: 17.6 Wh condition: 18.2/52.8 Wh (35%)
model: ASUSTEK F8---24 status: Unknown
Topology: Dual Core model: Intel Core2 Duo T5800 bits: 64 type: MCP
arch: Core Merom rev: D L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7980
Speed: 798 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 798 2: 798
Device-1: NVIDIA G98M [GeForce 9300M GS] vendor: ASUSTeK U6V laptop
driver: nouveau v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.5 driver: modesetting unloaded: fbdev,vesa
resolution: 1280x800~60Hz
OpenGL: renderer: NV98 v: 3.3 Mesa 19.2.8 direct render: Yes
Device-1: Intel 82801I HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k5.3.0-51-generic
Device-1: Intel WiFi Link 5100 driver: iwlwifi v: kernel port: cc00
bus ID: 03:00.0
vendor: ASUSTeK U6V/U31J laptop driver: r8169 v: kernel port: e800
bus ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 30.93 GiB (6.6%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
ID-1: / size: 11.40 GiB used: 5.87 GiB (51.5%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 444.24 GiB used: 25.06 GiB (5.6%) fs: ext4
dev: /dev/sda6
ID-3: swap-1 size: 1.77 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nouveau temp: 45 C
Processes: 179 Uptime: 2h 33m Memory: 3.84 GiB used: 1009.7 MiB (25.7%)
inxi: 3.0.32
aleksey@aleksey-N80Vb:~$ hwinfo --usb
03: USB 00.0: 10a00 Hub
[Created at usb.122]
Unique ID: 7eqy.v+N+B0xY+P6
SysFS ID: /devices/pci0000:00/0000:00:1d.0/usb6/6-0:1.0
SysFS BusID: 6-0:1.0
Hardware Class: hub
Model: "Linux Foundation 1.1 root hub"
Hotplug: USB
Vendor: usb 0x1d6b "Linux Foundation"
Device: usb 0x0001 "1.1 root hub"
Revision: "5.03"
Serial ID: "0000:00:1d.0"
Driver: "hub"
Driver Modules: "usbcore"
Speed: 12 Mbps
Module Alias: "usb:v1D6Bp0001d0503dc09dsc00dp00ic09isc00ip00in00"
Config Status: cfg=new, avail=yes, need=no, active=unknown
04: USB 00.0: 10a00 Hub
Unique ID: uIhY.MxUuepIFPaE
SysFS ID: /devices/pci0000:00/0000:00:1a.0/usb3/3-0:1.0
SysFS BusID: 3-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1a.0"
Driver: "hub"
Speed: 12 Mbps
05: USB 00.0: 10a00 Hub
Unique ID: BSFT.gkSaZmjGyhD
SysFS ID: /devices/pci0000:00/0000:00:1d.1/usb7/7-0:1.0
SysFS BusID: 7-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1d.1"
Driver: "hub"
Speed: 12 Mbps
06: USB 00.0: 10a00 Hub
Unique ID: zPk0.7gZT0a5zLs5
SysFS ID: /devices/pci0000:00/0000:00:1a.1/usb4/4-0:1.0
SysFS BusID: 4-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1a.1"
Driver: "hub"
Speed: 12 Mbps
07: USB 00.0: 10a00 Hub
Unique ID: FZIx.RTX9xWW_uz4
SysFS ID: /devices/pci0000:00/0000:00:1d.2/usb8/8-0:1.0
SysFS BusID: 8-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1d.2"
Driver: "hub"
Speed: 12 Mbps
08: USB 00.0: 10a00 Hub
Unique ID: k4bc.cO89g+iefn1
SysFS ID: /devices/pci0000:00/0000:00:1a.7/usb1/1-0:1.0
SysFS BusID: 1-0:1.0
Hardware Class: hub
Model: "Linux Foundation 2.0 root hub"
Hotplug: USB
Device: usb 0x0002 "2.0 root hub"
Revision: "5.03"
Serial ID: "0000:00:1a.7"
Driver: "hub"
Speed: 480 Mbps
Module Alias: "usb:v1D6Bp0002d0503dc09dsc00dp00ic09isc00ip00in00"
09: USB 00.0: 10a00 Hub
Unique ID: 2XnU.uOe2OKugI8D
SysFS ID: /devices/pci0000:00/0000:00:1a.2/usb5/5-0:1.0
SysFS BusID: 5-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1a.2"
Driver: "hub"
Speed: 12 Mbps
10: USB 00.0: 10a00 Hub
Unique ID: pBe4.9T1GDCLyFd9
SysFS ID: /devices/pci0000:00/0000:00:1d.7/usb2/2-0:1.0
SysFS BusID: 2-0:1.0
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Serial ID: "0000:00:1d.7"
Driver: "hub"
Speed: 480 Mbps
Пардон....во что надо форматировать? Я не делал этого.
Последний раз редактировалось пользователем 1 bims130562; всего редактировалось раз: 1
01: SCSI 600.0: 10600 Disk
[Created at block.245]
Unique ID: Zj8l.m6B0iUn4_F2
SysFS ID: /class/block/sdb
SysFS BusID: 6:0:0:0
SysFS Device Link: /devices/pci0000:00/0000:00:1d.7/usb2/2-4/2-4:1.0/host6/target6:0:0/6:0:0:0
Hardware Class: disk
Model: "JetFlash Transcend 16GB"
Vendor: usb 0x8564 "JetFlash"
Device: usb 0x1000 "Transcend 16GB"
Revision: "8.07"
Serial ID: "BB4C9284"
Driver: "usb-storage", "sd"
Driver Modules: "usb_storage"
Device File: /dev/sdb (/dev/sg2)
Device Files: /dev/sdb, /dev/disk/by-id/usb-JetFlash_Transcend_16GB_BB4C9284-0:0, /dev/disk/by-path/pci-0000:00:1d.7-usb-0:4:1.0-scsi-0:0:0:0
Device Number: block 8:16-8:31 (char 21:2)
Speed: 480 Mbps
Module Alias: "usb:v8564p1000d0100dc00dsc00dp00ic08isc06ip50in00"
Driver Info #0:
Driver Status: uas is active
Driver Activation Cmd: "modprobe uas"
Driver Info #1:
Driver Status: usb_storage is active
Driver Activation Cmd: "modprobe usb_storage"
Drive status: no medium
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 480 Mbps
11: USB 00.0: 10a00 Hub
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 12 Mbps
12: USB 00.0: 10a00 Hub
Hardware Class: hub
Hotplug: USB
Revision: "5.03"
Driver: "hub"
Speed: 480 Mbps
[b][b][/b][/b]
- Решено: 40
Флешка появляется , камеры не видно. Есть под рукой флешка с 18.3 ? Проверить , не сдохла ли камера. И ещё вопрос , давно ли ставил 19 минт?
Ну, короче....всем спасибо, все свободны. А мы уж как-нибудь сами......уж больно вы, ребятки,умные и язвительные. Высокого полёта птицы.
