геймпад sven GC-150
Numenorian
геймпад sven GC-150
05 июл 2020, 08:16
Имеется:
1. Геймпад, как на картинке.
2. ПК -
  Host: melon Kernel: 4.15.0-109-generic x86_64 bits: 64 compiler: gcc
  v: 7.5.0 Desktop: Cinnamon 4.0.10 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
  Type: Laptop System: Sony product: VPCEB1E1R v: C603S026 serial: <filter>
  Mobo: Sony model: VAIO serial: <filter> BIOS: American Megatrends
  v: R0220Y8 date: 01/12/2010
  Topology: Dual Core model: Intel Core i3 M 330 bits: 64 type: MT MCP
  arch: Nehalem rev: 2 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17024
  Speed: 1118 MHz min/max: 933/2133 MHz Core speeds (MHz): 1: 1463 2: 1463
  3: 1463 4: 1463
  Device-1: AMD Park [Mobility Radeon HD 5430/5450/5470] vendor: Sony
  driver: radeon v: kernel bus ID: 01:00.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 4.15.0-109-generic LLVM 9.0.0)
  v: 3.3 Mesa 19.2.8 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Sony
  Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
  vendor: Sony driver: snd_hda_intel v: kernel bus ID: 01:00.1
  Device-3: JMTek LLC. type: USB driver: hid-generic,snd-usb-audio,usbhid
  bus ID: 2-1.2:3
  Sound Server: ALSA v: k4.15.0-109-generic
  Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
  vendor: Foxconn T77H126.00 802.11bgn driver: ath9k v: kernel port: d000
  bus ID: 02:00.0
  IF: wlp2s0 state: down mac: <filter>
  Device-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet with AVB]
  vendor: Sony driver: sky2 v: 1.30 port: a000 bus ID: 04:00.0
  Local Storage: total: 298.09 GiB used: 36.74 GiB (12.3%)
  ID-1: /dev/sda vendor: Toshiba model: MK3265GSX size: 298.09 GiB
  ID-1: / size: 22.79 GiB used: 11.94 GiB (52.4%) fs: ext4 dev: /dev/sda1
  ID-2: /home size: 265.83 GiB used: 24.67 GiB (9.3%) fs: ext4
  dev: /dev/sda6
  ID-3: swap-1 size: 3.72 GiB used: 133.5 MiB (3.5%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 54.0 C mobo: 54.0 C gpu: radeon temp: 55 C
  Processes: 230 Uptime: 17h 28m Memory: 3.71 GiB used: 2.33 GiB (62.8%)
  inxi: 3.0.27
3. Jstest-gtk который определяет геймпад как 10 кнопочный с 2 осями. Все кнопки, калибровка работают.
Суть вопроса: При использовании в эмуляторах NES пад работает отлично, но стоит запустить эмуль SEGA MD и попытаться назначить кнопки - ни в какую. Тоже самое наблюдается в ряде игр - в каких то кнопки R1 и R2 не определяются, в каких то игра вообще не видит пад. Как выяснить, на чьей стороне косяк? ПО, моей или самого геймпада?
Ара Магеддон
Решено: 18
Благодарил (а): 37 раз
геймпад sven GC-150
05 июл 2020, 08:39
А как эмулятор сеги называется? Раз оборудование работает в двух независимых софтинах - значит, с ним всё должно быть в порядке.
Можно погуглить "название эмуля + gamepad": может, какая общая проблема всплывёт.
Можно попробовать альтернативный маппер: apt install antimicro
Numenorian
геймпад sven GC-150
05 июл 2020, 08:41
Ара Магеддон писал(а):
05 июл 2020, 08:39
я пробовал ВСЕ эмули с этого сайта https://www.emu-land.net/consoles/genesis/emuls/linux ни один адекватно не работает, счас попробую другой маппер
Numenorian
геймпад sven GC-150
05 июл 2020, 09:07
05 июл 2020, 08:39
Попробовал, Антимикро мой пад вообще не опознаёт, открыватеся окно где есть уже 2 контроллера, которые я создавал через эмулятор BlastEm но некорректно, как в нем сделать сбрс на дефолтные настройки тоже не знаю, в то время как jstest-gtk видит пад и все кнопки
Numenorian
геймпад sven GC-150
05 июл 2020, 09:14
Эмулятор BlastEM выдает следующие ошибки при запуске: no SDL2 mapping exists for input a on gamepad 0 и no SDL2 mapping exists for input guide on gamepad 1
