inxi
Kernel: 5.15.0-48-generic x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Cinnamon 5.4.12 Distro: Linux Mint 21 Vanessa
base: Ubuntu 22.04 jammy
Type: Desktop Mobo: HUANANZHI model: X79 v: 249PC V2.2
serial: <superuser required> UEFI: American Megatrends v: 4.6.5
date: 06/08/2020
Info: 6-core model: Intel Xeon E5-2620 v2 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 4 cache: L1: 384 KiB L2: 1.5 MiB L3: 15 MiB
Speed (MHz): avg: 1289 high: 1788 min/max: 1200/2600 cores: 1: 1200
2: 1200 3: 1200 4: 1201 5: 1200 6: 1216 7: 1556 8: 1200 9: 1200 10: 1788
11: 1260 12: 1251 bogomips: 50405
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP107 [GeForce GTX 1050] vendor: Gigabyte driver: nvidia
v: 470.141.03 bus-ID: 04:00.0
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: nvidia
gpu: nvidia resolution: 1: 2560x1440~60Hz 2: 1600x900~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 470.141.03 direct render: Yes
Device-1: Intel C600/X79 series High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 04:00.1
Sound Server-1: ALSA v: k5.15.0-48-generic running: yes
driver: r8169 v: kernel port: d000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 3.87 TiB used: 10.36 GiB (0.3%)
ID-1: /dev/nvme0n1 vendor: SanDisk model: Extreme Pro 1TB
size: 931.51 GiB temp: 36.9 C
ID-2: /dev/sda vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD30PURX-64P6ZY0
ID-1: / size: 39.08 GiB used: 9.75 GiB (24.9%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 33.6 MiB (35.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 160.37 GiB used: 595.5 MiB (0.4%) fs: ext4
dev: /dev/nvme0n1p7
Swap:
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p6
System Temperatures: cpu: 23.0 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Processes: 309 Uptime: 0m Memory: 15.56 GiB used: 1.16 GiB (7.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.2.0 Packages: 2249 Shell: Bash
v: 5.1.16 inxi: 3.3.13
date: 06/08/2020
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p7
Swap:
dev: /dev/nvme0n1p6
